Question about Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive
Maxtor one touch iii diagnostic code a3dad346
  • 2 more comments
  • usagent86 Jun 26, 2008
    The drive is 160 GB not 120 GB as stated in the question, sorry.
  • usagent86 Jun 27, 2008
    The drive was beeping when copying many GB of data from one external drive to another. I ran chkdsk /f and it found many errors and said it fixed them all. I then ran the maxtor software diagnostics and it gave me this error code and told me to backup all my data and send the drive in for repair. It's out of warranty now. I then bought another mini drive and backup all the data. I then reformatted the maxtor drive with the NTFS and reinstalled all the data, but i still get the error code. I am afraid I may lose data if I continue to use the drive.
    I just tried to copy 20 GB from one external drive to the maxtor and got a "windows delayed write failure" message in the bottom right of my computer screen and the message said it was unable to write d:/$mft
  • usagent86 Jun 28, 2008
    Anyone have any thoughts about how to eliminate the error code A3DAD346 from my maxtor onetouch mini iii 160 GB usb drive?
    Genius:
  • 1,447 Answers
Can you pls elaborate more on the issue you are having with your maxtor HD? thanks!
Posted on Jun 27, 2008
    Genius:
  • 1,011 Answers
Dear Sir/madam,
Stop errors are difficult to diagnose since they are so diverse.
A good place to start troubleshooting is the Microsoft Support knowledgebase.
Experiment with the problem by
  • shutting down the computer, removing the external drive, and working for a while with the drive disconnected
  • checking the Windows Event Viewer for entries around the time the STOP error occurred
  • connecting the drive again once the computer is on and has been functioning properly for a while
  • connecting the drive to a different Windows computer to see if the problem follows the external drive.
click this link for more information
http://support.microsoft.com/search/default.aspx?mode=r&query=stop+error+usb&catalog=LCID%3D1033&1033comm=1&spid=global
Thanks
Good luck
"Don't forget to rate the solution"
Posted on Jun 28, 2008
  • 6,487 Answers
It seems that your hardware is failing already, Did you try running a check utility software that may fix your concern but if not you may need to have this disk replace...
Good luck.......
  • Mark Gil
    Mark Gil Jun 27, 2008
    Follow this:
    1.
    In Windows Explorer, right-click your hard-disk, and then click Properties.
    2.
    Click the Hardware tab.
    3.
    Click the hard disk, and then click Properties.
    4.
    Click the Policies tab.
    5.
    Click to clear the Enable write caching on the disk check box, and then click OK two times.
    6.
    Repeat steps 3 through 5 for each hard disk that is installed in your computer.
    7.
    If the issue is resolved, do not continue with the steps in the "Advanced users section." If the issue is not resolved, continue with the steps in the "Advanced users section."
    loadTOCNode(2, 'resolution');
    This section is intended for advanced computer users. If you are not comfortable with advanced troubleshooting, you might want to ask someone for help or contact support. For information about how to do this, visit the following Microsoft Web site:
    http://support.microsoft.com/contactus/ http://support.microsoft.com/contactus/)
    1.
    Make sure that your UDMA hard disk controller is using an 80-wire, 40-pin cable. For information about how to do this, view the documentation that is included with your computer, or contact your UDMA hard disk controller manufacturer. Test to determine whether the issue is resolved. If the issue is resolved, do not continue with the remaining steps. If the issue is not resolved, go to the next step.
    2.
    Warning Do not change the BIOS settings unless you are very familiar with all the effects of changing BIOS settings.
    Make sure that the BIOS settings are not configured to force faster UDMA modes. For information about how to do this, view the documentation that is included with your computer, or contact your computer manufacturer. Test to determine whether the issue is resolved.
    President:
  • 1,314 Answers
From Maxtor's website:
My Maxtor OneTouch software or FreeAgent software gives an 8-digit (eight digit) diagnostic error code Unfortunately, an 8-digit code from either the Maxtor OneTouch Manager software or the FreeAgent diagnostic/Test My Drive software signals a drive failure. Please be sure to backup the data contained therein as soon as possible and prepare a return order to request a replacement. Remember also that many retail stores will allow a return directly to the store within 30-90 days of purchase.
Note: FreeAgent Pro drives can give false diagnostic failures when tested using the FreeAgent Tools and connected via the eSATA interface. Please see Seagate KnowledgeBase article 5034 for more information.
  • Kevin Shafer
    Kevin Shafer Jun 28, 2008
    The only way to eliminate the code is to replace the drive. Your hard drive has failed and cannot be fixed.
  • Kevin Shafer
    Kevin Shafer Jul 06, 2008
    Please take a moment to rate one of these as fixya. Thanks.
    Brigadier General:
  • 3,614 Answers
Can please describe how you get the diagnostic code...? please kindly provide more info here..
  • 5 more comments
  • micromaster
    micromaster Jun 27, 2008
    In the event that your OneTouch III does not pass the diagnostics, an
    error code will generate that can be used when contacting Maxtor for
    Warranty Replacement Options.
  • micromaster
    if the harddrive was actually new maxtor noted that "In the event that your OneTouch III does not pass the diagnostics, an
    Warranty Replacement Options."
