Question about Hitachi 53FDX20B 53" Rear Projection Television
Distorted Picture TV is 6 year old. Worked fine until today. Picture is focused, but all 3 colors are"shifted" around. Any suggestions? Thanx, ALEX
  • STARB Jun 27, 2008
    It is like seeing tripled objects in magenta, green and blue. Please help.
  • 3,037 Answers
The two convergence Integrated Circuits or ICs need to be replaced on the board, if that for some reason still doesn't fix the problem, please let me know
Posted on Jun 27, 2008
  • 6,487 Answers
If the fuzzy picture you are experiencing looks like, at least in some places over the screen, like misregistration of the colors it may be the failure of the convergence ICs.
Hope that helps.......
    Guru:
  • 1,894 Answers
Color shifting can be due to both internal and external disturbances of the magnetic field.
if there is any external magnetic objects please remove them and try it.
else it may be some internal parts.
  • 1 more comment
  • dewan nafees ahmed Jun 27, 2008
    many people having this hitachi set seem to have this problem from before.
    You have what most big screen rear projectors face at least once in
    their life time: Convergence failure. There are two ICs called STKs
    that go bad and they need to be replaced.
    If an outside tv expert comes in to repair it the cost is always around
    $400 for the job. The only way to keep it down in cost is to do it
    yourself but you must be an experienced technician and know how to
    solder in replacement ICs.
    WIsh I had better news for you.
    source:en.allexperts.com
    Convergence is set by following the instructions in your owners manual.
    Always try that first. But, if the convergence has failed you will
    not be able to align it until the STK chips have been replaced.
    Hitachi calls their convergence Magic Focus and explains how it works in the manual.
    In your manual it is on page 45(sorry if page number is wrong) and says, in part:
    SET UP
    45
    SETUP
    Your HITACHI Projection TV has three color projection tubes: one for
    red, one for green, one for blue. When mixed together in the
    proper proportion, the output of these three color tubes can produce
    any color. To produce these colors, however, the beams must be
    precisely aligned over each other so that the colors can be mixed. The
    process of aligning these picture beams is called òconvergenceó.
    Over a period of time, the picture tubes can drift out of alignment due
    to normal bumps and vibrations or moving the TV. If you move
    your TV, or if, after a time, you notice color rings or halos around
    objects in the picture, you may want to converge (align) the colors.
    Properly converged, the lines appear white, which is actually a
    combination of the outputs of the three color tubes. The output of the
    green tube is stationary. The outputs of the red and blue tubes can be
    adjusted. When properly aligned, the outputs of all three tubes
    should be directly over each other to produce the white lines.
    To simplify convergence, HITACHI incorporates a function called MAGIC FOCUS located on the front control panel, which allows the
    TV to self-adjust. Press this MAGIC FOCUS button and the convergence self adjustment willl start and this process will take
    approximately 15 seconds. If this button is pressed during this
    process, no change in picture quality will occur. After this 15 second
    self-adjust period, picture quality will be optimum. (Do not move the TV during self-adjust.)
    You may also select MAGIC FOCUS from the SETUP Menu.
    NOTES: Only a momentary press of the MAGIC FOCUS button is necessary to start AUTO DIGITAL CONVERGENCE. At
    anytime during this convergence correction process, you may press the MAGIC FOCUS button to exit the MAGIC
    FOCUS mode.
    hope it helps.
    thank you
    dont forget to accept MY solution if u go by it.
    feel free for asking any doubts u have.
    thank u for ur cooperation.
    good luck for getting fixed soon
    President:
  • 2,712 Answers
Could you explain a bit more clearly by what you mean by "shifted"? A pic here would help..
  • Swilin Sampson
    Swilin Sampson Jun 27, 2008
    You will need to replace the convergence IC's on the main board.
I have a Hitachi Projection TV 51G500A 2004 ,
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2010 | Hitachi 51G500 51" Rear Projection...
I'm having a problem with the color green being distorted on my TV. Is this a color tube issue, bulb issue, lamp issue?
This is a picture tube type TV. No lamp.
You don't describe the distortion.
A colour green picture that is twisted and shifted away from the other colours is a convergence problem. see Projection TV Convergence on this site.
If the green is smeared, out of focus, larger than the other colours like a halo around objects, things like that, it is the green picture tube. Sony has discontinued most of the picture tubes so you may not be able to get this fixed.
Mar 31, 2010 | Sony KP-46WT520 46" Rear Projection...
Ghosting and bad color, sound is fine.
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 15, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
POOR PICTURE QUALITY
The convergance IC's need to be replaced along with possibly a pico fuse in the same circuit.Theres a large heat sink with two IC's starts with a STK number,replace them and that should take care of it.
Apr 29, 2009 | Televison & Video
Green screen and distorted picture sound is good but no picture
It must be connected with the color circuit of your tv, a board connected to back end of the tube. Could be dust, cob web or carbon deposit shorting a transistor. Popping noise if loud enough can be attributed to high voltage circuit fault and picture tube.
Have it service by a qualified person.
Apr 04, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
My 42 inch plasma has black distorted picture
hi
its cathode ray tube problem or the colour wheel...check that both please.....
thank u,,,,,,
Mar 07, 2009 | LG 42PC3D 42 in. Plasma Television
Green picture and distorted
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
Mar 11, 2008 | Hitachi 42V710 42" Rear Projection HDTV
Shadows on Rear Projection TV
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 25, 2008 | Televison & Video
Dvd playback
Maybe it's something with picture settings, i.e. NTSC/PAL or INTERLACE/PROGRESSIVE SCAN.
Oct 07, 2007 | Bose 3·2·1 Entertainment System...
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Hitachi 53FDX20B 53" Rear Projection Television Logo
55 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
