Question about Kirby Generation 3 Bagged Upright Vacuum
No suction generation 3
I have a generation3 and it appears to be blowing out dust in the front instead sucking it up.
  • 113 Answers
There is a clog in the line try blowing it out with compressed air
Posted on Jun 27, 2008
How do I make it switch from blowing to sucking
There should be separate openings for suction and pressure.
Jan 24, 2017 | Ridgid Vacuums
My very old 6 us gallon wet-dry shop vac now blows instead of sucks.
connect the hose on the other end where it say vacuum not blow.
Sep 19, 2016 | Shop Vac Vacuums
It seems to be blowing the dirt away instead of sucking it in?
Sounds like it has blockage somewhere in it causing low suction, therefore brush 'blows' dirt away instead.
Jan 27, 2016 | Oreck Vacuums
Why does my hoover steam vac only blow out
Hey there! The cleaner blowing out air instead of sucking is an indication that the unit is not sealed off properly. Follow these brief steps to restore suction to your cleaner.
1. Remove the clean water tank.
2. Recline the handle and let the cleaner lay flat.
3. Remove the dirty water tank lid.
4. Reposition the front panel located on the outside of the tank in the center. It should be flush to the tank, even straight across and pushed down as far as it will go.
5. Assemble the dirty water tank lid back on from the front to the back. The lid should not lift up from the front.
Give it a try! The cleaner should now have suction. Hope this helps!
Jun 02, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Hoover dm6200 blowing air
check your suction hose again, follow it to where it goes into the body of the machine. I assume this will be near where the bagless cannister is. Remove the bagless cannister and look up inside to where the attachment hose should come into the cannister. I believe you are still blocked up there. using a butter knife or something along those lines should free up the blockage.
Also, if that is all clear, try re-adjusting the dirt cannister as it may not be on properly to create your suction flow through the hose.
Good luck and let me know if I can help further.
Jan 24, 2012 | Hoover Vacuums
Brought a dirt devil envision vacuum cleaner yesterday, assembled it and tried to use it. as i am running it, the dirt/dust seems to spread on the carpet/nothing seems to go in the dirt camister. The...
Fro what you say, the unit is blowing instead of sucking, There must be a pipe that is connected to the wrong outlet. Feel where there is suction instead of pressure, that is where your vacuum pipe must be connected.
Jan 30, 2011 | Dirt Devil Vacuums
My Bissell bagless vacuum does not seem to work anymore. It will start to with a suction and then instead of picking up the dirt, it appears to blow the dirt out almost in a cloud of dust and debris from...
this is caused by a dirty air filter and/or a blocked vacume hose ( most of the time the blockage is at the bend where the hose enters the floor sweeper area ) ---
remove and tap out and brush the filter ( or use a air compressor to blow out filter ).
then with the vacume on its side - remove the bottom plate ( like you were going to change the belt ) and use a coat hanger and clean out the hose between the floor sweeper and where the suction hoes attaches. this will restore your vacume to full operation.
c...
Jan 23, 2011 | Bissell 6595 Lift Off Bagless Upright...
Seems to **** up the dirt/dust and simply blow it out instead of capturing it inside
Most of these have an suction hose and a blow port. One blows air, one sucks air. Make sure the suction hose is on the correct port. Also, a dirty air filter will cause the same effects. The filter must be good to prevent the dirt and dust being blow around.
Nov 08, 2010 | Craftsman 17026 Wet/Dry Vacuum
Blowing insteading of sucking
Go online to HOOVER.com and locate your nearest repair facility. Take receipt with you to show it's a new purchase.
Feb 05, 2010 | Vacuums
Dysin vacuum blows air instead of sucking it!
Dysons aren't supposed to clog up, but they do. There a number of ports you can open to see if there are clogs in any of them. Usually a clog is why it will blow air and debris out instead of sucking. You just need to find it.
Jan 05, 2008 | Vacuums
Kirby Generation 3 Bagged Upright Vacuum Logo
245 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
