Question about Kenmore 24 in. 16293 Built-in Dishwasher
My kenmore 665.1629 dishwasher
Hello
here's the problem - i started the cycle today as per usual. came back and there is no power and water in the bottom of the machine. main fusebox is fine - any ideas?
  • 413 Answers
There may be a thermal fuse located on the electronic control board housing that may have failed.This replaceable part (gray or white) is clipped on to the side of the housing.
Posted on Jun 27, 2008
Kid 60 s10 please give fault codes
Hi Roger, Hope this helps......CHEERS..
KENMORE DISHWASHER ERROR CODES
Kenmore Dishwasher Error Code = Start Resume light blinking slow
When the dishwasher door opens or electrical power is removed during the cycle then the dishwasher will not start again. The door is detected as being closed and the Start Resume button is being pressed
Kenmore Dishwasher Error Code = Clean light is blinking 7 times
Heater circuit fail. Control panel did not detect the water getting hot. Did not detect heating element was energized to heat the water during the wash cycle
Kenmore Dishwasher Error Code = Sanitize LED blinking at end of cycle
Control panel could not detect if sanitation has been achieved
Kenmore Dishwasher Error Code = Console light blinking rapidly
There is a stuck button on the control panel
Kenmore Dishwasher Error Code = Clean light is constantly illuminated
Dishwasher cannot start a wash cycle until it sees that the door has been opened after the previous washing cycle
Kenmore Dishwasher Error Code = Control lock LED is ON but not responding to pressing of the keys
Turned on by accident or there is a control detected key pad problem
Mar 31, 2016 | Kenmore Dishwashers
My frigidaire professional series dishwasher has no power
Hello qmainous - The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may also prevent the unit to start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Nov 16, 2012 | Frigidaire Dishwashers
Fridgedaire dishwasher will not start a cycle. The green "clean: light stays lighted up and it will not reset the system. I have to turn off the breaker and then turn it back on. then the...
Hello
Ensure the Frigidaire dishwashing machine is fully connected to a power supply. Shut the dishwasher door firmly and select a wash cycle. Press "Start" to begin. Check that the "delay start" option was not selected.
  • 2 Verify that dishwashing detergent is placed in the dispenser and choose a longer washing cycle for heavily soiled items. Do not overload the dishwasher, as this may prevent proper cleaning.
  • 3 Check the household water pressure, which should be between 20 and 120 PSI (pounds per square inch). A water pressure gauge can be obtained at most home repair stores or hardware stores.
  • 4 Turn on the hot water at the sink closest to the dishwasher prior to starting the dishwasher to raise the water temperature inside the dishwasher. Check the hot water temperature, which should be at least 120 degrees Fahrenheit for proper cleaning.
  • 5 Check the spray arms in the dishwasher and move dishes that may be blocking the water spray or preventing the spray arms from rotating properly.
  • Read more: Frigidaire Dishwasher Wash Cycle is Not Working ' eHow.com http://www.ehow.com/how_7877923_frigidaire-wash-cycle-not-working.html#ixzz1Xow3qbbv
    Sep 13, 2011 | Dishwashers
    My kenmore dishwasher wont start at all now. It used to start if you pushed certain buttons a bunch of times but now the lights next to most of the buttons light up but it wont start a cycle. any ideas?
    Hello
    Ensure that the dishwasher is connected to a working power supply. Check the local fuse or circuit breaker and restart as necessary.
    Open and shut the door firmly until it latches into place. The dishwasher will not function if the door is not latched into position.
    Select the desired cycle and press the cycle button firmly, as you must choose a cycle in order for the dishwasher to begin operation.
    Look at the water valve that is connected to the dishwasher and ensure it is turned on.
    Turn off the dishwasher and unplug it from the power supply to reset the unit. Plug it back in and select a new cycle. Select "Start." If the dishwasher still does not start, contact an authorized service technician.
    Sep 11, 2011 | Kenmore Dishwashers
    665-110733490 Was working fine ,last night shut it off w/water in the bottom.also pushed cancel/drain did not drain.today I ran A wash cycle but after wash still had same amount water in...
    Hello & Welcome to FixYa
    Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose-filter assembly or the drain pump not working. First try to clean the drain hose and drain pump filter located inside the front bottom panel for any clogs, then check drain pump operation. Take off the bottom access panel to clean the drain pump filter and hose. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
    Kevin
    Jun 09, 2011 | Kenmore Dishwashers
    My kenmore diswasher model#363.153221100 when i start the wash cycle starts to fill up with water but then drains the water back out immediately and the wash cycle never starts.
    This problem is caused when the motor goes bad and needs replacement. The control will fill water and then sends signal to the motor to start a cycle, if it won't work then it will drain the water and so won't start the cycle. However, it can also be a bad door latch-lock assembly as if the control senses that the door is not closed it won't start the cycle. If you hear any humming buzzing sound from the bottom of the unit then replace the motor if not then replace the latch assembly. Please get back to me if you have any other questions.
    Kevin
    Mar 15, 2011 | Kenmore Dishwashers
    My dishwasher is seeming to stay on the wash cycle. How long is a normal wash cycle?
    Dishwashers today use a lot less water and energy to do this they filter the water like crazy this makes the wash times go way up, the motor used today uses only a little power so a long cycle does not cost much.
    They average wash time for a new machine is 90 - 120 minutes. Some high efficiency units can run 4 hours per cycle.
    Apr 24, 2010 | Kenmore Dishwashers
    Hot water for dishwasher
    Hi thanks for the question. before you start your dishwasher turn on the hot water tap at sinc let the water get hot . then start the dishwasher it will be hot enough for the rest of the cycle. thanks the appliance doc
    Oct 06, 2008 | Dishwashers
    Dishwasher not working again
    is the clean light blinking, if so make sure water temp is at least 120 degrees
    Jan 02, 2008 | Kenmore 24 in. 15933 Built-in Dishwasher
    Kenmore 24 in. 16293 Built-in Dishwasher Logo
    142 people viewed this question
    Top Kenmore Dishwashers Experts
    Ken Johnston
    Ken Johnston
    Level 1 Expert
    Fred Sops
    vince
    Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
