Question about Gateway 450ROG Notebook
Battery won't charge.
I have a Gateway 450ROG and it will not charge the battery. The laptop still functions normally when it is plugged in to the ac adapter. Any ideas?
  • androstarr Jun 27, 2008
    I bought a new battery and it worked fine until the battery was drained (less than a day). I also bought a new ac adapter as well, but the battery still won't charge.
  • 282 Answers
Battery could be dead,standard life for laptops is 1 year
Posted on Jun 26, 2008
Netbook charging indicator light won't light and battery won't charge. AC adapter works on other computers
If the battery won't charge and the laptop won't turn on but the ac adapter works with other laptops, then the problem is the port where you plugin the ac adapter. Some of the laptops has it built in to the motherboard. So you might need to have it repaired by a technician. Or if the laptop is still in warranty, you might need to send it to the manufacturer to have it repaired or replaced. But if the laptop works without the battery, or it will turn on but the battery indicator is not lighting up, you're facing one of these problems.
1. The battery itself is dead. 2. the battery bay is loose 3. the battery itself is loose
Hope this helps...
Sep 15, 2011 | Gateway LT2021u Netbook
Hi, I have a 1.5 yr old gateway NV52 laptop that has stayed in sleep mode for two days...I've tried turning it off and cutting back on but it is still in sleep mode...please help
Hi aiomason.
Remove the AC cord and the battery from the notebook. Re-attach battery and AC cord and power up the notebook. This will clear the Ram memory and force the operating system to "Cold Boot", in other words start the operating system loading up from the beginning instead of resuming from Ram the last time it was active. This proceedure should restore your Gateway Notebook to normal operation. Post back your results and good luck.
Jan 24, 2011 | Gateway 450ROG Notebook
Gateway 450ROG, will not start. Red DVD/CD ROM
I have the very same problem, the Drive light turns red, the screen is "black" and the battery charging light indicator on the front is off. No differance if I'm traying to power up on battery or AC-adapter.
Before this problem appeared I had problems where the laptop was powering off, with no warning, and I had to restart it. This happened several times and was going on for about a week before it died totally. Can it be the CMOS battery on the mother board? Anyone having clue what the problem could be?
Mar 31, 2010 | Gateway 450ROG Notebook
I have a 450ROG and the screen is blank the LED lights come. How do i fix it without paying
Is battery fully charged / plugged in??
Is contrast / brightness control adjusted correctly.??
Dec 04, 2009 | Gateway 450ROG Notebook
Problem Sustaining Power on Laptop
It sounds like it might be overheating. Take some canned air and try blowing it out wherever you see vent/fan holes. Also unscrew any covers and blow out the air this way also.
Apr 07, 2009 | Gateway 450ROG Notebook
450rog will not boot
try device manager
then update for battery
if still having problems you probably need to replace battery
you can take the battery to a small repair shop and usually they will test it for you on the spot at very little or no cost
Please rate me
and let me know if you still have problems
Feb 13, 2009 | Gateway 450ROG Notebook
Gateway 450 ROG will run only on battery.
If it's still under warranty, it's definitely worth repairing. If not, get them to quote for the repair they say it needs before agreeing to it. If their quote is anything close to the current price, I would say it's not worth it.
May 09, 2008 | Gateway 450ROG Notebook
CMOS BATTERY
Gateway 450ROG CMOS BatterySmall internal battery that maintains calendar and clock settings.
PLEASE NOTE: This is not the battery that powers your laptop; it only maintains certain internal settings. If you need a main battery, please refer to the page on our web site for your laptop model.
CMOS batteries are located on the motherboard; if you are not comfortable with the inner workings of your laptop, you may want to consider having the battery installed by a qualified technician.
Here is the link to their site for your cmos battery
http://www.gatewaylaptopparts.com/shopexd.asp?id=1082
Feb 25, 2008 | Gateway 450ROG Notebook
Gateway 450rog does not power on
Sounds like a voltage regulator. Have the system diagnosed at a repair shop. Sorry I know this isn't what you wanted to hear, but is probably the correct answer.
Jan 19, 2008 | Gateway 450ROG Notebook
Won't Charge Any Battery--Even a New One
Check for loose solder connection in the power supply and the terminals that connects the battery to computer.
Sep 03, 2007 | Gateway 450ROG Notebook
Gateway 450ROG Notebook Logo
139 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
