Question about Magic Chef Refrigerators
I have the counter top ice maker. Model No. MCIM30TS How can I open it up to clean the ice making area?
    President:
  • 2,712 Answers
Can you kindly give me the make as well please?
Posted on Jun 27, 2008
  • Swilin Sampson
    Swilin Sampson Jun 27, 2008
    Please see page 6 of the following manual for detailed cleaning instructions:
    http://www.mcappliance.com/document/MCIM...
  • Swilin Sampson
    Should you find my solution helpful, kindly take a moment to "accept" it.
    Thanks!
    Guru:
  • 1,894 Answers
You will need a service manual for doing that?
do u own a service manual?
Water leaking from ice maker
Make sure normal drain line (located under the ice) is not clogged. Check gaskets and seals. Also make sure everyone who uses it closes the door completely and does not leave it cracked open. And make sure no one has screwed any thing into it and punctured through it. A screw alone will not keep the water in.
Feb 24, 2015 | U-Line Icemaker
Our ice machine is making too much ice. When we open the door, ice spills out - so for some reason, whatever triggers the machine to know that it has enough ice made, seems to be malfunctioning. Any...
When frost builds up on the little flapper at the top of the door above the ice maker it can get stuck. It tells the ice maker to keep making ice. Try cleaning the mechanism of frost and make sure it operates freely.
Oct 17, 2013 | Electrolux Stainless Steel Under-counter...
I need to order aice shovel for my magic chef tabletop icemaker model #MCIM30TW
try this page - I have a similar model (MCIM30TS) - however, I can't figure out how to remove the pins to remove and replace the ice shovel...any ideas?
http://www.repairclinic.com/Shop-For-Parts?searchText=mcim30ts&Search=Find%20Parts
In case the link does not work properly, just go to the repairclinic.com website and enter your model number in the search box...
hope this helps
- Margaret
Sep 15, 2010 | Eastern Tabletop 7002 Stainless Steel 24...
Continental electric ice maker CE-IE65151. The
Look at the far ends of the shovel near the attachment hinges. There should be a little plastic tab near the pin on each end and on each hinge. They commonly break off. This is made by e_wave and their model is MCIM30TS. Order parts from Repair Clinic.com
Jul 14, 2009 | Continental PortableCE-IM65151 Ice Maker...
I have a Magic Chef Ice Maker Model No. MCIM30TS. My problem is that when I plug it in, nothing happens and the power light is blinking. Is the unit shot? Andrew from New Jersey
Hi, It's supposed to do that. Fill the base with water, then select an ice cube size, then click "start". It should start making ice within 20-30 minutes. The power goes off here all the time and that's how we re-start the machine. The important part is to first select the ice cube size, then click on "start'. I have no idea why it has to be done in that sequence. I have the same model, only I got it two years ago.
Apr 26, 2009 | Refrigerators
Magic chef MCIM30TS table top ice maker shovel breaks
I took 4 small nails, cut them to the proper length, heated them up with a lighter, and pushed them into the plastic creating 4 metal posts that the motor could push against. Just did it and it is working. Not sure for how long.
Nov 21, 2008 | Eastern Tabletop 7002 Stainless Steel 24...
I have a counter top ice maker. I can't seem to locate parts or find out if this machine even exists. It stopped making ice last summer. It cycles but does't add water to the cube maker. You have to add...
Magic Chef Counter Top Ice Maker.
just bought one. it seems to go through the cycle, but i noticed no water is getting pumped up to the tray. I looked through the back and the water tu be is 1/2 way, doesnt seem to pump water up. I may take it appart soon. Anyone have any luck?
Mar 18, 2008 | Magic Chef Refrigerators
Ice maker not making ice
you need a module cant remember the part number off the top of my head but go to repair clinic .com or your local appliance parts dealer with model and serial # in hand it may be quicker for you to get a new ice maker and easier
Dec 03, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
241 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
