Question about SVP Xthinn 570 Digital Camera
Sd card what brand sd card can I use?
Any Brand
Posted on Jul 20, 2008
What is the proper SD card for a Kodak Z740
The Z740 works with any SD card, 2GB or smaller. Just make sure you use an SD card, not a higher-capacity SDHC or SDXC card. The brand doesn't really matter, though personally I'd stick with the major brands.
Aug 09, 2014 | Kodak Cameras
WHAT TYPE OF SD CARD DO I USE
The DV179 uses SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards. You can use any brand and speed SD card, though personally I'd stick with the major brands.
May 06, 2013 | Jazz DV-179 Digital Camera
What kind of sd card goes into my jazz DV140 camera
SD cards should be available at just about any department, electronics, or office-supply store. The brand doesn't matter, though I'd stick with the major brands. Make sure you get an SD card and not an SDHC card.
Apr 29, 2013 | Jazz Dv140 5mp Digital Camcorder Color Lcd...
WHAT IS THE BEST MEMORY CARD FOR THE z760 CAMERA
The Z760 works with MMC and SD cards. MMC cards are all but extinct, and samples will likely cost more. MMC and SD cards max out at 2GB, so make sure you get one no larger than 2GB. SDHC cards start at 2GB but won't work in the Z760.
You can use any speed and brand of SD card, but personally I'd go with one of the major brands.
Dec 07, 2012 | Kodak EasyShare Z760 Digital Camera
Need make model of sd card for vivitar vivcam 3188
It is compatible with any brand of SD card up to 1 Gb size. To look at the brand/model of your SD card, open your camera, remove the SD card and check the labels. It doesn't have it's own brand of SD card, so depending where you bought it, the store can just put any brand of SD card into it.
Jul 11, 2011 | Vivitar ViviCam 35 Digital Camera
The SD card from my Olympus camera does not fit into my new ViviCam 5022. Does it have to be a certain brand of SD card?
Is it actually an SD card? The Vivicam 5022 accepts SD cards up to 8GB (which means SDHC as well), but many Olympus cameras use an XD card, which is quite different. SD and SDHC cards are all the same for fit, regardless of brand.
Nov 22, 2010 | Vivitar ViviCam 5022 Digital Camera
DSI not recognising SD card
Can you use that SD card for your photo digital camera or any other device such as card reader ,so you can check quality of that SD card?
Also check brand of that card. In many cases consoles such as playstations, nintendos , have their own brand memory cards, so if your card works on other devices but not on your DSI , you probably need to use their brand.
Sincerely
Aleksandar Adzic
Apr 16, 2010 | Nintendo Game Boy Advance SP Console
Card Error
please check the following: Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba Sora PDR-T20 Digital Camera
Card Error message
1. Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. 2. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. 3. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. 4. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
Card Error Message
1. Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. 2. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. 3. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. 4. The Toshiba PDR-3310 is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. The PDR-3310 may work with some MultiMedia Cards, but is not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
SVP Xthinn 570 Digital Camera Logo
29 people viewed this question
Top SVP Cameras Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Are you a SVP Camera Expert? Answer questions, earn points and help others
