My cd player stopped working and then i reset it now it works and my subwoofers worked at first and then the next day they stopped? i put the wires back in and switched them around but it didnt do anything.
    President:
  • 624 Answers
Make sure the sub-woofer is selected and turned on from the receiver. Most receivers have a setting for the sub-woofer, and if you did a reset, the factory setting may be set to off.
Is this receiver a car receiver or for the home?
What model and make is it?
I can help you further if you need it, but those are two questions I would need an answer to, so I can understand the problem a little better and figure out how to turn the sub on. It is not the same for every receiver.
Dave
Posted on Jun 27, 2008
My CD Player for a [Compaq] Presario V3000 hasn't been working. It worked fine less than a year ago, then it stopped working. My Computer doesn't show the CD icon any longer, not even Device Manager seems...
It will cost about $30 to buy a brand-new CD/DVD reader/writer.
Any computer-store technician can easily "manually" open your current drive, and remove the CD/DVD media.
Dec 14, 2010 | Compaq (120192-B21) CD-ROM Drive
The woofer wont turn off
The only wires that should be going to the subs are the Speaker wire, The power, goes to the amp, Blue the remote wire should only go to the remote spot on the amp wich is usually labeled rem. and the ground all goes to the amp.
Nov 19, 2009 | Vibe CBR10 Car Subwoofer
Digital Clock and cd player not working
it sounds like you have a bad connection either in the wiring or inside the deck itself. check the wiring for any loose connections or breaks in the wire.
Aug 19, 2009 | Car Audio & Video
CD Player does not play CDs
try getting an aftermarket cd player and see if it does the same thing as well
May 06, 2009 | Car Audio & Video
CD player doesn't work...
most cd players have a reset button underneath the faceplate. try hitting that and see what happens.
Mar 30, 2009 | 2003 Toyota RAV4
Subs won't turn on
Hi Neo_69
i would love and try to help you. ok so your having a problem with your subwoofers when you put a cd in. well try to change the output of speakers to work when you put a cd in it should be on the car radio and also you can try reseting the car radio there should be a little button to reset it. If you need more help or this does really answer youe question let me know. Thanks
Dec 23, 2008 | Kenwood KDC-MP438U Car CD/ MP3 Player
Subwoofer in my car works only on tuner
I had the same problem. most radios have a power antenna wire and an amp turn on wire it sounds like your amps are being turned on by the power ant wire that loses power when you put a cd in try swapping the blue with blue and white wire this should solve it
Nov 19, 2008 | Sony CDX-GT300 CD Player
Troubleshooting in car cd player
that is very strange but it could be that when you put the cd in the radio it maybe sending out a quick shot of amplified power I would try disconecting the subs put in a cd let it play a little then plug the subs in while the cd is playing and see if they work if this works you may to get a new radio or put in a switch to turn the subs off or some type of momentary circuit breaker I'm just trying to help I never saw anything like that before good luck........
Nov 06, 2008 | Sony Xplod CD Player w/MP3 Playback...
Clarion dxz665mp cd player
I think you connect the wrong remote wire to the subwoofer amp.
This cd player it has 2 blue remote wires,one is for PWR ANTENNA (BLUE ONLY),when you insert the cd,this wire cut out the pwr,so,is when your subwoofers stop working.
The other blue wire is the REMOTE (BLUE W/WHITE) Wire,this is the one you need to connect to the Amplifier.
Let me know if work
Thank you
Jul 27, 2008 | Clarion DXZ665MP CD Player
No sub when listening to a cd
you're using the wrong remote output wire. You have it hooked to the power ANTenna wire (blue) which turns off when not using the tuner. You need to use the REM OUT wire (blue w/ white stripe).
Oct 14, 2007 | Sony CDX-M630 CD Player
 Grubhead
Grubhead
