Question about Mitsubishi WS-55819 55" Rear Projection Television
WS-55819 55 vertical hold problem
I just replaced both ic's in the above TV to solve my display problem. However, when I now start up the TV, I get a rapid vertical hold rolling upwards. How do I adjust this to normal?
  • d4knarf Jun 27, 2008
    I certianly will. In the mean while, is there a vertical hold adjustment anywhere on the unit I can try and adjust? If in the service menu, which parameter would I try and adjust?
    Scholar:
  • 167 Answers
HELLO. SOUND' LIKE U NEED TO GO BACK TO WHERE U STARTED.!!! AND LOOK OVER WHERE U SOLDER IN THE IC's. !!! ON THE MOTHER BOARD. & MAKE SURE THAT NONE OF THEM ARE NOT TOUCHING ONE ANOTHER.!!! OR POSABLY .!!!! U COULD OF GOT SOME SOLDER ON THE BOARD .!!!! WHERE THERE SHOULD NO BE.!!! SO LOOK OVER THE BOARD REAL GOOD.!!! AND SEE IF YOU CAN FIND. !! ANY THING.!!! LIKE .!!! WHAT.!!! "AM".!!! TALKING.!!! ABOUT. SOLDER THAT DRIPED OFF .!!! ON TO THE BOARD. WHEN YOU WHERE SOLDERING. THE IC's BACK IN TO PLACE.!!! LET ME KNOW IF THIS HELP'S YOIU. OK. "GOOD LUCK"
Posted on Jun 27, 2008
  • MICHAEL WALLACE
    MICHAEL WALLACE Jun 27, 2008
    HELLO. LIKE I SAID.!!! U NEED TO GO BACK AND LOOK.!!! AT THE CONNECTION'S ON THE BOARD.!!! FIRST.!!! THAT'S MOST LIKLY.!!! WHERE YOUR PROBLEM IS.!!!!! 9 TIME'S OUT OF TEN.!!! DONT TRY TO ADJUST.!!! ANYTHING.!!! ON THE BOARD.!!! U WILL HAVE MORE PROBLEM'S .!!! SO PLEASE DON'T.!!! OK. GET BACK TO ASAP. "GOOD LUCK"
How to solve horizontal lines on a CRT TV monitor and what could be the possible courses for it
Monitor horizontal lines problems usually caused by a defective vertical output/driver ic. A missing supply voltage to the vertical output ic may caused similar faults which is one horizontal line across the display. Dry joints and missing vertical output pulse from vertical oscillator ic also could contribute the same symptom. If you discovered that the protection resistor (usually from 1 to 4.7 ohm) open circuit or burnt, then replacing it won't solve the problem. The resistor burnt or open circuit was due to a short in the vertical output ic. Thus you have to replace the vertical output ic and the burnt resistor together before you switch on the monitor.
Jun 12, 2015 | Televison & Video
On power up I hold the power button down, I can hear some sort of relay kick-on, sometimes a horizontal white line appears across the screen, then it kicks-off, and the red led blinks four times...
White line across the screen indicates that tv got vertical deflection failure problem that may be due to vertical output chip failure. If that kind of problem occurred, tv select protection mode and red light starts blinking 4 times.
Please check vertical output chip in tv main board and replace it to solve tv issue. This job needs soldering work so local tv repair shop will help you.
Thanks.
Feb 01, 2011 | Sony FD Trinitron WEGA KV-24FS120 24" TV
My Panasonic TC-21Z88RBN doesn’t displays the total picture vertically ,when the picture is display it like not in the center of the screen sum of it is disappear in the bottom
Hello
Your TVs vertical output section has the fault. You just open your TV after disconnecting it from the AC mains wall socket, and locate the vertical output section. This section uses an Ic marked as part [IC 401] on the board and its number is LA7840. Just look for any loose soderings around its components legs, and the solderings at the IC legs, which has 7 of them. The IC stated above will be screwed onto a heatsink to radiate heat out of it when it works.
If all soldering point are fine, come towards the IC legs and measure the voltages at each leg. The voltages must be
pin 1= Ground
pin 2= 12.6
pin 3= 24.7
pin 4= 4.4
pin 5= 4.4
pin 6= 24v [vcc]
pin 7= 1.8
All voltages stated above are DC voltages with respect to ground. If any of this voltage is missing, find out the reason for that. If all of them are noted abnormal, IC may be defective, and replace it.
[vcc] stands for main input voltage to the IC.
If you need any more assistance, feel free to contact me through Fixya. Ok.
Dec 07, 2010 | Panasonic TC-21Z88R 21" TV
The vertical hold on my tv goes up and down. The picture still shows but its just in the center of the tv but if i hit the side it goes back to a fullscreen.
There will be some loose contact in the circuit board of your tv. May loose sodering in the vertical output stage; around the ic used. Try resolder almost all the solderings around it will solve the problem. Vertival sync; signal may not absent in the main ic too. Anyway resolder the main ic too. Surely it will solve your problem.
Oct 13, 2010 | Toshiba CF30F40 30" TV
Mitsubishi WS-55857 with a flickering blue edge.
The vertical IC needs to be replaced. You can get new Vertical output ICs at www.tvrepairworld.com and they will also help explain where its located.
Nov 27, 2009 | Mitsubishi WT-46805 46" Rear Projection...
My 15 year old Toshiba Televisiononly shows a narrow horizontal band in the middle of the screen. Sound OK.
Hiii fairley,
You aren't specsificly dercribe yor tv set.
For common TV horizontal problem ;i.e : White line accross the horizontal screen, horizontal band,etc..it's can solved by replacing the IC Vertical/Transistor, and olso to replace the cap nearest the IC.
For common TV Vertical Problem :i.e : White line at the center of the screen (top to bottom),Vertical band,etc...It's can cure by Replacing the Horizontal IC/Transistor,and offcurse the cap's.
Tha's what all I know....
Hope can help you to solved the problem.
Thank's
h3liax
Jun 22, 2009 | Toshiba 32A33 32" TV
Mitsubishi rear projection tv
replace vertical IC and shadows/ghosting the problem is either electrolytic capcitor or video IC or convergence adjustment
Aug 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
No picture on tv screen
try resoldering the vertical output IC. sounds like the cRTs are blanking due to the vertical. If that doesnt help you may need a new IC. While youre there look for signs of the CRt leaking as often it leaks right onto the vertical output section real close to the IC.
May 07, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubushi vs4541 red,blue,green vertical lines no picture,very good sound
Try soldering the vertical output IC, sound without picture usually means vertical output is either defective or has bad solder joints. Does your on screen displays work when you press menu?
Mar 12, 2008 | Mitsubishi WS-48315 48" Rear Projection...
Horizontal line in my TV.
"Guest" obviously has no idea what he is talking about. There is no such thing as "frame section" and if the vertical IC, ramp generator or vertical hold circuits were bad, you would have no vertical at all. If you mean that there are thin white lines at the top 3 inches of the picture, and the top of the picture seems folded back on itself, it means that the pump-up capacitor is going bad in the vertical output circuit. This is a very easy thing to correct but should be done by a qualified tech.
Sep 01, 2007 | Televison & Video
Mitsubishi WS-55819 55" Rear Projection Television Logo
53 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
