Question about Samsung Office Equipment & Supplies
I am trying to use my scanner for the 1st time and I scanned 24 pages which took quite a long time and at the end my computer advised that these pages are now sitting in c:\documents & settings\owner\my documents\my pictures\samsung\scan06262008_154431-24.BMP I looked at some & they are huge images and how do I access these so I can e-mail them off to someone? When I bought the unit it was all setup properly (May 22nd)No instruction manual came with the unit. bernice.joyce@shaw.ca
I guess that was the way the unit is setup and programmed. I expected to have the scanner setup to automatically send the documents directly into my e-mail, as this unit is in my home office and that would be the only place I would ever want them to go. Then I could forward them on very easily. I had to attach every page of the 24 pages separately into 3 e-mails. So I did accomplish the task. It would be nice to adjust it for future scans.
Thanks anyway:o)
Bernice
250-616-8760
Posted on Jun 27, 2008
Canon 7090C is slow between pages
If the target storage area is insufficient this will happen. Clear disk space, run 'defrag' to make space contiguous and try.
Also if you choose 24 bit color in TIF mode, it will take time to write onto disk leading to stopping in between scans.
S. Mohan, India
Apr 15, 2013 | Canon Dr 7090c Doc Scanner
Hi, I scan documents (recto and recto-verso) using the InformatikScan software and the scanner Canon DR-9080C. When I scan for ex. 30 pages, after 10 pages the scanning process slows down in...
The scanner creates a Raster Image and if it is grey or color, the size is big. After a few images are scanned, the 'buffer' inside the scanner is full. It may take more time to process the scanned image by the scanner if it is 24 bit color. The image is sent to the computer Harddisk and if the disk is full or if it had not been defragged for a long time, the sectors may not be contiguous for speedy writing, This will slow up the scanning. Ensure the disk has large space. 'Scan ahead' slows down scanning speed. (Without scan ahead, the next page is fed only after processing, whereas when selected, just after the previous page is scanned, the scanner start the next one)
S. Mohan, India, Chennai
Jul 04, 2011 | Canon DR-9080C Path-Through Scanner
After selecting the "colour' option,
Color scan files will be huge and it will take quite a time to process. Ensure that there is enough disk space in the computer to speed up the scanning.
S. Mohan, India
I have a 2006 Pontiac G6; 4 cylinder...the check engine light is on and I need to get it off for my emissions test so I need help finding out what the problem is. Ive had the car put on the scanner twice...
when you changed the parts did you have the codes cleared ? as if the comp stored it then it will return and when you put new parts on it took the comp time to test and display new changes.
Jan 19, 2011 | 2006 Pontiac G6
The fisrt page is always black, if you scan more than one page.
If the first page output is black, it could be because of insufficient light (assuming other outputs are okay). May be the light takes more time to get 'on'. Keep the scanner in 'on' position for some time and try if the first page is black. The light has some life and check the user manual if it requires replacement.
S. Mohan, Chennai, India
Oct 15, 2009 | Fujitsu fi-5120C
My Canon DR-9080 scanner is duplicating pages, when it is not set to do that, it is not every page but consistently the 1st page and 15th page. Have uninstalled drivers, re-installed drivers, changed...
Very likely it is the software that you are using. I would run virus scan like Mohan suggested, and then test again. If the problem is not a virus, then I would uninstall the scanning program and reinstall it...or contact the software manufacturer if you have a maintenance agreement with them. There is a good free downloadable high speed document scanning software available if you want to load it and verify that it is a software problem.
Jun 01, 2009 | Canon DR-9080C Path-Through Scanner
Lexmark 1150 Printer
You may be trying to scan at too high a resolution, read PDF @
lexmark.com/publications/pdfs/x1100/eng/ug.pdf
Check page 24, this info PDF is specifically for your model.
Nov 19, 2007 | Lexmark X4270 All-In-One InkJet Printer
Scanner to Pc File Size and Volume Problems
Hello We have been having this same problem when scanning Black and White as well. We have just played around and have changed one of our settings that has seemed to solved the problem for now. Try Properties (on scan settings) then more then click on - Detect Page Size - Image Width instead of Guide Plates Hope this works for you to
Jan 18, 2007 | Canon DR-9080C Path-Through Scanner
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
