Question about Samsung HLN4365W 43" Rear Projection HDTV-Ready Television
HLN4365W Start-up Issue
Recently my HLN4365W DLP set has begun to take a long time (2+ minutes) to start-up. The set first goes through the normal start-up sequence where the green light blinks and the color wheel starts; but then after approximately 60 to 90s, the set appears to shut down for a few seconds and then begins the start-up sequence again. After this second start-up sequence, the set usually powers up and operates normally, but this behavior seems to mean the set is about to fail completely. Everything on this set is original, meaning no components have ever been replaced. Do you know what is causing this behavior?
  • hootgood Oct 11, 2008
    Appears to be an air flow issue, affecting some sort of switching for the lamp to come on with ventilation.
  • usa2be4me Nov 16, 2008
    When I turn my set on, you see the blinking lights and it acts as if it will start, then it shuts off. If I unplug it for 30 seconds then plug it in and hit the on button, it will come on again and work fine until I turn it off, then fail again when I turn it on. I just replaced the bulb and it is doing it again. Please help!
The problem was due to a failed bulb; the bulb was replaced and everything is working properly.
Posted on Nov 04, 2008
  • 2,920 Answers
The main power supply may be getting weak. if so it will delay the time it takes it to come on and eventually it wont come on at all
Posted on Nov 03, 2008
Samsung 61
If using a cable or sat box try a DVD etc when set cold, a box can cause lockup issues via signal.
Not a color wheel is correct, more likely a DMD which is rather pricy and almost as much as the entire light engine which comes with it.
Oct 12, 2012 | Samsung HLP6163W 61" Rear Projection...
I have a 43 inch samsung DLP tv 2004 model# HLN4365W, I was getting a black and white picture, so i replaced the color wheel which was broken. It worked fine for a couple of days then there was no picture,...
No picture on a DLP when you can see the lamp is working is ALWAYS the DLP chip. BECAUSE you recently replaced the color wheel, i suspect that the LVDS/data cable to the light engine was not plugged in well and has come loose. I suggest checking and rechecking every cable and plug you can find.
Aug 09, 2012 | Samsung HLN4365W 43" Rear Projection...
The sound comes from the color wheel and not a fan,common to samsung dlp tv's which can be the cause of the shut down.
Mar 22, 2010 | Samsung HLN4365W 43" Rear Projection...
Samsung DLP Facial Colors off after changing color wheel
Do you mean that red and blue are reversed? If so, you may need to remove a jumper, see end of linked article. Pinkish-yellow or orange sounds like a good description of skin tone, but perhaps too intense. If the color is too intense, can you just lower the color level with the color control? Or can you just change the tint with the tint control? Otherwise, see including the comments at the end.
Oct 11, 2009 | Samsung HLN4365W 43" Rear Projection...
1997 VR6 Jetta won't start intermittently on hot days.
Just a thought , maybe change your fuel cap. may not be regulating tank pressure properly.
Jul 27, 2009 | 1998 Volkswagen Jetta
Samsung HLN4365W picture not centered
turn the tv off, hit mute 1 8 2 power, the tv will come on in the service menue, look in that menue for vertival and horizontal adjust, after you adjust it, just turn the tv back off, it will save your changes
Jan 07, 2009 | Samsung HLN4365W 43" Rear Projection...
Samsung hln4365w - no pic. or sound. it whistles a few times when powered on
We have the same DLP set and had the same problem. The Color Wheel, P/N BP96-00250A, a $200 part needs replacement to eliminate your problem.
May 24, 2008 | Samsung HLN4365W 43" Rear Projection...
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Mar 14, 2008 | Samsung HLN4365W 43" Rear Projection...
Right 2 inches on edge of screen are darker than the rest of the screen
What is the model of the TV? Samsung DLP TV's start with HLS,HLP,HLW.....
Feb 06, 2007 | Samsung TX-R3080WH 30" TV
Samsung HLN4365W 43" Rear Projection HDTV-Ready Television Logo
135 people viewed this question
Jerry Greenberg
Jerry Greenberg
