Question about Kenmore Washing Machines
Need to change the lid switch on a kenmore series 90 top load washer
  • 413 Answers
To access the lid switch, REMOVE POWER, lift the console by one of three ways.
1. Look in the back of the console, in each corner there will be a screw, unscrew until the console can be pushed forward.
2. The trim on either side can be pried off from the top, grasp and pull forward to expose to expose a screw.
3. insert a putty knife under each corner, push to release a latch. With console lifted:
1. You will find a lid switch connector (white in color). Unplug the switch from the connector.
2. There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
Posted on Jun 27, 2008
My kenmore 90 series washer will not drain i have tried playing with the lid leaver any thing else i can do ,can i replace the leaver switch?
Yes you can replace the lid switch its fairly easy to do...this tip i wrote will help ya to replace the lid switch http://www.fixya.com/support/r9939128-whirlpool_kenmore_estate_kitchen_aid
Series 90 is unfortunitly not a model number please reply with exact model number as found on a label on the rim of the tub inside of the lid and i will give you the part number for the lid switch.
GENE
Sep 12, 2011 | Kenmore 24032\24036 Top Load Washer
I HAVE A KENMORE 90 SERIES WASHER JUST REPLACED
it mounts to the metal where the lid closes, not on the drum... there's usually two holes where the screws go through... and a third hole where the actuator(plastic post) on the lid goes through to activate the lid switch...
Sep 25, 2009 | Kenmore 24032\24036 Top Load Washer
Won't spin or rinse, took clothes out .... too heavy maybe??
you have a bad lid switch,you can by pass it,remove the switch,put the pos.neg. together with wire nut and your finished-mike
May 20, 2009 | Kenmore 23822 Top Load Washer
Kenmore 90 Series Washer
CHANGE THE LID SWITCH
Apr 18, 2009 | Washing Machines
Washer will wash and drain but not spin
Sounds like the lid switch is not working.It is a safety feature to prevent the washer from spinning if the lid is open.If you look a the lid,you will see a small point that sticks out,The switch is locate under the rim,right where that point would contact with lid closed.
Jan 11, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore Washer Model 100, 90 series fills and agitates but
most common solution is to replace the lid switch. (the machine thinks the lid is still open)
Dec 26, 2008 | Kenmore 23822 Top Load Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Dec 17, 2008 | Kenmore 23822 Top Load Washer
My washing machine water wont drain,it is a kenmore 90 series.
  • first thing to check is the lid switch.
  • if the lid switch is bad it will fill up, then agitate then sit there full of water.
Jul 05, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
140 people viewed this question
Sal De
fordexpert
Robert Rankin
