Question about Sony Grand WEGA KF42WE610 42" Rear Projection HDTV-Ready Television
Lamp replacement How do I replace the lamp. No instructions came with the new lamp and none are in the manual. I apparently also need to reset the lamp life timer. need instructions to replace lamp block myself
  • golf19 Jun 28, 2008
    Thank you very much. That was an easy 10 minute fix.
    President:
  • 2,712 Answers
There's no procedure to reset the lamp timer. But there is a procedure that resets the results of the Self-Diagnosis Function, hopefully, this may reset the lamp timer:
With the TV OFF...press:
DISPLAY --> Channel 5 --> VOL(-) --> TV Power
Channel 8 --> ENTER
Wait until you see the initial setup display. Then disconnect the power cord and reconnect it.
Posted on Jun 27, 2008
  • Swilin Sampson
    Swilin Sampson Jun 27, 2008
    OK, here's a procedure I found for resetting the counter that may work:
    Accessing the service menu could render your TV non-functional if you
    make incorrect entries, so it should only be done with extreme caution!
    Procedure
    1.
    To access the service menu, with the TV off, press the following
    buttons on the remote control sequentially in rapid succession (note:
    if the TV is already on, you can start by turning the power off, but
    then you should enter the full 4-button sequence within about 3 seconds
    to avoid a lamp restart):
    <5>
    2. Press until the PANEL service menu displays.
    3. Press <2> until the OPTION_E category appears.
    4.
    The "LampTM" (lamp power-on time in hours) and "LampCT" (lamp on/off
    cycles) entries are in the first item in the OPTION_E category. If they
    are not displayed, press <1> repeatedly until they do.
    The display should look as follows:
    PANEL NVM OK 9 OPTION_E
    0 LAMP 0 Diff 1
    LampTM #### LampCT ####
    To reset these counters, press <3> .
    "WRI-EXE" should be displayed momentarily in red text, followed by resetting to “0”.
    5. To display the PanelTM (total LCD panel power-on time) entry, press <1> until it displays.
    7 SH SFT1 10 Diff 1
    PanelTM ####
    6.
    When done, exit the service menu by turning off the TV (note: you can
    turn the TV back on immediately, but you should do so within about 3
    seconds to avoid a lamp restart.
    Guru:
  • 1,894 Answers
Are you experienced in electronics first?
with out proper knowledge of electronics it is too risky to do it by yourself.
  • 2 more comments
  • dewan nafees ahmed Jun 27, 2008
    The bottom panel in the front of the tv pops off similar to a car door
    cover. Careful it feels screwed but its not. There should be a door
    just left of center on the tv that has a plastic thumb screw. Undo the
    screw and that door should swing open and be able to be removed. There
    are 2 allen screws (the new bulb should have come with a wrench) remove
    the screws and the entire bulb assembly pulls out, reverse the steps
    and your in business. After your done if the tv will not stay turned on
    the door for the light bulb is not closed correctly the door has a
    sensor.
    source:blurtit.com
    Here are the typical steps for replacing a lamp.
    1. Turn your TV off. Let it sit there for about 5 minutes to let the cooling fan help cool the lamp.
    2. Unplug
      your TV from the power let it sit about another 30 minutes. Even with
      the TV turned off power is still going to the lamp and the lamp
      receptacle can still be hot enough to burn you. Even if you think that
      the lamp is cool I recommend that you do not touch the receptacle.
    3. Usually
      the lamp has a cover that you will need to unscrew. Most manufactures
      use a Philips head screw for holding the cover shut. Unscrew the lamp
      cover.
    4. Unpackage the replacement lamp. Be careful not to tough the glass, as oil from your fingers can damage the lamp's surface.
    5. Pull
      the lamp out. Most lamps have a plastic tab or hoop on the handle that
      you can use to pull it out. Follow the owners manual for specific
      instructions on how to pull the lamp out. Make sure you do not touch
      the surrounding lamp housing if you just turned off the TV. It can burn
      you if it is hot.
    6. After the lamp has cooled, place it into the empty box of the replacement lamp. Never put the used lamp into a plastic bag.
    7. Using
      the guiding post also called "gutters" by some manufactures slide the
      lamp replacement lamp in pushing it until you hear a firm click.
