Tv keeps blowing fuses... - Televison & Video
    Genius:
  • Televison & ... Master
  • 1,689 Answers
This could be a blown power supply, or there is a short on one of the boards. Without the process of elimination, this would be impossible to easily work out. Many times these shorts cannot be found with simple ohm readings using a DVM.
You will have to send the set for factory service to have it serviced.
Jerry G.
Posted on Jun 27, 2008
Tv fuse keeps blowing
You have an electrical short inside the TV. The fuse keeps blowing to prevent any further damage to the TV circuitry.
Jan 07, 2014 | Emerson Televison & Video
Panasonis 50" plasma, both fuses keep blowing when
This is a dead short, check power supply for diodes bad or zeners
Mar 08, 2011 | Panasonic Viera TH-50PX80U Plasma TV
TV won't turn on
take the back off the tv and inspect the glass fuse off the ac power cord, it will probably be black and open, this is a common problem, it blows because the degaussing circuit works too slow, the original fuse is an 6.3 amp fuse, you need to replace it with a 6.3 amp slow blow or a 7 or 8 amp fuse to keep it from blowing, if you put an original 6.3 amp fast blow fuse in it, it will work for a while, but will blow again someday.
Sep 07, 2009 | Panasonic CT-32SX12 32" TV
My tv keeps blowing a fuse when I turn on set.
DO NOT keep feeding it fuses more damage can accur-check rectifiers in power supply-then check regulator-chech H.O.transistor.if you need more help im gonna need a model number to go furthor
Sep 04, 2009 | Televison & Video
My sd-533hd5 keeps blowing the 5 amp 125v fuses
Yes! it sounds like a power supply problem! or the flyback in the main board needs replaced ( part is in the $70.00 range
Dec 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Blown fuse
Most likely there was a power event (surge, brownout, ect) that caused the power supply to fail in the TV causing the fuse to blow. you will need to have someone come and look at the unit and give you an estimate. If you keep putting fuses in and blowing them you could actually be causing more damage.
Mar 10, 2008 | Televison & Video
TV KEEPS BLOWING FUSES
means you have a part that is dead shorted after the line fuse, usually a bridge diode, regulator IC or possibly the Horizontal output transistor. Not really something a non tech will be able to find, a volt Ohm meter is required as well as soldering equipment.
Nov 27, 2007 | Panasonic CT-36G34 36" TV
Proscan PS32610
Tv keeps blowing fuses it is due to short ckt in your tv in 1 power supply. 2 horl output section it is mainly due to 1 switching transistr 2 main fil cap 3 rectifier diodes 4 print short 5 h/output tra. 6 eht transformer
Sep 25, 2007 | Proscan PS36810 TV
Fuse blows.
Please check for shorted diode or condenser at power section.
May 29, 2006 | Panasonic CT-27G14 27" TV
Televison & Video Logo
134 people viewed this question
Top Televison & Video Experts
