No picture on my combo tv/dvd
I purchased this TV/DVD combo (Audiovox FPE1906DV when a local electronics store was going out of business about a year ago, so I doubt it has a warranty.
It worked fine up until 2 months ago and then the DVD started making strange noises, then it started not to read some of the DVDs that I inserted, and ultimately the DVD player stopped working all together. I just get a blank blue screen, it says 'no disc, and there is no sound.
Then a couple weeks ago, the picture on the TV stopped working as well, but the odd thing is that I receive audio, just not video. I thought perhaps it was a bad cable connection, so I removed the cable and same thing, no picture.
What can I do to fix this?
  • 1 more comment
  • gino1999 Jun 27, 2008
    What is an IC and can I replace it myself?
    sorry those are basic solutions that I've tried already.
    sorry, that last comment about basic solution was for the other person who sent me a solution. I think it probably is the IC, but I don't know how to prove that...perhaps I can take it apart and see something broken?
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
1. Make sure that the HDTVlp is connected to the correct “antenna in”
input on the set-top box or TV.
2. Rotate the antenna around the room to find the best reflacted signal,
keep in mind that the best reflected signal may be behind the antenna.
( Rotate the antenna base up to 360º until you receive the
best signal possible).
3. For houses with aluminum siding/insulation or stucco, place the antenna
near a window to minimize interference.
If this fails to give you a solid picture, slowly rotate the antenna 360
degrees until you receive a picture - the HDTVlp antenna was designed to
pick up reflected signals from interior walls. Keep in mind that the best
Check if the connections with the external AV signal source are
correct.
Correctly set the items in the picture menu.
Check if the video type input signal is not corresponding to the
unit.
Make sure the unit is turned on and in correct video type.
Make sure the unit is turned on and the connections are
correct.
Make sure the power adapter is correctly connected.
Make sure disc is loaded in.
Make sure disc is loaded upside down.
Make sure disc is not dirty or warped.
Make sure the player’s region code is the same as region code
of DVD disc.
Make sure water condensation has not occurred. If it occurs,
take out disc and leave the player on for at least one hour.
CLICK THIS LINK FOR DOWNLOAD THE MANUAL FOR MORE INFORMATION
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=5fa00a4cabc26e3e1fcd089d137720ac&q=Audiovox+FPE1906DV
Thanks
Good Luck
"Don't Forget to rate the solution"
Posted on Jun 27, 2008
    Guru:
  • 1,894 Answers
No picture means
it can be a damage to vertical or horizontal ICs or any other important IC sir
  • 2 more comments
  • dewan nafees ahmed Jun 27, 2008
    IC means integrated circuity.
    it is a very small chip which can perform complex functions.
    they are soldered to a circuit board for performing those functions.
    for replacing the ICs u need have a very good knowledge in practical electronics
    thank you
    it can be the PIP module or the vertical ICs..
    There is a quick test you can do to determine if the problem
    is in your PIP module, using two 4.7uf/50v electrolytic capacitors. The
    PIP module plugs into two connectors on the main board. Remove the PIP
    module, and on connector VP on the main board (the 11 pin connector), use one
    cap to jumper from pin 7 to 9 (negative lead on pin 9); and use the other cap
    to jumper from pin 5 to 11 (negative lead on pin 11). If the PIP module
    is bad, you will now have video. The PIP module has surface mount
    capacitors that go bad. Typically all but the three large surface mount
    capacitors will read bad or weak with an ESR meter. When you remove the
    caps and clean the board, check for eaten traces; especially around the
    4.7uf/35v cap at the upper left of the PIP module. Sometimes the
    electrolyte leakage will also eat other traces, so be sure to inspect the area
    around the micro. I prefer to replace these surface mount caps with miniature
    leaded ones as they don't seem to have the leakage problems associated with the
    surface mount caps.
    is your unit has a old chassis like 169 then you need not have fear about the fly back voltage since there will be a high voltage splitter.
    am not sure of the chassis your unit uses.
    so be careful..
    fly back voltage is a very high voltage and can cause instant spot death. so be careful
    hope it helps.
    thank you
    dont forget to accept MY solution if u go by it.
    feel free for asking any doubts u have.
    thank u for ur cooperation.
