Question about Hitachi 53FDX20B 53" Rear Projection Television
Distorted picture It is like seeing tripled objects in green, magenta and blue,
Yes there are 2 IC's on the convergence board. Unless you have used solder wick and a soldering iron before use a tech to replace them you can expect to spend around $335.00 for the repair.
Posted on Jul 04, 2008
    President:
  • 2,712 Answers
You will most likely have to replace the convergence IC's..
Posted on Jun 27, 2008
Blue and green " blooms" in picture
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 28, 2011 | Panasonic PT-52LCX66 Projection Television
My television is only showing blue and green colors
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 25, 2010 | Philips Televison & Video
I have a samsung 65in hdtv rear projection and the colors dont line up it looks like triple vision what could it be
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 18, 2010 | Samsung HCN653W 65" Rear Projection...
Triple colored ghosts
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
Problem #2 - Another common problem is dull or washed out video.
Apr 17, 2010 | Sony KP-43T90 43" Rear Projection...
Problem with Sony KP46WT500: Each line on the
These sets have several common problems listed below.
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
Mar 16, 2010 | Sony KP-46WT500 46" Rear Projection...
MAGENTA AND GREEN WAVE ACCROSS TOP OF SCREEN
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
  • Dull looking video
  • White looking video
  • Red/Orange looking video
Jan 26, 2010 | Hitachi 53FDX20B 53" Rear Projection...
Distored picture and a rainbow aura around objects in the pictur
this CRT TUBE internal Problem, first use CRT Rejuvenation Device. If dont repair you must change CRT TUBES
Oct 30, 2009 | Samsung Televison & Video
Picture is ok,but the blue,red & green lines appear in picture
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Oct 19, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Red, Green convergence lines are wavy
Projection TV sets have two very common problems listed below.
*Screen Looks 3-D
*Colors wont align
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
Green/Blue distorted Colors
Color issues are harder to solve without seeing the problem. It sound like the red amplifier on the crt board is bad. Is there any red in the picture at all? If not, that will be you problem
Nov 26, 2008 | Televison & Video
Hitachi 53FDX20B 53" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