  • micromaster
    Stop errors are difficult to diagnose since they are so diverse. A good place to start troubleshooting is the Microsoft Support knowledgebase.
  • micromaster
    this was from MAxtor Knowledge BAse;
    Sometimes FreeAgent Pro drives will display a FreeAgent Tools diagnostic failure when connected via the eSATA interface.
    By design, FreeAgent drives are not designed to be tested with the
    FreeAgent Tools utility when connected via eSATA. If you do try to run
    a diagnostic test, it is supposed to give a message stating that the tools are only available when connected via USB.
    Due to the many different controllers out there, sometimes the tests
    are available. In these cases, if you test the drive while connected
    via eSATA, you will get a failure every time.
    This does not mean that the drive is failing. Rather, this occurs because the test is not supported when the drive connected via eSATA.
    If you are concerned about the health of the drive, please connect
    the drive through USB and then run the diagnostic test. If this test
    passes then you should consider your drive healthy.
    ...BUT
    sure to backup the data contained therein as soon as possible.
  • micromaster
    -Unfortunately, $Mft errors usually indicate a corrupted partition.
  • micromaster
    if you still info/instruction just let us know.. but for now if you already backup all of your files.. it is better to re partitioned the failing drives, and the re format it again..
    thank you for using fixya...
    micro
  • micromaster
    if you still need info/instruction just let us know.. but for now if you
  • 1,183 Answers
Welcome to FIXYA, could you be more specific to the problem at hand. The diag results that you shared, does it also have description next to it.Kindly post the same.
Thanks
proton
  • Mandeep  Singh
    Mandeep Singh Jun 29, 2008
    Well you have been working on this hard drive for a few days now . The best possible solution to your problem is get the harddrive replaced from Segate. They generally have a 3 to 5 year warranty on external harddrives , depending upon the model number..
    If you have critical data that you would hate to part with. You can contact the following companies for data recovery from crashed and broken hardrives.
    http://www.ontrackdatarecovery.com/
    1 800 872 2599 toll free
    http://www.drivesavers.com/
    1 800 440 1904
    Thanks
    Proton
  • 1,879 Answers
Greetings,
The hard drive is obviously having internal issues.
Further information can be found here.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Hi - I have a Maxtor One Touch III, 500GB drive (3-4 years old) that has backed up my last 3 computers running Windows XP. I'm now trying to connect it to my new laptop running Windows 7, when I run the...
Hi , it seems the 'error code that you are recieving, is due to a 'connection in the {USB}.
Try "Updating the Driver / Software!"
"Go to this "Website!"
Fill-in necessary information.
ie: Model #, Brand, and or Operating System...
"Select the [Drivers] you need from the "List."
View: OneTouch III EMC Vista Update:
View: OneTouch III USB
Read below:
---> "Updates software to run in Windows Vista/XP/2000"
"Download the Drivers!"
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Click here: http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot3-downloads&vgnextoid=35c6069f356d3110VgnVCM100000f5ee0a0aRCRD
Mar 15, 2011 | Maxtor One Touch III 500GB FireWire/USB2.0...
My computer no longer recognizes my Maxtor One Touch III Firewire 400/USB 2.0
go to my computer proeprty then uninstall usb driver and then right clik any driver then clik on scan for hardware then it searches usb and install automatically.
May 22, 2009 | Maxtor One Touch III 500GB FireWire/USB2.0...
Just got new computer w/vista. Cant download maxtor software
Try this link. It has a software for Vista for your Maxtor drive. Download the ZIP version and install it. Hope this works for you .
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot3-emc-vista&vgnextoid=b6623428ab622110VgnVCM100000f5ee0a0aRCRD
May 14, 2009 | Maxtor OneTouch III Mini Edition (R01E100)...
Maxtor One Touch III 320GB
THE PROBLEM IS MASTER AND SLAVE CONFIGURATION .. MAKE YOUR BACK UP HD A SLAVE IT MAY BE A MASTER NOW..
AND IF ITS A MASTER MAKE IT SLAVE
IF IT STILL DOESNT WORK THE CONTROLLER IC ON MOTHER BOARD CAN BE FAULTY.
Jul 28, 2008 | Maxtor One Touch III 500GB FireWire/USB2.0...
Sortware for maxtor onetouch 111 mini edition to install in the maxtor onetouch 111 mini edition not compatible with MS vista ultimate 64bits
Here is the link to download the software for the Maxtor Onetouch III
OneTouch III USB
OneTouch III FireWire 400/USB (all models other than ones starting with FA)
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ot3-maxbu-vista&vgnextoid=c42f69a859d63110VgnVCM100000f5ee0a0aRCRD
Or
OneTouch III FireWire 800
OneTouch III Turbo
OneTouch III FireWire 400/USB models starting with FA
Use this :
Good Luck.
Live, Love, Laugh.
May 11, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
Download and run maxtor powermax, when you run the program it will idenify your hard drives, select your one touch and run the recertify, this will not erase anything but will run a complete diagnostic and attempt recovery of data to recertify as good. If the drive fails I have recovery software I can e-mail you.
Mar 14, 2008 | Computers & Internet
Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive Logo
136 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
