Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Kv27fS100 - LED BLINKS 15/16 TIMES FIRST AND THEN 2 TIMES CONTINUOUSLY
Hello everyone
My Trinitron doesn't start. After I turn power on, LED blinks 15/16 times and then it blinks twice .. Any ideas as to where can i start troubleshooting this?
Thanks,
BG
  • 1 more comment
  • k29ska9 Jun 27, 2008
    Hi Dan
    Thanks for the insight. I am new to TV troubleshooting but i don't mind challenges.
    I was planning to open up TV. I read on several another forums that D board - very expensive part - is where problems are seen. Is this o/p transistor on that board? Any pointers as to which board / location of transistor that i need to check. Also what tools do i need to check - which indicates i would need help with how to check.
    Thanks for your patience and help.
    regards,
    BG
    Finally found a service manual. It says to check following:
    H.OUT (Q502) is shorted. (A Board)
    IC702 is shorted. (C Board)
    I was able to locate IC702 on C board but Q502 looks ugly. How do i check IC702 for a short? Do i need a multimeter or do I need something else?
    I was able to locate IC702 on C board but Q502 looks ugly. How do i check IC702 for a short? I think i need multimeter. Is that correct or do I need something else?
Same model TV and SAME problem - 2 blinks. After reviewing the service manual, here is what ive come up with:
2 parts listed as defective.
Q502 on the A Board. (a transistor, part# 2SD2634 online for $2.39)
IC702 on the C Board. (integrated circuit, part # TDA6108JF online for $3.29)
Both Parts - www.acme-sales.net
Service Manual - Free Download ( you have to download all four parts before extracting - http://www.eserviceinfo.com/downloadsm/27543/Sony_KV-27FS100,%20KV-27FS200,%20KV-29FS100.html
Has anyone tried replacing one or both of these parts and if so how did it turn out?
Posted on Jul 29, 2008
  • 4,234 Answers
The initial blinking is normal. The two blinks are the key and indicate an over current condition detected. This can be a problem in any of the circuits. Since the set initially performs as expected and the blinks show up after a little while suggests that the problem is in the high voltage circuit. If you are comfortable working inside the set, check the horizontal output transistor for a shorted condition. That is the most common failure. If you must see a servicer, expect a parts cost in the $25 range. Add in the local labor rate for the total repair cost.
Dan
Posted on Jun 27, 2008
  • ABRsvcs Jun 27, 2008
    I don't have the service manual right on front of me at the moment, so I'm doing this from memory and experience. I'll look up the model and post more details. Stay tuned...
    Dan
Sony kv27fs100
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Sep 09, 2015 | Sony FD Trinitron WEGA KV-27FS100 27" TV
My Sony Trinitron televison, model number KV27FS100, does not have a picture anymore. There is a flashing red light at the timer that flashes 5 times and then repeats this sequence of 5 flashes again and...
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Aug 20, 2011 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony trinitron 36" has 7 red blinks wont turn on
I HAVE A SONY TRINITRON KV-36HS510. IM HAVING A PROBLEM,ITS NOT SHOWING A PIC, AND BLINKING 7 TIMES THEN PAUSE FOR A COUPLE OF SECONDS THEN IT WILL BLINK 7 MORE TIMES,I CAN HEAR AUDIO BUT CANNOT SEE PIC. COULD YOU PLEASE HELP ME OUT ,I'VE TRIED CUTTING THE TV OFF FOR ABOUT 6 HOURS AND CUTTING IT BACK ON,SAME RESULTS, THANKS
Jan 02, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
The led light blinks continuously and tv will not turn on
With the led blinking continuously it's probably a power supply problem. Unless you're a tech there's not much you could do other than unplug the power chord for a little while and plug it back in to see if there is a difference. If not you'll need a qualified tech.
Sep 11, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
Jun 21, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony FD Trinitron WEGA KV-30XBR910 30" TV Led flashing
6 blinks meens no horizontal and no raster check capasitor c515/c516/ jungle IC and IC206.
regards,
daniel.
Dec 28, 2008 | Sony FD Trinitron WEGA KV-30XBR910 30" TV
KV-27FS120 blinks 2 times continuously...
This is not for a DIY're.
It is possible that the flyback transformer and the horizontal output transistor have failed. Also there may be damage in the power supply when these components fail.
When troubleshooting, it is important that the tech locate the cause of the fault and also change the related components.
After the parts are changed, the power supply and the high voltage setups must be done to make sure that the voltages are in specs.
This type of work must be done by an experienced TV tech. He will have the necessary test equipment, tools, service manuals, and training. There are some very serious safety issues when working in a TV set.
Jerry G.
Jun 19, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
My sony 27 Trinitron KV27FS100 has a great picture but no sound
HELLO. SOUND'S LIKE U HAVE A BAD SOUND BOARD.!!! U CAN HOOK UP TO A HOME STEREO AND GO THROUGH IT FOR YOUR SOUND.!!! GOOD LUCK!!! LET KNOW IF THIS HELP'S YOU.
Jun 05, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
566 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
