My ILO 27" tv will not come on, my power light is on
  • 1,879 Answers
Greetings,
It won't turn ON even for a minute ?
Power Supply problem.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jun 27, 2008
I need to change my Ilo tv from "Digital" to
This is done in the menu through cable or air
Mar 05, 2011 | iLO 3200 32 in. LCD Television
Ilo tv quit - will not turn on
The Problem is with the Capasiters in the power supply bord a total of 9 caps have to be replaced the power supply bord is the one on the right side of the tv in the back where the power cable enters the caps values are 35 volt 1000uf x2 35 volt 470uf x3 16 volt 1000uf x3 and 16 volt 470uf x1 after replaceing thses caps the tv will work like new... i hope this helps.
Apr 09, 2009 | Televison & Video
ILO 27" LCD don't start up.
check batteries in remote, does it click back into stand by when u press power button?
Dec 11, 2008 | iLO 3200 32 in. LCD Television
Ilo 27
If you have the original remote, try the "picture size" button.
Oct 22, 2008 | Televison & Video
Ilo 27 inch tv
I too have the same problem. We've had the ilo27 for almost 2 years and it suddenly decided to not turn on anymore. Red light-itus.
I did find a little trick if you are not so mechanical like me and don't want to risk opening the back. I know this isn't a cure, but you CAN get around this by simply pulling the plug from the wall and plugging it back in. It comes on with remote or manually every time!!!
A little inconvenient, but a way around it temporarily!
Oct 13, 2008 | iLO V27DMBX Television
Ilo 27" lcd tv
If your LCD has a defective power supply module will cause the following symptoms:
No Display and no Sound, Then Power indicate light changes from Green to Red.
Apr 29, 2008 | iLO LCT32HA36 Television
Junk tv
My ilo 27" tv did the same thing (red light on front but would not turn on) and after much frustration looking around on the net I finaly cracked it open. After removing enough screws to remove the back the first thing I saw was the main power board. This board has quite a few capacitors on it and I found 4 of these that had bulging tops. 3 were 1000uf/16volt and 1 was 470uf/16volt. I disconnected all wire connectors from this board and replaced them with parts from radio shack PN 272-1032 and 272-1030. The voltage rating of these are different but ok if larger than the original part. It fired right up when I put it all put back together
Apr 02, 2008 | iLO V27DMBX Television
Ilo-27 lcd
I CAN,T GET IT TO CHANGE CHANNELS. I DON,T HAVE THE ORIGINAL REMOTE SO I HAVE TO USE A UNIVERSAL AND IT WON,T PROGRAM.
Jan 13, 2008 | iLO 3200 32 in. LCD Television
No Power
It might have reset during the night
only thing you can do is be certain it is connected directly to wall plug without a power strip.
or
http://www.funai-corp.com/support/contact.aspx
Nov 28, 2007 | iLO 2600 Television
Televison & Video Logo
Top Televison & Video Experts
