Question about Hoover F7220900 SteamVac V2 Upright Vacuum
We have a Hoover SteamVac V2 Model No. F7220-0900. It has always worked great and was last used 8-9 months ago; however, when we went to use it the other day it would not dispense cleaner or rinse water when the trigger was squeeezed. We clean all parts and let them dry thouroughly after each use, keep the filters and brushes clean, etc. We have never used the separate hand tool and the current dispensing problem is strictly when the machine is used in the normal carpet cleaning process. I have taken the handle completely apart to check for a broken/pinched wire. All containers, caps and seals seem to be fine. The motor runs, brushes turn and it appears to have proper suction. Could there be a short in the trigger that activates the pump? Could the pump be bad? Could a hose be blocked?
reddevil6
  • 1673 Answers
SOURCE: hoover steamvac model #F5857-900
Is the lid for the tank locked on all the way round? The filter on the underside of this lid should have a 1/4 gap from the lid to the top of the filter. Is the duct in place, front of the tank. Any of these will cause the problem.
Posted on Feb 14, 2008
reddevil6
  • 1673 Answers
SOURCE: Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
Posted on May 26, 2008
  • 3 Answers
SOURCE: Hoover SteamVac Dual V Carpet Cleaner # F7410-900
Turbine assembly is bad. Get part #23 here http://www.vacuumcleanershop.com/hvrmdlf7205900.htm#B2
Not to bad to put in.
You can also find them on Ebay cheaper.
Posted on Jul 01, 2008
SOURCE: Clean water coming out of sides
Hoover SteamVac Ultra (model F5883-900) Threw it away, and had to buy a new machine. Sorry, but I found it more difficult to deal with the housing unit on the machine and just couldn't deal with it anymore. I hope you have better luck than I did with it. I couldn't find ANY help on ANY web sites for this model, just too old I guess.
Posted on Jul 28, 2008
reddevil6
  • 1673 Answers
SOURCE: I have a hoover steamvac
One cause is that the recovery tank lid isn't on correctly and not sealing. If there is a foam filter on the inside of the lid, make sure it has a 1/4 in. gap from the top of the lid. There is another filter, from the bottom, it has a red frame, pull it out far enough to clean it. May have a bad turbine, or the shaft on the top of the brush block broke off. You have a 1 years warranty on this, I would take it in to a warranty repair shop and get it repaired.
Posted on Aug 10, 2008
I have a 1 year old Hoover carpet cleaner . I went to use it today and it won't start. Everything seams to be in the right position. can't figure it out..
Dual Power™ Carpet Cleaner - Hoover
hoover.com/products/.../dual-power-carpet-cleane...
The Hoover Company
Rating: 3.5 - ‎84 reviews
Dual Power™ Carpet Cleaner. Easy to Empty Tank ... You currently don't haveany recently viewed items. ... 3.5 out of 5 stars. ... The Hoover Dual Power™ Carpet Washer deep cleans on the double. ... 1 Year Limited Warranty .... The rinsing stage is a must and it cleaned a 20 year old carpet that was badly stained.
Hoover SteamVac Troubleshooting: Carpet Washer Loss of ...
? 1:19
https://www.youtube.com/watch?v=6TkcWjuz1zw
Aug 16, 2013 - Uploaded by Hoover
Your SteamVac carpet cleaner should pick up as well today as the day you got it. If you're experiencing loss of suction or noticing that your SteamVac won't . ... Hoover 1 year ago ... thank you! worked and i did not have to wait for call center to open! thank ...This machine is running well almost four years in.
Repairing a Hoover Carpet Cleaner ' ThriftyFun
www.thriftyfun.com/Repairing-a-Hoover-Carpet-Cleaner.html
I have a Hoover f7412900 carpet cleaner and one day the brushes stopped working. ...It was a couple years ago, so I don't quite remember, but it was in the manual, ... Itwon't start back up. ... If it is only 5 months old, it is likely still on warranty. ... Do not try to fix this yourself, as you may void the warranty if you start taking ...
Jan 29, 2016 | Hoover Vacuums
Hoover steam vac model f7425-900 filter is
The brush system on this model has a poor engineering design in that the brushes are running off an air turbine, which uses a steel bushing to spin the turbine which gets rusty from the moisture when the machine is being used. No long term solver. I would replace the machine with a Dirt Devil Platinum Force model
Nov 27, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
The scrub brushes dont spin anymore
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine gear will have to be replaced. You can access the turbine gear by removing the hood. You can find a genuine hoover replacement part by following the link below. Just find the model number of your Steamvac.
http://www.usavacuum.com/Hoover-SteamVac-Parts-s/105.htm
Oct 23, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Where can I get a manual on my model#F5817 steam
Here is a number for customer service for Hoover.
contact our customer service department at 1-800-944-9200 M-F 8 AM - 7 PM EST.
I went to their website and searched for a manual. Some of the manuals will cover more then one model so they will have to tell you which one will work for you. Hope this helps
Aug 15, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Brushes do not turn worked , fine last time i used it a month ago.
The brushes are run by vaccum. Take the brush out and there is a passage way in there that could be blocked. If I rememer correctly there is a screen in there. If that dont help then there is a spring hooked to a lever underneath so when you lay the back down it engages caccum to the rollers. It could be that this is stuck and not moving. Try moving it by hand with the scrubber running.
Jun 20, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover V2 SteamVac
Under the detergent side, there is a metering plate,(located on the machine) which can be removed. ensure that this is installed. have you verified whether the machine will dispense detergent only without any water in the water tank?
Jan 03, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=728884
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac Deluxe
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=624426
Posted by providence51 on May 26, 2008
My cleaner is not dispensing the shampoo solution. Still sucks up the dirty water that I manually applied with a scrub brush. I use this on my tiled screen porch floor and it has worked great many times.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac Carpet / Upholstery Deep Carpet Cleaner.
There is a release value in the bottom the holding tank that may be bad and not opening or the trigger assm in the handle may be broken and not connecting to release the water to scrub and clean the carpets. You should really check with your local factory authorized Hoover vac dealer in your area or , please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
May 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes are not moving
You should be able to get a manual from Hoover.
Oct 21, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover F7220900 SteamVac V2 Upright Vacuum Logo
56 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
