Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Philips HDTV wont turn on
Hi, i have a 60" philips HDTV and it wont turn on and the light doesnt even show that it receiving any power. i believe that there may have been a power outage and the bulb blew. i was told to look and find the panel but im not sure where it is.....i see 2 side panels. Could u please advise where to look to find the bulb.
How do you remove the rear cover on the phillips 69PP9202? I know this probably sounds stupid but it wont budge with a screw driver. Help!
Posted on Aug 10, 2010
  • Philips Master
  • 8,617 Answers
If your model number is 60PP9202 you dont have a bulb, you have three CRT picture tubes instead, and if the power light doesnt come on check the fuse on the power board. Remove the rear cover after unplugging the cord and look at the small board on the irght where the power cord attaches you will see a fuse its most likely blown.
Posted on Jun 27, 2008
4 Suggested Answers
Ecollier2012
  • 3459 Answers
SOURCE: Projection Lamp for Philips 60PL9200D/37 TV
More than likely the problem is the CRT fluid and not the tube. Do a few google or fixya searches on CRT fluid and to get an idea of what it looks like when it gets cloudy.
Posted on Nov 18, 2008
maatmartin7
  • 1213 Answers
SOURCE: Philips Magnavox 9p6034c bulb is bad
If you have to replace one, they are very difficult to pull out and replace. You must do a convergence on the color of the tube you replace. You will be replacing a picture tube not a bulb. You may need to replace the fluid in the one tube. Or you may have a convergence problem. You need a TV tech to reveal that the problem is not a bad picture tube....which is rare in your case! Good Luck and thanks for asking!
Posted on Jun 12, 2010
toyladi3
  • 597 Answers
SOURCE: 60 inch philips rear projection hdtv one day just
The blinking is a sign that there is a problem in the unit that needs to be checked, that is why the television did not come on.
Most likely a power problem.
You can unplug the unit for some time lets say for about an hour or 2, then open up the cover of the television then assess the panel for any burnt capacitor, then replace it, and if it is the power panel that is faulty, then you can replace it as well. It goes for a token.
Take care
Posted on Oct 11, 2010
Testimonial: "where can i find the parts i need to fix it?? "
Philips 60PP9202 60 in. Rear Projection HDTV-Ready Television no Picture no sound
Are you getting some kind of high pitched squeel from set when you try to turn it on?
The more you tell me the more I can help.
Nov 10, 2011 | Philips 60PP9202 60" Rear Projection...
Turned off by itself and never came back what part will I replace
If the TV is completly non-responsive (ie not even a flicker of light on the power button) then one of the first things to check on this is the fuses - easiest being the right corner next to where the power cord plugs in (have to take off the back panel)
May 30, 2009 | Philips 60PP9202 60" Rear Projection...
Philips Hopper SV20 Impact Multimedia Projector doesnt power up
hi the power supply of your unit is burnt refer service personnel
shyam
+919867355202
Feb 08, 2009 | Philips Hopper SV20 Impact Multimedia...
There is power to the tv but it wont turn on.
it probably burned one of the circuit boards youll need to call a repairman out to lookit over
Jan 29, 2009 | Philips 60PP9202 60" Rear Projection...
No Power
Check the fuse on the small board on the far right inside the TV.
Oct 25, 2008 | Philips 60PP9202 60" Rear Projection...
Hdtv 32"
this is symptomatic of the power boards in these larger tv's you will need a service tech to come out and diagnose the actual issues
May 08, 2008 | Philips 32PFL7332D 32 in. LCD HDTV
Philips 60" HDTV Rear Proj NO POWER
Is the led flashing or just steady light? Also do you hear a click when you hit the power button?
Apr 07, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
87 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
