Question about GE Lands Phones
How do I change my phone numbers that on automatic dialing?
It was easy - I found my instruction pamphlet. Thanks..
The phone must be off when you store numbers.
1. Press the memory button.
2. Press a number key (0-9) to store the dialed number in that memory location.
3. Press the memory button.
4. Enter the number (up to 20) digits.
5. Press memory button to comfirm. You will hear a confirmation tone.
Posted on Jun 27, 2008
Why my samsung galaxy s gt i9003 cell phone reeboot automatically
This is controlled in your settings menu under 'Fixed Dial'. (or similar command). You will need to change this setting.
I do not have a copy of the user guide for your phone but for most phones these are the directions:
When you turn on fixed dialing, you
can call only numbers stored in the
fixed dial list.
Turn fixed dialing on or off:
- > Settings > Security > Fixed Dial
Use the fixed dial list:
- > Settings > Tools > Dialing Services
> Fixed Dial
Jul 31, 2012 | Samsung Cell Phones
I need instruction manual to program speed dial
I was unable to locate a user manual for that particular device, however the basic instructions for programming speed dial functions are normally very similar between most phones.
Generally there are ONE TOUCH Speed Dial buttons labelled something like M1, M2, and M3 on the dial pad somewhere.
There should also be another button labelled PROG or STORE on the keypad as well.
Normally to program a number into a ONE TOUCH speed dial memory location you carry out the following procedure:
Lift the handset.
Then press the PROG (or STORE) button.
Now just use the number keypad to dial the full telephone number that you want to store in a Speed Dial location.
Once the full telephone number is dialed, then push the M1 button to store that phone number in the M1 One Touch Speed Dial location.
The phone may or may not show some kind of confirmation that the M1 location was just programmed, then just hang up the handset.
Now when you lift the handset and press the M1 button, the phone should automatically dial the phone number you programmed into it.
Now just repeat the same process for the M2 and M3 One Touch Speed Dial buttons with other phone numbers if necessary.
To change one of the Speed Dial numbers, just carry out the normal programming procedure for that location using the new phone number and the old number will simply be overwritten.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Dec 02, 2011 | Southwestern Bell FM-480 Corded Phone
Every time I click open a text message I've received, it automatically starts dialing the telephone number the message was sent from.
i think you should better click carefully your phone. Maybe your phone's keypad is just so sensitive that it uses the number of the message number and dials it automatically.. :)
Feb 03, 2011 | Samsung Cell Phones
This is my mother's phone. She cannot retrieve her voicemail messages. Typically, she "taps" the OK button twice, then it prompts her for her pin. However, she has done something because when she taps the...
she has changed her speed dial options to her daughters number instead of hers, or that was the last number dialed, have her manually call her own number from the device and then in the call log set it to speed dial for the number one.... This should take care of the issue.
Feb 14, 2010 | Vtech Lands Phones
I need to know how to program the numbers into the speed dial option. My mother's phone is a table set with large numbers #29267A ... close enough?
Before you store a telephone number in memory, make sure the dialing mode is
correctly set for the type of service you have. The default dialing mode is tone
(touch-tone), so if you have pulse (rotary) service, you must first change the dialing
mode. See “To Set the Dial Mode.” The following buttons can be stored into any
memory location: 0-9.
STORING FREQUENTLY CALLED NUMBERS
1. Pick up the handset.
2.Press the store button.
3. Push the desired memory location button.
4. Press the store button.
5.Use the handset number keys to enter the telephone number (up to 16-digits)
and press the store button.
6.Hang up the handset.
NOTE: If you make a mistake, use the delete button to delete wrong digits.
CHANGING A STORED NUMBER
Repeat the storage sequence above. The new number replaces the old number at
the memory location.
ERASING A STORED NUMBER
3.Press the memory location (0-9) to be erased.
4.Press delete for three seconds until the number in the display is erased.
5.Hang up the handset.
DIALING FREQUENTLY CALLED NUMBERS
1. Pick up the handset and press the mem button.
2. Press 0-9 for the memory location. The number dials automatically.
OR
1. Pick up the handset and press the dial button.
2. Press the review button for the desired memory location.
3. Press the dial button to dial the number.
OR
1. Press dial button while the handset is still in the cradle.
2. Press the review button for the desired memory location, lift the handset and the
Download User Manual
If this information was helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 02, 2010 | GE 29267GE3 Corded Phone
When I redial a number outside of my area code, how do I set up my phone to redial an automatic 1 before the number I want to dial? I have a GE cordles 28111 model
I can't redial.. How do I set up my phone to redial an automatic 1 before the number I want to dial? i have a GE digital 5-8
May 07, 2009 | Uniden Cordless Phone
What is a dial out code?
A dial-out code is a number that is automatically added when you dial a number. It can be either your area code or (usually) your country code.
Let's say the number stored in your phone is (123) 456-7899. So if your dial-out code is set to "+1", then the number dialed is +1-123-456-7899. This ensures that, wherever you are on this planet, you will always reach that number in the US.
On home phones you can sometimes set a dial-out code (like "123"), and if you dial 456-7899, then it automatically adds your area code to the number.
What sometimes happens is, let's say you bought your phone in the US, but you live in another country, your phone still automatically adds a "+1" to all your numbers stored in your phone unless specified otherwise. That's why you have to set the dial-out code to your specific region.
Jan 11, 2009 | Innovage Lands Phones
Enter memory data
Here are the commands to run the phones memory dial (speed-dial).  I have included the instructions for deleting and changing numbers as well.  It is listed below.  I hope this helps you out.
Ken
MEMORY DIAL INSTRUCTIONS Store up to ten 20-digit numbers in memory for quick dialing. Storing a Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the MEMORY button. 3. Press a number (0-9) to store the dialed number in that memory location. 4. Press the MEMORY button again. 5. Use the handset number keypad to enter the telephone number (up to 20 digits, including pauses) and press the MEMORY button again to save the number. The unit beeps to confirm. 6. To enter another number in a different memory location, return to step 1 and repeat the process.
Storing a Redial Number 1. Repeat steps 1 through 4 in Storing a Number in Memory. 2. Press the REDIAL button. 3. Press the MEMORY button to store the number. You will hear a confirmation tone.
Changing a Stored Number 1. Repeat steps 1 through 6 in Storing a Number in Memory. 2. Press the MEMORY button to store the number. You will hear a confirmation tone. The old number will be overwritten with the new number.
Dialing a Stored Number 1. Make sure the phone is ON by pressing the TALK button. 2. Press the MEMORY button. 3. Press the number (0-9) for the desired memory location. The number dials automatically. Inserting a Pause in the Dialing Sequence Press the PAUSE# button once to insert a delay in the dialing sequence of a stored telephone number. A pause is needed to wait for a dial tone (for example after you dial 9 for an outside line, or to wait for a computer access tone). Each pause counts as 1 digit in the dialing sequence. If you need a longer pause, press the PAUSE# button twice.
Deleting Stored Numbers 1. Press the MEMORY button. 2. Press the desired memory location (0-9). 3. Press the MEMORY button twice to delete the entry. 4. You will hear a confirmation tone.
Jan 08, 2009 | GE 27928GE5 Cordless Phone
U600 unable to dial number
typed *2767*3855# this should manu reset the entire main-board.
Mar 10, 2008 | Samsung SGH-X830 Cellular Phone
Lands Phones Logo
82 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