    good luck for getting fixed soon
Codes for one for all remote
Cable:
Americast 0899 Bell South 0900 Director 0476 General Instrument
GoldStar 0144 Hamlin 0009
Jerrold
Memorex 0000
Motorola
Pace 0237
Panasonic
Paragon 0000
Philips
Pioneer
Pulsar 0000 Quasar 0000 Runco 0000 Samsung 0144
Scientific Atlanta
Sony 1006 Supercable 0276 Toshiba 0000
Zenith 0877 1877 0477
0000 0525 0899
0476 0810 0276
0476 0810 0276
0476 0810 0276
0000 0107
DVD:
Apex Digital 0672 0717 0794 1056 0755 0797 1100 0796 1061 Axion 1072
Blaupunkt 0717 Blue Parade 0571 CineVision 0876 Curtis Mathes 1087
CyberHome
Daewoo 0784 Denon 0490 Dual 1068 DVD2000 0521
Emerson
Enterprise 0591 Fisher 0670 Funai 0675
GE
Go Video
GPX 0699 Greenhill 0717 Hitachi 0573 Hiteker 0672
1024 1023 0816
0591 0675
DVD JVC
DVD Kenwood
DVD KLH
DVD Koss 0651 DVD Lasonic 0798
DVD Magnavox
DVD Marantz 0539 DVD Microsoft 0522
DVD Mintek
DVD Mitsubishi
DVD Nesa 0717 DVD Norcent 1003 DVD Onkyo 0503 DVD Oritron 0651
DVD Panasonic
DVD Philips
DVD Pioneer
DVD Polk Audio 0539 DVD Proscan 0522 DVD Qwestar 0651
DVD RCA
DVD Rotel 0623 DVD Rowa 0823
DVD Samsung
DVD Sanyo 0670
DVD Shinsonic
DVD Sony
DVD Sylvania 0675 DVD Symphonic 0675 DVD Technics 0490 DVD Theta Digital 0571 DVD Toshiba 0503 DVD Tredex 0799 DVD Urban Concepts 0503 DVD Xbox 0522
DVD Yamaha
DVD Zenith
Satellite AlphaStar 0772
0558 0623 0490 0534 0717 1020
0503 0675
0839 0717 0521 1521
0490 1762
0503 0539 0646 0525 0571
0522 0571 0717
0573 1075 0820
0533 0839
0533 1533 0864 1033
0392 0566 0639 0247 0749 1749 0724 0819 1856
Satellite Dish Network System
Satellite Dishpro
Satellite Echostar
Satellite Expressvu 0775 Satellite GE 0566 Satellite General Instrument 0869 Satellite GOI 0775
Satellite DirecTV
1005 0775 1005 0775 1005 0775
Satellite Hitachi
Satellite HTS
Satellite Hughes Network Systems Satellite JVC
Satellite Magnavox
Satellite Memorex
Satellite Mitsubishi
Satellite Motorola
Satellite Next Level
Satellite Panasonic
Satellite Paysat
Satellite Philips
Satellite Proscan
Satellite RadioShack
Satellite RCA
Satellite Samsung
Satellite SKY
Satellite Sony
Satellite Star Choice
Satellite Toshiba
Satellite UltimateTV
Satellite Uniden
Satellite Zenith
TV AOC
TV Admiral
TV Advent
TV Aiko
TV Akai
TV Alfide
TV America Action
TV Anam
TV Apex Digital
TV Audiovox
TV Baysonic
TV Bell & Howell
TV Bradford
TV Broksonic
TV CXC
TV Candle
TV Carnivale
TV Carver
TV Celebrity
TV Celera
TV Changhong
TV Cineral
TV Citizen
TV Clarion 0819
0775
"0749, 1749" 0775
0724 0722
0724
0749
0869
0869
0247 0701
0724
0749 1749
0392 0566
0869
0392 0566
1276
0856
0639 1639
0869
0749 1749
0392 0639
0724 0722
0856 1856
0030
0093 0463
0761 0842
0092
0702 0030
0672
0180
0180
0748 0765 0767
TV Contec 0180 TV Craig 0180 TV Crosley 0054
TV Crown
TV Crown Mustang 0672
TV Curtis Mathes 0047 0054 0060 0702 1147 1347
TV Daewoo
TV Denon 0145 TV Dumont 0017
0154 0236 0171 0623
TV Durabrand
TV Electroband 0000
TV Emerson
TV Envision 0030 TV Fisher 0154
TV Fujitsu
TV Funai
TV Futuretech 0180
TV GE 0047 0051 1347
TV Gateway
TV Gibralter
