Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony TV The colors slowly fade in and out as we watch it. Sometimes it looks like alternating color bands and b & w bands waving through the set.
  • 58 Answers
What are you using as a source of video.
cable, cable box. satellite. dvd. or?
thanks Guy9
Posted on Jul 12, 2008
Bought mickey watch at disney resort in June. Color on watch band is fading. Is there a number I can call to discuss repairs?
hi, try calling the resort and tell them the issue- they should contact vendor--gold plated so it wont last-- was it under 30 bucks?
Aug 13, 2014 | Watches
The screen looks faded. The colors are right, but
take off the front of the set, and clean the lens as well as the mirrors inside the tv set
Techman
Dec 14, 2009 | Sony KP-53XBR200 53" Rear Projection...
My screen turns green and then turns off
you need to adjust the screen voltage. behind the front grille and inside cover. a small black box 6 adjusters protruding from it. only adjust the the color counterclockwise that matches the problem in this case it's the green so look for the knob with "G" marked by it. there are 2 with "g" marked by them the row across the top of the box are for focus don't adjust. back the knob off untill the raster is blank with your input set to an inactive input, the picture should be blank and black.
when it is you have the adjuster close to where it should be, now change the input to an active signal and turn the color off so that you wil have black and white picture. adjust that knob untill you do have a truely black and white picture not too green or red or blue. go back to inactive video input and check that there are no lines of any color on the screen. repeat if needed. always adjust these knobs slowly the set will be watching you ! if your autofocus won't work now you have the adjustment set too low. check this function before putting back together again. these adjustments can be real touchy so be patient
Feb 20, 2009 | Sony KP-57HW40 57" Rear Projection...
Seeing red !
I had a television that went to a bright shade of blue.A friends neighbor worked for sony television plant where the new tubes came down the assembly line.His job was to make sure tubes were working fine,if one color was dominant then his job was to smack the front center of the tube with a rubber mallot to fix the problem.He suggested i try that with my tube while the set was on.It worked and solved my blue problem.Apparently he explained,the gun connections in the tube came loose and to fix it was to smack it this caused the connection to reweld itself.For you I would use the palm of an open hand and smack the tube dead center with a good hard smack.Dont be afraid of breaking the glass because its very thick and strong.Give this a try.Hope it helps.Good luck!
Oct 31, 2008 | RCA F25442 25" TV
Color fading on Sony could be cable ?
have the cable company come out and check there cable box and picture.
Jan 28, 2008 | Sony KV-27V22 TV
Have no red color and the other colors seem to be fading on my sony KV36FS13
in that tv you have surely the color circuit trouble - if you can you have to check  the red color circuit , first transistors then voltage or a capacitor not functioning ,
I HOPE THIS MAY HELP YOU - DELFO
Jan 19, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
JVC I'Art Pro, Color Fade
sounds like two separate problems. color fade ?
green gun/band = bad convergence ic
Dec 18, 2007 | JVC AV-56WP30 56" Rear Projection...
Visible bands moving up the TV
The bands are caused by unsheilded power cables that are near the
set. sometimes your tv cable or antenae cable is near a power
source and it is picking up unsheilded EM signals. Remove all
power sources near your tv and tv cable.
Nov 09, 2007 | Toshiba 62HMX84 62" Rear Projection HDTV
Toshiba 65hx81 65" Rear Projection tv. black & white color/green
Yep, your problem is a relatively easy one to repair if you know how to solder. You better repair it before it blows the fuse though. There are two capacitors in the main power supply that are coming loose and need to be re soldered. There is a Toshiba service bulletin about it. They are marked C809 and C810 on the main power supply board. Good Luck
Sep 05, 2007 | Toshiba 65HX81 65" Rear Projection...
Color fades in and out of picture
The first thing I would check is the antenna or cable connection into the set. When an analog TV signal is weak, the first thing to go is the color, then the picture, then the sound. If you have another TV, connect it to the very same cable or antenna connection and see if it fails the same way, too. Make sure you just disconnect the cable end right where it goes into the failing TV and connect it to the other TV - don't disconnect the antenna cable from the wall for this check. If the second set does not fail, gently pull on the antenna wire - not too hard, you just want to put a little tension on it to see if it makes the color cut out. Reconnect the first one and try again. If it's fine now, the connection was loose. If not, it has a tuner problem that must be repaired. Also, when you look at the end of a TV connector, the center wire should stick out just a little bit, like in the attached photo. If it doesn't stick out as bit, it won't make good contact, and will result in a weak signal. I appreciate your rating if you find this helpful.
Nov 13, 2006 | Philips 27PT643R 27" TV
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
238 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
