Question about Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive
Connection My computer no longer recognizes the External Drive. No connection. Can anything be done, or do I need to take this to a computer repair shop to extract the drive data?
  • gdgr Sep 14, 2008
    Mon système Microsoft XP ne reconnais plus mon disque dur
    Alors que mon portable avec microsoft XP le reconnais...
    Que dois-je faire????
    Problem Solver:
  • 8 Answers
Try checking your power cord adapter.
I found the same problem was with the cord.
Luckily, I had another Acomdata HD cord to check the problem.
Posted on Sep 02, 2008
External hard drive data recovery
If a hard drive is not recognized by your computer, there is no way to get data out of it using conventional procedures.
You should take your device to a computer repair shop and if neithe they can do anything, maybe can give you information about getting professional data recovery service... but it is EXPENSIVE.
Apr 18, 2015 | Hard Computers & Internet
Dropped SmartDisk
Depending upon how hard the jar was to the internal mechanism, the data may be salvageable. I would guess that the first problem is broken connections at the USB connector. This case is just snapped together with a laptop drive in it. Carefully open it up and look for anything broken.
Worse case scenerio, you can get an adapter to plug the drive into a standard IDE cable inside your tower system.
Dan
Mar 20, 2008 | SmartDisk FireLite 40 GB Hard Drive
External drive not picked up on computer
External hard drives not only provide additional storage space on a computer system but also allow data to be conveniently transported from one computer to another.
These drives typically plug right in to a port on the computer and function without any additional setup; however, if you are running into trouble where your external hard drive is not being detected, you must troubleshoot the situation to determine why the drive appears to be missing.
Check the USB connection running from the hard drive to your computer.
If the USB cable is not seated securely in the port, the computer will not detect the external drive.
Disconnect the USB cable from the computer and plug it into a different USB port. Occasionally, a USB port will fail to function with some hardware and changing the USB connection may correct this issue.
Switch from a USB to a Firewire cable connection, if possible.
The USB port on the hard drive may have died; if so, changing to a Firewire connection will resolve this issue.
Install the driver for the external device from the installation disc provided with the product. Older computer systems may require you to manually install this driver.
After inserting the installation CD, follow the prompts from the installation wizard to install the driver on your computer.
Restart the computer.
If you connected the external drive while the computer is powered down, it may not recognize the device when you turn on the computer.
After restarting the computer, connect the external drive to the system.
The drive should now be detected by your operating system.
Connect the external hard drive to a power source and then plug it into your PC computer using a USB or Firewire cable.
Log on to your PC computer using an account with administrative privileges.
Open the Start menu and click on the "Control Panel" icon.
Open the "Administrative Tools" folder and then double-click on the "Computer Management" icon.
Select "Disk Management" from the list of options on left side of the window.
Right-click on the drive you want your computer to recognize and select "Change Drive Letter and Paths."
Select a drive letter for the external hard drive to be recognized as and click "OK."
The drive will now appear in My Computer.
Hope this helps.
Nov 22, 2012 | Samsung G3 Station Desktop External Drive...
My fantom hd tfd500u16 is no longer recognized by my computer. I get a blue light and I hear the hd spinning. I uninstalled/reinstalled the drivers, replaced usb cord and tried connecting to other...
Is this an inbuilt drive or an external drive? If you're using USB, it needs a USB connection. It shouldn't need drivers as the computer will automatically detect a hard drive.
Have you tried connecting to a completely different computer to see if that recognised it?
Dec 30, 2010 | Fantom Titanium Hard Drive
I have a d2 HD Quadra connected to an iMac(intel) but it is no longer being recognized. It will not even show up in disk utility. System shows an unidentified firewire connection
Please try it with another computer, a mac or a PC and see if it works.
If the problem remains on another computer the drive has a hardware issue, depends on how old it is the power supply (external box) is, they tend to fail in few years or sooner.
is it in warranty? this will most likely have to be sent to repair, what you could do is if its outside of warranty, you could take the drive apart and place the Hard drive into a new external case and continue using it, thats if the old case is what broke down and not the hard drive it self.
Sep 02, 2009 | Computers & Internet
Computer does not recongnize connection
External is damanged or you have problem with USB drivers...
May 10, 2009 | Beyond Micro MobileDisk 500GB 3.5 External...
Unrecognizable USB External Harddrive
dear jpaws check your computers device manager. ithink you need drivers please install a driver.
Feb 25, 2008 | Computers & Internet
External Hard Drive will not post "Cavalry Storage CAUI35160 Hard Drive"
if your hard drive making a unusual noise there something happened to the internal parts of the drive. does your hard drive accidentally dropped?
ok. check your jumper settings. set your jumper to slave. try it might work.
Jan 28, 2008 | Cavalry Storage CAUI35160 Hard Drive
Rock Mobile external hard drive was accidentaly dropped
Well it has been cause a mischief that's for sure. Try dismantling the case to check the connectors but that is about all you can do - if the drive is done then it stays done there is no repair option
Jun 02, 2007 | Ultra 1 Bay USB 2.0 External Drive Case
Acomdata (HD250UE5-72) (HD250UE572) 250 GB Hard Drive Logo
168 people viewed this question
Top Acomdata Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