TV GoldStar
TV Gradiente 0053 TV Grundig 0672 TV Grunpy 0180 TV Hallmark 0178 TV Harman/Kardon 0054 TV Harvard 0180 TV Havermy 0093 TV Hello Kitty 0451
TV Hitachi
TV Infinity 0054 TV Inteq 0017 TV JBL 0054 TV JCB 0000
TV JVC
TV Jensen 0761 TV KEC 0180
TV KLH
TV KTV
TV Kenwood 0030 TV Kioto 0706
TV LXI TV MGA TV MTC 0047 0054
0150 0030 0178 0060 0030
0180 0672
0451 1661
0003 0171 1034
0683 0809 0180 0171
1755 1756 0017 0030 0030 0178
0145 1145
0463 0053
0765 0767 0180 0030
TV Magnavox TV Marantz TV Matsushita TV Megatron TV Memorex TV Midland 0054 0706 0030 1454 1254 0054 0030
0250 0650
0178 0145
0154 0250 0463 0150 0178 0047 0017 0051
0093 0150 1250 0178 0836
TV Mitsubishi
TV Motorola 0093 TV Multitech 0180
TV NAD
TV NEC
TV NTC 0092
TV Nikko
TV Norcent
TV Onwa 0180
TV Optimus
TV Optonica 0093
TV Orion
TV Panasonic
TV Penney
TV Philco
TV Philips
TV Pilot 0030
TV Pioneer
TV Portland 0092 TV Prima 0761 TV Prism 0051 TV Proscan 0047 TV Proton 0178 TV Pulsar 0017
0166 0866
0051 0250 0650
0047 1047 1147 1247 1347 1447 1547
TV RadioShack
TV Realistic
TV Runco
TV SSS 0180
TV Sampo
TV Samsung
TV Sansei 0451 TV Sansui 0463 TV Sanyo 0154 TV Scotch 0178
TV Quasar TV RCA
TV Scott
TV Sears
TV Semivox 0180
0156 0178 0866 0030 1704 0704
0030 0178 0092 0748 0824
0154 0250 0166 0650
0236 0463
0051 0250 0650
0047 0156 0051 0060 0030 0178 1347
0054 1661 0463 0030 0145 0054 1454 0690
0047 0154 0180 0030 0178 0154 0180 0030 0178
0017 0030
0030 1755
0060 0702 0030 0178 0812
0236 0180 0178
TV TV TV TV TV TV TV TV TV TV TV TV TV TV TV TV TV TV
TV
TV
TV
TV
TV
TV
TV
TV
TV
TV
TV
TV
TV DVD Combo TV VCR Combo TV VCR Combo TV VCR Combo TV VCR Combo TV VCR Combo TV VCR Combo TV VCR Combo TV VCR Combo TV VCR Combo TV VCR Combo TV VCR Combo TV VCR Combo TV VCR Combo TV VCR Combo TV VCR Combo Semp 0156 Sharp 0093 Sheng Chia 0093
Sony
Soundesign
Squareview 0171 Starlite 0180 Supreme 0000
Sylvania
Symphonic
TMK 0178 TNCi 0017 TVS 0463 Tandy 0093
Technics
Techwood 0051
Teknika
Telefunken 0702
Toshiba 0154 0156 0060 1356 1656 1704 0650
Toshiba 1256 Vector Research 0030 Victor 0053 Vidikron 0054 Vidtech 0178 ViewSonic 1755
Wards
Waycon 0156
White Westinghouse
Yamaha 0030
Zenith
Sylvania 0675 America Action 0278 Audiovox 0278
Broksonic
Citizen 1278 Colt 0072 Curtis Mathes 1035 Daewoo 1278
0000 1100 0810 0180 0178
0054 0030 0171 0180 0171
0051 0250
0054 0180 0150 0060 0092
0054 0030 0178 0866
0463 0623
0017 0463 0178 0092
0479 1479
TV VCR Combo TV VCR Combo TV VCR Combo TV VCR Combo TV VCR Combo TV VCR Combo TV VCR Combo TV VCR Combo TV VCR Combo TV VCR Combo TV VCR Combo TV VCR Combo TV VCR Combo TV VCR Combo TV VCR Combo TV VCR Combo TV VCR Combo TV VCR Combo TV VCR Combo TV VCR Combo TV VCR Combo TV VCR Combo VCR
VCR VCR VCR VCR VCR VCR VCR VCR VCR VCR VCR VCR VCR VCR VCR VCR VCR VCR VCR VCR VCR VCR VCR VCR
Sears 0000 1237 Sony 0000 1232 Sylvania 1781 Symphonic 0000
Thomas 0000
Toshiba 1145 0845 Zenith 0000 1479 0479 ABS 1972
Admiral 0048 0209 Adventura 0000
Aiko 0278
Aiwa 0037 0000 Akai 0041 Alienware 1972 America Action 0278 American High 0035
