Question about Lands Phones
Our Aria phone system is playing up. 3 of the 7 phones are displaying this message LDP-7008D V1.4 SCOUT-DX V1.1 OK SYNC and none of the buttons on the keypads work and there is no dial tone. the system has been reset but that didnt fix problem
3 Suggested Answers
SOURCE: lkd-24d error for starplus sts
The technician had to remove the memory module as the board tried to reset itself but the memory module was corrupted and would not allow the board to reset itself. The phone were reprogrammed and are working.
Posted on May 13, 2008
micromaster
  • 3614 Answers
SOURCE: LG-Nortel LDP-7024D Handset connecting to GDK100
try to check the telephone wire connections. or try to use the other phone box to test.
Posted on Sep 09, 2008
maklean
  • 1665 Answers
See link about LDP-7000 series basic functions. May helps
http://www.promelit.gr/downloads/manual/7016D24D_user_Guide.pdf
Posted on Sep 10, 2008
Lg aria phone showing "LDP-7016D V1.4 SCOUT-DX V1.1 OK SYNC" same as below
Lg aria phone showing "LDP-7016D V1.4 SCOUT-DX V1.1 ...
www.faqqq.com/.../lg-aria-phone-showing-ldp-7016d-v1-4-scout-dx-v1...
Question Product: Phones Question Details: Lg aria phone showing "LDP-7016D V1.4SCOUT-DX V1.1 OK SYNC" same as below View Answers Search ...
LG Aria 130 & LDP-7016D Handset Issue - LG / Goldstar Systems ...
www.tek-tips.com/viewthread.cfm?qid=1694833
Oct 3, 2012 - I recently purchased 3 additional LDP-7016D handset for our phonesystem, but have ... System is a LG-Nortel Aria 130 running 7 handsets 1 x LDP-7024D Handset (V1.4) 6 x LDP-7016D Handsets (5 x V1.4 and 1 x V1.5)
Sep 16, 2013 | Lands Phones
Sep 09, 2008 | Nortel Lands Phones
NTL VS205 lost manual
Lets see if I can get my hands on a manual. one moment
Jun 27, 2008 | NTL D6000 Cordless Phone
How do i reprogram my speeddial numbers on jazz 4400?
Hello.
From NorStar Support:
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94). that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
If the above doesn't work, try:
  1. Press [Feature] [*] [4]
  2. Enter a two-digit code from 71 to 94.
  3. Specify the external line by pressing a line button, a line pool button, or the intercom button. If you don't specify the external line, the system automatically chooses a line for the call.
  4. Dial the telephone number you want to program (up to 24 digits).
  5. Press [Hold].
  6. Record the code and number you have just programmed.
Hope this helps.
Feb 02, 2011 | NorStar Jazz Plus 4400 Corded Phone
How do I remove the Touch tone/pulse option. This message has recently appeared without knowing how it go there. It was never there before. ''If you are calling from a touch tone phone please press 1 now,...
Sounds like your touchtone gate has been enabled in your voicemail. To disable the touch tone gate enter feature 983. if your system has 2 digit intercom #s your default password is 120000 if your system has 3 digit intercom #s your default password is 1020000. once you have entered the password you will see 3 selections you can make .use the three soft keys under the display and select AA (auto Attendant). next press 1, the display should say TT gate:std chng and ok. press the chng key til it says none and press ok press the rls key when finished.
Jan 11, 2010 | Nortel T7316E 2-Line Corded Phone
I have a problem with voice mail with a meridian hooked to NT5806DA-93. The system on voice mail every second pulse off so that only half of each message is played at a half second interval
Voicemail Features Norstar Common To Check Your Voicemail:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
To Change Your Personal Greeting:
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
To Record Your Alternate Greeting (Used when on vacation or out of the office.:
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the ChOOSE softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting
Norstar Voicemail Administrative Programming Programming must be done from any M7310, T7316, or M7324 model phone set.
To Log Into System Administration:
1. Enter Feature 983
2. The display will show "LOG", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
3. Press the softkey under "OK"
To Create a New Mailbox:
1. Log into system administration
2. Select the softkey under "MBOX"
3. Select the softkey under "ADD"
4. Enter the mailbox number (extension. you want to add
5. Mailbox type: Subscriber and then select "OK"
6. Extension: Usually the same as the mailbox number
7. Service Class: Enter 1
8. Name: Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma, and then enter the first name. When spelling the name, press # to move to the next character
9. Directory: Y (Yes.
10. Message Waiting: Y (Yes.
11. Out dial: Pool, enter 1 and then OK
12. Accept: 1, select OK
To Delete a Mailbox:
1. Log into the system administration
3. Select the softkey under "DEL"
4. Enter the mailbox number (extension. you want to delete
5. Select the softkey under "Delete"
To Reset a Mailbox Password:
3. Select the softkey under "Chng"
4. Enter the mailbox number you want to reset the password for
5. The display shows "Reset Password"
6. Select the softkey under "RESET"
7. Press the release key
*The new password will be "0000", the system will ask the user to change this the first time they log into their mailbox using this password.
To Change the Name on a Mailbox:
4. Enter the mailbox number (extension. you want to change the name on
6. Select the softkey under "Next", keep hitting "Next" until the display shows the name
7. Select the softkey under "Chng" to enter a new name
8. Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma and then enter the first name. When spelling the name, press "#" to move to the next character
9. Select the softkey under "Next" to save the change
10. Hit the release button
Apr 15, 2009 | NorStar Lands Phones
Lkd-24d error for starplus sts
May 12, 2008 | Vodavi StarPlus 2706 Corded phone
Resetting company voicemail
Norstar Common Voicemail Features To Check Your Voicemail:
4. Leave message
took this from a guide i have, might help you guys out
Jan 07, 2008 | NorStar M7310 Corded Phone
Lands Phones Logo
164 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
