I have a 2001 Accord and if I hit the unlock button and do not open any door within a certain amount of time (2-5 minutes) it automatically re-locks it. Is there a setting I can change to prevent this...
Hope the following procedures helps.
TRANSMITTER TEST
NOTE:
If the doors unlock or lock with the transmitter, but the LED on the transmitter does not come on, the LED is faulty; replace the transmitter.
If any door is open, you cannot lock or unlock the door with the transmitter.
If you unlocked the doors with the transmitter, but do not open any of the doors within 30 seconds, the doors relock automatically. ?
The doors do not lock or unlock with the transmitter if the ignition key is inserted in the ignition switch.
1. Press the lock or unlock button 5 or 6 times to reset the transmitter.
If the locks work, the transmitter is OK.
If the locks don't work, go to step 2.
2. Open the transmitter and check for water damage.
If you find any water damage, replace the transmitter.
If there is no water damage, go to step 3.
3. Replace the transmitter battery (A) with a new one, and try to lock and unlock the doors with the transmitter by pressing the lock or unlock button 5 or 6 times.
If the doors lock and unlock, the transmitter is OK.
If the doors don't lock and unlock, go to step 4.
NOTE: The transmitters for LX models and EX models are different and are not interchangeable.
4. Reprogram the transmitter, then try to lock and unlock the doors (see Transmitter Programming ).
If the doors don't lock and unlock, replace the transmitter.
TRANSMITTER PROGRAMMING
Storing transmitter codes:
The codes of up to three transmitters can be read into the keyless receiver unit memory. (If a fourth code is stored, the code which was input first will be erased.)
NOTE: It is important to maintain the time limits between the steps.
1. Turn the ignition switch ON (II).
2. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
3. Within 1 to 4 sec., turn the ignition switch OFF.
4. Within 1 to 4 sec., turn the ignition switch ON (II).
5. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
6. Within 1 to 4 sec., turn the ignition switch OFF.
7. Within 4 sec., turn the ignition switch ON (II).
8. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
9. Within 1 to 4 sec., turn the ignition switch OFF.
10. Within 4 sec., turn the ignition switch ON (II).
11. Within 1 to 4 sec., push the transmitter lock or unlock button with the transmitter aimed at the keyless receiver unit behind the glove box.
12. Confirm you can hear the sound of the door lock actuators. Within 1 to 4 sec., push the transmitter lock or unlock button again.
13. Within 15 sec., aim the remaining transmitters at the keyless receiver unit (up to two additional ones) whose codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn the ignition switch OFF, and pull out the key.
15. Confirm proper operation of the transmitters.
Cheers!
Ryan