Asha 0240
Audiovox 0037 0278 Beaumark 0240
Bell & Howell 0104
Broksonic 0184 0121
Calix 0037
Canon 0035
Carver 0081
CCE 0072 0278 Citizen 0037 0278 1278 Colt 0072
Craig 0037 0047 Curtis Mathes 0060 0035 Cybernex 0240 CyberPower 1972
Daewoo 0045 0278 1278
Satellite PVR Combo Satellite PVR Combo PVR
PVR
PVR
PVR
PVR
PVR
Cable PVR Combo Cable PVR Combo Cable PVR Combo TV VCR DVD Combo RCA 0392 Sony 0639 Panasonic 0616 Philips 0618
ReplayTV
Sonic Blue
Sony 0636
Tivo
Motorola 1376
Pioneer
Scientific Atlanta 1877 Sharp 0807
0614 0616 0616 0614
0636 0618
0187 0007
Dec 24, 2015 | One For All Televison & Video
I have no or barely audible sound when I try to play a dvd on my audiovox TV/DVD player. Lots of volume when in satellite TV mode.
I repair electronics at a local thrift store, and I have one with this issue. It seems odd that the laser would be bad since the video comes through beautifully which suggests to me that it is reading the disc well. If I'm able to solve the issue, then I will reply soon.
Mar 15, 2015 | Audiovox DVD Player FPE1505DV
I need a TV code for Audiovox FPE1906DV.
0451. 0180.0092.0623.0003.setup codes for tv,s.
Apr 26, 2010 | Audiovox FPE1906DV 19 in. LCD Television
TV picture upside down.
go to " SETTINGS " and rotate picture in there , hope it helps , AJ
Nov 03, 2009 | Audiovox VE1020 10.2 in. TV/DVD Combo
Disney 13" TV/DVD reads because of Regional settings
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be replaced. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be replaced at no charge to you. The warranty would likely be at least 90 days from the date of purchase from the manufacturer. If you purchased an extended service plan they will replace the TV at no charge as well.
If the TV is no longer in warranty, you will not be able to get it repaired because the parts are no longer available. The company that was manufacturing Disney TVs and DVD players went out of business nearly two years ago.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Jul 04, 2009 | Disney Princess TV/DVD Combo
Need a remote that works for TV and DVD player
Go to Remotes.com and put your model # in, they do have the original for $30.00
Feb 26, 2009 | Audiovox FPE1506DV 15 in. LCD TV/DVD Combo
GoVideo DVD combo
Hi - I can record a dvd from the tv and can play it back but when I try to play a store purchased dvd it ejects the dvd and on the tv screen it says unknown disk, please, check disk again.
Aug 19, 2008 | GoVideo Go Video DVD/VCR Combo
SuperSonic FC-2245 TV/DVD Combo
you can purchase one from any local electronics parts store.
you can buy one from ebay too.
just type power cord and you will see flood of info.
it costs, $2.00
Feb 16, 2008 | Televison & Video
Costoco Case #308092- I bought a Audiovox 27" LCD TV/DVD combo in May
Contact your authorized servicer as you have a more elaborate tech problem...accordianman
Oct 19, 2007 | Audiovox FPE1078 7.8 in. TV/DVD Combo
Televison & Video Logo
194 people viewed this question
Top Televison & Video Experts
