Question about VillaWare 3900 Krumkake Baker
Non-stick peeling off
The non-stick coating has started to peel off the bottom plate, can I replace just the plate?
  • 1,689 Answers
You should get in touch with the manufacture service rep, or directly in touch with them to find out how to order spare parts.
I found that with Tephlon coatings, after some time they all start to peel and not perform very well.
Jerry G.
Posted on Jun 27, 2008
Does anyone know how to contact these folks? The non-stick coating on the Grill started peeling off in sheets so I can use it unless I cover it with aluminum foil. I want it replaced!
Best of luck, you did not post the maker info but there is a limit on what they replace and they will say it is your fault, you cooked to hot or you did not hand wash or you used sharp objects (utensils)
May 26, 2017 | The Kitchen Appliances - Others
They are peeling inside. Only had 3 years. What do I do?
bakers use black steel trays in which to bake bread
they are only covered in butter to stop sticking so if you follow the same procedure it will be alright
the covering that is coming off is probably the non-stick teflon coating which medical evidence proves not to be good for us as it breaks down with heat and age and is basic carcinogenic in nature
Look at all your old non stick pans and ask yourself , where did all the covering go?
Dec 15, 2015 | Kitchen Appliances - Others
Peeling nonstick coating
It can't be fixed. In the future, use only plastic cooking utensils so they won't scratch off the non stick coating. You can line the pan with foil if it is a baking pan, if it's a frying pan, there's no fixing it.
Apr 07, 2014 | KitchenAid 16-Inch by 13.5-Inch Roaster...
Is it possible to restore the teflon surface of teflon coated pans on which the surface has become scratched (in this case Jamie Oliver Tefal Frying pans)
No. There is no effective repair procedure for the pan once the teflon coating has become scratched down to the bare metal or begins peeling off.
You can continue to use the pan safely, but the non-stick surface will not be as effective as an undamaged coating would be.
Never use metal forks / spatulas / utensils on a teflon coated pan.
Instead try using thermal rated plastic, teflon, or wooden spatulas which will not scratch the pan coatings.
Good luck.
Jun 12, 2011 | Microwave Ovens
Paint inside lid peeling off when I cook
From Don’t worry, it’s not paint. The inside surfaces of our grill lids are not painted, they are coated with baked-on porcelain enamel which cannot peel. What you are noticing is a deposit of grease and smoke that collects during normal use. During use, the grease and smoke vapors slowly oxidize into carbon and collect on the inside of your lid. This deposit will eventually peel, and looks very similar to paint. The peeling normally starts in the center of the lid and spreads outward. It may come off in sheets or flakes, and is shiny on one side and dull on the other. These carbon deposits are non-toxic. But you might want to regularly remove the build-up. Fortunately, the peeling is easy to remove. Simply brush off all loose particles with a brass brush before you start grilling. To prevent future build-up, after every grilling session, while the grill lid is warm—not hot—wipe it with paper towels or a mild soap-and-water solution.
Apr 25, 2009 | Weber Genesis Silver C Grill
Bread Machine non-stick starting to peel off
Since your machine is only about 6 months old, it should still be covered under warranty. I'd contact the manufacturer. (Contact information should be in the instruction manual). The teflon coating is just a sprayed on coating. Once it starts to peel, it's not safe to use them. It becomes hazardous (possibly eating it in the bread).
It sounds like you've taken care of the pan as it's supposed to be. If this was an older machine, I'd suggest ordering a new pan. You can find them on the internet quite easily.
Apr 01, 2009 | Zojirushi BBCC-X20 Home Bakery Supreme...
Coffeemaker nonstick coating is peeling off
you need to replace it when it doesn't make coffee anymore
Feb 28, 2009 | Hamilton Beach Aroma Elite 48101
$5.00 plus shipping or somewhere around $10. How much is a new toaster? I just scrubbed the remaining coating off my replacement pan that also peeled and it works fine. $10 is too much money for something that will peel just like the original. Too bad they won't make them available in stores that sell the toasters and at least save the consumer shipping.
Apr 12, 2008 | Back to Basics TEM-500 Egg & Muffin...
Non-Stick surface peeling off inside microwave.
Normally you can strip and sand the old paint, get it squeaky clean, and use appliance paint. Yes indeed it is a heat-resistant enamel. You can get it from appliance parts stores, Wal-Mart, or home centers, etc. BUT if it's under warranty I would call GE Customer Relations with your model and serial numbers. They're at 1-800-386-1215 (8-6 ET) and I would also suggest you ask them for a referral to a GE-authorized servide center in your area. Good luck. I appreciate your thoughtful rating of this answer.
Jan 29, 2007 | GE JES1231 Microwave Oven
VillaWare 3900 Krumkake Baker Logo
164 people viewed this question
Top VillaWare Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
Michael Vincent Cruz
Angel Joseph Jr.
Angel Joseph Jr.
Are you a VillaWare Kitchen Appliances - Other Expert? Answer questions, earn points and help others
