I have a Promac 15000 btu (4 years old), indoor unit (wall unit), model ps150cri. When I turned it on for the first time this year, some water keep on coming out from it inside the house. What might be the problem . Thank you!
I have the same model and have had the same problem. It has happened to me a couple of times. Once was when I turned it on after it was very humid, and the water condenses so fast it won't drain fast enough and over spills. The other time I had a problem was when it was left in "auto" mode overnight (again when it was very humid), but the fan was very slow (silent). Ice formed on the condenser and when I woke up and put it on "normal", the warm air blown over the condenser (ice) caused the ice to melt rapidly (again too much water to pass through the drain).
Posted on Aug 01, 2012
  • fuhrmanator_
    fuhrmanator_ Aug 01, 2012
  • 4 Answers
You may have a blocked drain or the filters may need cleaning..
pull the filters out of unit and clean with water.
check if the drain is working you can do this by pouring water into the drain tray if the water does not drain away the drain is blocked.
Posted on Jun 27, 2008
Where can i get parts for the promac ps120 cr1
My air conditionner wall units stop after 20 minutes and the light on the unit flash. the air dock is normal and we also clean the plower. I wonder if it is normal. Last year it was not like this.
Jul 26, 2013 | Promac Heating & Cooling
My 9 year old 17,500 BTU wall mounted window Unit is freezing over with little air coming out. New filter & clean coils still have same problem.
Sounds as though the indoor fan is about to give up the ghost.. 2 choices . 1 start looking for a newer more effecent unit. 2 replace the fan motor.. sorry but it does not sound good..Wiat I just thought It just might have a run capasitor ?? Not sure.. But it could be going bad as well .. Justa thought on that one. either way you can call a tech or buy a new unit.
Aug 08, 2011 | Friedrich Heating & Cooling
Hi, have a split system 10 years old, unit on wall has one green light flashing 5 times and repeats. Patrick
E5 Communication error between outdoor and indoor
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Helpful?
Jan 01, 2011 | Mitsubishi Heating & Cooling
Rheem 266K to 399K BTU Swimming Pool Natural Gas Heater keeps failing and giving me a ROL and SPR code. The thing is a little over a year old and only been used 1x last winter (we live in Florida). Cannot...
ROL code means Rollout.
This heater used a one time use switch in the cabinet on the left hand side.
The switch will look like a ceramic oval disk about 1.5" in diameter. It will have two wires coming from it.
This switch is one time use because it mean your heater is getting a bad burn. This could be happening due to:
1. High wind situation (could be random)
2. Incorrect gas supply
3. Incorrect venting (if indoor)
4. Obstruction on top of the burner tray.
There was a recall on the refractory kit with some of these models, causing the fire walls to crack off and fall on top of the burner tray. Thus causing the flames to rise too high inside the cabinet and therefor trip the rollout switch. The timeline for the recall matches your heaters date.
E-mail me if you need more help.
ahudson43@yahoo.com
Dec 28, 2010 | Rheem 266K to 399K BTU Swimming Pool...
Replacement of window unit
Yes,you can,they are basically the same,you can get a 18000 btu to go in it.The more the btu`s,the higher they are anyhow.
Jul 22, 2010 | Heating & Cooling
PTG-74PVN
I suggest you call tech support. I had a similar problem, and after walking me through a few tests, they determined it was likely a motherboard problem and are sending a new one. At 2 1/2 years, your unit should still be under warranty...
Sep 01, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Promac wall unit Model # PS9OCR. Unit was left on
I would suggest you check how humid it is outisde, if it is really humid it is pulling water out of the air, the drain could be plugged also. And the filter could be plugged or the condensor may be defective or plugged.
Aug 28, 2009 | Heating & Cooling
WHAT BTU IS THIS UNIT? IT IS 4 YEARS OLD. SAYS
Check the serial plate. This should tell you the btu's
May 13, 2009 | Heating & Cooling
2 Air Conditioner Problems
Whinny noise is probably motor which needs some motor machine oil (hardware store).
Freezing is probably caused by bad de-icing switch or poorly insulated de-icing switch.
If you want to further pursue, let me know.
Apr 30, 2009 | Heating & Cooling
Need the BTU rating for an old Kenmore K948991 a/c
Your model number is not complete enough for a model check.
However, 18,000 btu in todays' units is what you need.
Mar 28, 2009 | Kenmore Heating & Cooling
Heating & Cooling Logo
142 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
