Tool to wedge rubber strip into screen door groove
    President:
  • 1,314 Answers
This is what you need.
Obviously, you don't need a 10 pack but you should be able to buy a single one at your local store.
Posted on Jun 27, 2008
How to take out the window weather strip on a vauxhall calibra door
if you are refereeing to the rubber strip on the out side of the glass that you rest your arm on then it just pulls up out of a groove. Installation is to place the new strip in place and press it down into place.. Get the new strip and it will be easy to see how to remove the old one.
May 11, 2014 | Cars & Trucks
How to get keys out of audi 1998 a4 / locked inside
you need a lock out kit for the proper tools. but you can use a door wedge or other wedge shaped object wood, metal or plastic. push wedge in gap at top corner or door frame till you can see though crack. next use a coat hanger undone to push though crack in door hit lock switch,grab handle in cant do either a small strip of emery cloth taped on end of hanger in a loop. slip over lock stem and pull up hard .
Aug 02, 2012 | Audi A6 Cars & Trucks
I can not open the door from the inside or the outside and the childlock is keeping me from opening the door from the inside because the outside door handle does not work
The way the police open a door is by manipulating the release directly, by putting wedges between the glass and rubber weather strip on the window, and then reaching in with a "slim jim", which is a long thin strip of metal.
Some releases go back and forth, while others go up or down.
Go to a junk yard and take a look at the mechanism on a door where the panel has been taken off.
Or take the panel off the inside of your door.
Either way, it is not that hard to do.
You can use an old dip stick as a "slim jim", or you can buy one at a place like Harbor Freight.
Jan 30, 2011 | Hyundai Accent Cars & Trucks
Basically how can i pull the window up manually until i can get money to buy parts
either remove the outer rubber strip on the door to give extra room to access glass take your time using a flat wide screwdriver or slide a lenght of duct-tape down the inside or outside of the glass & use a thin flat fish slice to help stick it to glass.then lift carefully and make sure the glass is well secured with duct-tape & a wedge inside the door!!!!
Nov 23, 2010 | Computers & Internet
Rubber door seal came off along with metal ring. How do we fix it?
If you are referring to the wire hoop with a small spring, this is the front bellow clamp. The bellow is the rubber door seal. Around the perimeter of the seal where it attaches to the door frame, is a small groove in the rubber. Make sure the rubber bellow is properly seated around the door frame opening, then the wire hoop inserts into the groove in the rubber to hold the front of the bellow affixed to the door frame. Without it and the bellow will eventually come loose and the washer will leak. To reinstall, just follow these steps:
1. Make sure the bellow is firmly seated all the way around the perimeter of the door frame.
2. Begin inserting the wire hoop into the groove, starting at the twelve o' clock position.
3. Work your way around the four and eight o'clock positions. While maintaining some downward pressure to keep the hoop inserted in the groove, pull the spring apart and snap the wire hoop back in place.
A second set of hands may come in handy to hold the hoop in position to get it reseated. Make sure the wire hoop ends up at the 6 o'clock position when you are complete.
If you have any questions, please let me know. I hope this helps you.
NOTE: Overloading the washer with heavy items can contribute to premature wear on the bellow and can cause the clamps to come loose.
Dec 30, 2009 | Washing Machines
My washer front load rubber at the door has pulled away and the wire with spring has come out. the rubber is not torn and i put it back in but i dont know were the wire gos
Dec 29, 2009 | Kenmore Elite 45986 Front Load Washer
Rubber boot and spring need put back in
The rubber boot presses on the rim, and the spring clamp fits in the groove behind it. Don't overtighten.
--W/D--
Jul 19, 2009 | Kenmore Elite 45986 Front Load Washer
Can i take apart the door shelves of my subzero for cleaning
You can take them off the door by lifting up and out at an angle but do not try to disassemble them. You can soak them in hot water to try and get rid of spills in the seams.
Jul 12, 2009 | Sub-Zero 650 / O Bottom Freezer...
Remove interior door panel on 2003 BMW 330I. The window is binding. Trying to get panel off so I can see what it is.
I am assuming that you have a 4 door sedan. If you want to remove the front door panel, it is held on with 4 or 5 torx screws, Under the armrest you will see 2 plastic cap covers. Gently pry the covers loose and the screws are inside. T20 I think. Where the inside release handle is you probably have a decorative strip(wood grain or painted plastic). At the end farthest from the handle, use a plastic wedge, or flat popsicle stick to pry the corner loose and gently pull the strip toward you. There will be 2 more screws under it. If your door has a plastic airbag emblem there is a screw under it. Otherwise there should be 1 screw hiding under the mirror switc on the armrest, or mirror switch cover. Using a small flat edge wedge pry between the panel and body at bottem until the panel pops loose.work your way around the entire panel. The top panel near the glass pulls toward you. Once the entire panel is loose, grabbing the armrest,pull the panel straight upwards. Be careful when pulling up as to not pull too far. Your inner release cable is attached on the backside. When reinstalling the panel make sure that the rubber grommets are on the panel clips..they help keep water out.
Mar 15, 2009 | 2003 BMW 330
Kenmore washer need to put rubber gasket retaining spring back on. Any tricks, seems impossible. Peter
I assume that you're talking about the inner spring. It's very tight, so you have to get the rubber gasket (bellows) fitted on the its frame, then push the bellows inside out in toward the tub. Start with placing the spring in its groove at 12 o'clock. Wedge something between the bellows and the white colored weight ring of the tub. You'll need something approx 3/4" in diameter to wedge the top of the spring in place. (I've used a 1/2"X90 degree copper elbow I had laying around that had an approx outside diameter of 3/4"). This will hold the spring in place as you work it around. It is still very difficult and you may have to stretch the spring ever so slightly to get it back into the groove. Once the spring is back on, remove the wedge, fold the bellows back out and attach the fill hose and attach bellows back to front panel.
Jan 02, 2009 | Kenmore 44072 Front Load Washer
Computers & Internet Logo
27 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
