My Sanyo TV DS25204 is stuck in Video mode.
My TV has worked OK for four years on cable. I played a DVD movie on it yesterday. Now I can't get it our of Video mode to work on TV. I use
a universal DVR remote (Synergy IV) for it.
  • 5 more comments
  • William Kershaw Jun 27, 2008
    No, the buttons on my TV are: Menu, Channel up
    and down, volume up and down, and Power
    All the buttons you mentioned are on my remote
    control, but the only reaction I get is that the TV turns off and on when I press the channel button. When I press the Video Source button, the CBL red light goes on and off.
    Another thing, when I turn the TV on, the cable box shows a number-4801 and a clock face. It
    never did this before!
    When I click the tv button on the remote, the
    TV goes off. When I reclick it, the TV goes
    back on, but still showing the word Video in
    the upper right corner. There is no opportunity to change to Channel 4, which is
    what I need to get TV reception.
    I tried the volume control on the remote and the
    word Video disappears and the volume changes (if
    I have a DVD on). But then the word Video
    comes back on the screen.
    I have disconnected the remote and the cable connection and I used the TV buttons. Nothing
    different happens.
    to bestdarngood: No, the DVD player is not a combo vcr-dvd. It is now disconnected and so
    is the Cable control box, but the TV is still doing the same things. I think I will have to take it to a local repair shop. I am afraid
    that none of you have been able to solve my
    problem. It is now 10:00 PM and I will go to bed. I will check my e-mail in the morning to
    see if any of you can find any solution.
    I unplugged the TV and everything else overnight
    and just tried it again this morning. Still I
    have the same problem.
    I will go to a repair shop today and if I can't
    get an answer, I will buy a new TV.
  • 1,512 Answers
Hi,it is possible that the remote has lost its code.It may be worth re entering it. Have you tried scrolling the channel button on the Tv to get back channels? You havent mentioned you tried that yet.
Posted on Jun 27, 2008
  • 4,234 Answers
My first guess would be that the universal remote has gotten confused and is no longer sending the correct codes for your TV. Try replacing the batteries on the remote and reprogramming for your TV model. The TV/Video button should not work as expected.
Dan
    President:
  • 2,712 Answers
Try a hard reset of the TV: unplug it from the AC power source and any other inputs like cable/DVD, etc for at least 4 hours. Reconnect everything after 4 hours and see if it works.
If not, it looks like a problem with the circuitry, for which I would recommend seeking professional repair.
    Genius:
  • 2,035 Answers
Un plug all connections and power cable from the tv and receiver wait for 30 minutes and even the the battery of the remote and then reconnect it back and check if you have the same problem..............
  • 3,037 Answers
Try resetting the cable box by unplugging it for 10 minutes to see if it will revert to default settings. Check with your manufacturer of the box to see what the numbers mean as this will be unique to the exact box. Did you have any recent power surges or anything out of the ordinary?
  • Benjamin Patri
    Benjamin Patri Jun 27, 2008
    Also, is this a vcr/dvd player that you were using? Have you tried unplugging the tv until it reset? Are you getting channels through the assumed vcr that is connected?
  • Benjamin Patri
    Try leaving it unplugged overnight to see if it will reset the tv
    Do the buttons on the tv work at all? If not then, I believe that the control unit may have a short
  • 6,487 Answers
Try this :
  1. Try changing the volume with the volume control. If it changes the data bus is not the problem. This is assuming the TV is tuned to a good TV station.
  2. Mark the EXACT position of the screen/G2 control with a marker. Then turn the G2 control up.
    • If the picture unblanks and a gray scale bar pattern is used, you can usually see which CRT gun is weak. Time to replace the CRT for a long term fix. All of the temporary fixes I have tried resulted in only a few months extra life out of the tube.
    • If the picture does not unblank and it looks kind of like there is a halo near the top of the screen. The vertical circuit needs checked for proper operation and repaired. WARNING do not continue to operate the TV set in this mode for any length of time, it will crack the CRT from localized heating!!!! (because the guns are shooting into the extreme top of the tube and possible the neck of the tube) RETURN the G2 control to the exact position that was marked before you started.
The typical failure mode of the vertical circuit in a Sony causes only one of the vertical supply resistors to open usually. Either the +15 V or -15 V. This puts a full + or -15 V on the yoke which deflects the guns into the glass envelope of the tube.
Hope that helps.......
