Question about Connex 3300 240-Channels Base CB Radio
CB RADIO RECEIVING PROBLEMS - Connex 3300 240-Channels Base CB Radio
  • AVONMATT Jun 28, 2008
    connex 3300 hp peak and tuned on a wilson 1000 with a six foot whip on pick up truck cab gets out real good but not receiving worth a darn sometimes not at all unless its a big radio pushing some power
  • 90 Answers
This is a 10 meter radio & is factory tuned to 29 MHz. If you are using it on CB the receiver should be retuned to 27.205 Mhz by a competent tech. Most dealers who modify & peak these radios never tune the receiver.
Posted on Sep 05, 2008
  • 27 Answers
You need to supply more information regarding make model type
am / uhf etc.........Cheers
Posted on Jun 27, 2008
  • flyingfox Jun 29, 2008
    Listen for hiss from the speaker...check it with a analogue multi-
    meter by touching solder tags by holding one probe on a tag and touch the other probe should hear a scratching sound = Working. next..every solder joint has to be checked for dry joints working outwards from the flying leads ( i simply resolder and that often will cure the problem as cb rabio is subject to they are also in a hostile inviorment ) i also replace electro caps that are small value in uF as through heat in a truck the electrolite dries up and the cap no longer functions.The good news is that 98% of parts in older sets a freely available in 2008 from electronic parts stores but not the few ICs . If you set is 27 meg with USB LSB it is worth a rebuild
    but it can be costly if done by service personal. not shift the position of trinpots or tuning slugs without marking their factory set positions so you will be able to return them to the same position. in the case of active component failure it is not often an untrained person can repair a CB.. also it requires
    bench test gear that would cost more than any CB is worth NOTE.. there are any number of faults that will cause loss of CB
    functions and before you can be told ,the fault has to be found.
Why does the mic attachment on my cb radio cause receiving & output problems?
did the radio do well at the cb shop you took it to? when you re-installed it in your vehicle did you change the coax? You may think about taking it to another shop for a second opinion as to whether or not the radio was actually tuned.
Oct 17, 2015 | Radio Communications
Problem no squelch noise or speaker like its muted, but can hear weather ok shows receiving and ant ok
Since the radio cannot transmit on Weather bands, there is no need for the radio to detect if it is transmitting when receiving weather.
In CB mode (on CB channels) the radio will mute when transmitting. So... a guess is that it is muting, or transmitting all the time in CB mode. Check for a mic problem by removing the Mic from the radio ... if it receives CB with no mic connected, then there is an issue with the mic. Otherwise, unless the unit is in PA mode (public address mode) it is likely something internal and beyond the scope of this service.
Sep 08, 2015 | Cobra 29lx Cb Radio W/clock 29 Lx Lcd
My cb radio is saying its transmitting and receiving but when I put out for radio check I'm getting no reply and don't think anybody can pick me up
Can you hear anyone on the CB? Does anyone actually use CB these days.
Check the connections to the antenna. Did you tune the antenna with a SWR meter?
Aug 13, 2015 | Radio Communications
2001 Honda GL 1800 Gold Wing CB radio not receiving clearly
Hi, David for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
GL 1800 CB radio problem
CB radio not receiving any more GL1800
Honda GL1800 Service Manual
GL 1800 CB RADIO operators manuel GL1800 Information Questions...
Honda Goldwing GL1800 Owner Manual
Aug 11, 2013 | 2001 Honda GL 1800 Gold Wing
TRC-481 No sound
test the internal speaker to see that sound is indeed getting to it.Hook an external speaker to it and see if that just may have to change the speaker but it could be more than that. Do thisfor now then repost as to what you did and whether it worked or not because there is more problems and they are internal. Just go with this for now and if it doesn't work you may have to get it to a tech to repair it.
Jan 10, 2013 | Radio Shack Trc-481 Cb Radio
2 out of 5 signal reading on cobra cb radio
You'll need to find another CB radio for someone to check to see if they are receiving your transmission.
Aug 16, 2012 | Cobra 19 DX IV CB Radio
Low transmitting range on Cobra MRF55
Hi dstrand, sorry you are having a problem. I will need some more info if you can. Is this radio in a base situation or mobile? Have you had any work don recently? Have you changed anything on the system? (Microphone, antenna, coax, etc)
Haave you checked your swr recently/ If yes, did you use a seperate meter or did you use one built in the radio?
Hope to hear from you soon.
Dec 30, 2008 | Cobra MR- F55 Base CB Radio
Limited cb radio range on Kenworh t800 truck
I recall problems grounding the antenna on those kw's. May want to try a no ground antenna. Also the stock coax that comes with the truck sometimes gets broken or pinched. Go to a good shop, replace the cheap coax and grount the antennas.
Nov 26, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Connex 3300 240-Channels Base CB Radio Logo
369 people viewed this question
Top Connex Radio Communications Experts
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