    8. Screw the lamp cover back in.
    source:dlptvreview.com
    If you replace the lamp and need to reset the Lamp Timer Reset procedure is:
    With The Set In Standby Press Display, 5, Vol Up, Power on the remote control
    Press Jump 3. Or,
    To Display The Lamp Time Press 2 Nine Times.
    To
    Reset Press 3, Mute, Enter. One of these should work on your model.
    Make sure you replace the bulb first. There is a possibility that the
    ballast could be damaged by a defective bulb as well.
    source:fixya expert henlopen
    hope it helps.
    thank you
    dont forget to accept MY solution if u go by it.
    feel free for asking any doubts u have.
    thank u for ur cooperation.
    good luck for getting fixed soon
Message on screen says lamp needs to be replaced then timer reset. Need lamp and instructions to reset timer
The lamp time reset will be or should be in the owner manual---Google the model number with keywords "lamp install" with the model number and the "manual" with the model number---Google can be a great help.
Nov 01, 2012 | JVC Lamp W/ Housing For Hd-52g786 /...
I replaced the lamp and it still indicates that the lamp needs to be replaced
The lamp timer must be reset and so this will reset the processor to switch on the lamp.Please follow instruction on the manual, open main menu and proceed as directed.
Dec 17, 2011 | Sanyo PLV-Z4 Multimedia Projectors
How to reset lamp timer on pt 50L C-13
Their manual says:
After lamp replacement, you must reset the lamp
time. Refer to the instructions enclosed with the
lamp unit (Part No.: TY-LA2005).
lamp unit (Part No.: TY-LA2005)."
http://www2.panasonic.com/consumer-electronics/support/Televisions/LCD-Projection-TVs/model.PT-50LC13
Aug 09, 2010 | Panasonic PT-50LC13 50" Rear Projection...
I JUST REPLACE MY LAMP IN MY SONY KDS-55A2000 HOW DO I RESET THE LAMP HOURS..TV IS STILL READING PROJECTION LAMP NEARING LIFE END
you need to go into the TV's menu and select replace projection lamp menu and follow the on screen instructions to verify and reset the lamp timer, (its in your instruction manual , in detail) , i am awaiting a new phillips bulb for mine, as i always use the original enclosure, no need for extra plastic, and its easy to complete the swap, and reset hours via TV menu
Aug 03, 2010 | Sony KDS55A2000 55" HDTV
Lamp is not coming on. It was replaced recently Benq 8720
Check in your instruction Manual about pressing a button sequence while starting up. Some projectors do not actually know when you have changed the lamp, so you have to reset the lamp timer by pressing a button sequence. Often a genuine replacement lamp will have an instruction set which comes with the new lamp ( If you still have it !! :) You may have replaced the lamp but not reset the counter and it has shutdown because the counter has reached a critical umber of hours.
Jan 02, 2010 | BenQ Office Equipment & Supplies
Panasonic LCD Lamp Replacement
Here is the manual for your set, the instructions for replacing the lamp are on pages 66-67.
You can download the manual here.
http://www2.panasonic.com/consumer-electronics/support/Televisions/LCD-Projection-TVs/model.PT-61LCX65
To reset the lamp timer
For the full instructions and how to reset the lamp timer go to the following site
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Aug 21, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Projection lamp nearing end of life replace lamp still coming on
Along with the instructions for the lamp installation, you should have revceived instructions on how to reset the lamp counter. If not, this operation is listed in the owner's manual. If you can not locate that manual, please confirm your model number and I will post the instructions. Since the counter has not been reset, the TV will continue to show the "error" message.
Dan
Mar 09, 2009 | Sony KDF46E2000 46" Projection HDTV
Infocus Lp240 Projector Will not power on NEW BULB. Red light Blinks on and off.
The owner's manual should have a troubleshooting chart that will indicate what the blinking lights mean. If the new bulb did not clear it, the problem may be the ballast (part that starts the bulb). Also, when you replaced the lamp, you should also reset the lamp timer. Some units will continue to indicate a lamp needing replacement until the counter is reset. The procedure for that should also be in the manual.
Keep us posted.
Dan
Dec 18, 2008 | InFocus LP290 1100 Lumen XGA LCD Projector...
Lamp replacement
The file is too large to post here but if you post your email address, I can send you the step by step instructions to replace the lamp and reset the lamp hour counter.
Mar 01, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Sony Grand WEGA KF42WE610 42" Rear Projection HDTV-Ready Television Logo
246 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