  • 2 more comments
  • Mark Gil
    Mark Gil Jun 27, 2008
    I think this time better take this unit to a repair center near to properly diagnose what really the problem here and led professional handle it for you ..
    Good luck..........
  • Mark Gil
    Try using the channel button on your television set instead of using the remote....
  • Mark Gil
    Try turning off the DVD, and use the control on the television like channel and volume,,,
  • Mark Gil
    If still the same follow my suggestion and bring this to a near repair center...
  • 58 Answers
Look in the remote for a botton t.v click it and you will be back to the t v mode or click on the exit botton
    President:
  • 357 Answers
When you played the movie, you would have changed the channel from TV or AV to Video, in the bottom left hand corner, you should find a button that says "Video Source", make sure that the setting for this is to your TV.
At the top of your remote, you should find two buttons that say "TV" and "CBL", try both of these to see if you get a picture on your TV Screen.
In the middle of your remote, you should find a button that says "CH", try using this to switch between channels to find the channel your TV would be displayed on.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
  • Dustin Ellse
    Dustin Ellse Jun 27, 2008
    Hi there
    You should try and turn off your DVD player, this should automatically switch it back to TV Mode, if this doesn't help, i would suggest that you bypass the DVD Player by disconnecting the Cable from your DVD Player and plugging it strait into your TV.
    Guru:
  • 1,894 Answers
There is also a button on the TV set also.
instead of the remote try using that
Scree is blue and says Video as if were going to play one. I did not put it in that mode and I cannot get it back in TV mode.
Go to your menu on your tv, go to inputs, check for right setting, no problem, connect a player and try to play a movie, if movie plays and TV is on cable or HDMI. Tv needs to be reset to factory settings.
Mar 05, 2016 | Sanyo Televison & Video
Fix tv picture
If the TV is receiving its signal from a cable TV box or DVR then you need to find out if the problem is in the TV or the cable box/DVR. Connect a different source to your TV such as a DVD or Blu-ray player and play a DVD movie. If the problem occurs again it suggests the TV needs repair. If the TV works OK when playing a DVD movie then that suggests that your cable box/DVR needs repair or replacement.
If your TV is receiving its signal directly from an antenna or cable outlet on the wall then you should try replacing the cable wire from the wall to the TV with a new wire. If that doesn't help then your TV probably needs repair or replacement.
Dec 29, 2015 | Sanyo Televison & Video
Left half screen is dark
Open your left eye ...
OK, just kidding. If your TV or its remote control has a Reset button you can press it twice to reset the TV to original factory conditions (but you lose all customised picture and sound settings). If the TV receives its signal from a cable box or DVR, try connecting a different device such as a DVD or Blu-ray player and play a movie disc. If the problem on your TV screen still exists that suggests the TV needs repair or replacement. If the picture is OK when playing a DVD movie that suggests that your cable box or DVR is faulty and needs replacing (usually free from the cable TV company).
Dec 28, 2015 | Sanyo Televison & Video
Can't change to video mode missing remote on SANYO TV model DS25204
You must have its original remote control to select inputs.
May 12, 2012 | Sanyo Televison & Video
What channel does it need to be on to play a dvd player I have the converter box
Ur tv have a video input holes R,Y,W.?Use the RCA cable R,Y,W to hook up to play the DVD player.Use the tv video 1 input to watch dvd movie.
May 27, 2010 | Sanyo DS25390 TV
DVD does not work with TV - invalid format error
Make sure that there are no discs in the player.
1. Turn it on
2. Press "Setup" on the remote
3. Press the down button twice on the remote
4. Press the right button once on the remote
5. Press the up button once on the remote
6. Press "Ok" on the remote
You should now be back into interlace mode.
Apr 13, 2009 | Televison & Video
Sanyo dvd/vcr dvw 7000
I have a Sanyo Dvd/vhs player and I recentlty went to dish network instead of cable and I do not know how to get the player to work now so I can watch movies that I have rented. Can you tell me how to use the remote to watch movies.
Apr 08, 2008 | Sanyo DVW-7000 DVD Player/VCR
DVD Plays in Black and White
Depending what cables you have, try plugging only the yellow cable into "video out", I previously had red, white, and yellow cables plugged into "comopents out" and only got black and white. Doing only the yellow into video out gave me color.
Jun 17, 2006 | Sony DVP-NS700P DVD Player
Televison & Video Logo
235 people viewed this question
Top Televison & Video Experts
