Question about Dell Inspiron 6000 Notebook
No sound Dell inspiron 6000
Did all the basics first checked if it was muted then went to device manager to enable it , then went to dell to reinstall driver, I even did the boot diagnotsic and used the syptom tree diag. and it test fine I even heard sound for the first time, but as soon as windows starts nothing nada
  • Anonymous Dec 25, 2008
    same problem, tried msconfig and no help.
  • 79 Answers
Hi
open RUN from start menu and type msconfig. On the "system configuration utility" open services tab and chk for windows audio and make sure its running, if not then select it and just enable it.
hope this solves ur problem.
Posted on Jun 27, 2008
My laptop dell inspiron.1525 is unable to produce sound.what is the solution.
check if the volume has been muted or else go to device manager and uninstall and reinstall the drivers for the sound .
Apr 06, 2010 | Dell Inspiron 1525 Notebook
All of a sudden I have no sound on my Inspiron 1525..I have been having problems with this model since I bought it. I would like to try to reset it to the factory settings but don't remember how. ("factory...
check if computer is mute, check in sound properties if speaker headphones is selected, check if sound device is detected in device manager. try uninstall reinstall sound driver. to perform factory image, press F8 up to 10 times during the DELL LOGO, select repair your computer, select language then click next, click Dell Factory image Restore.
Feb 23, 2010 | Dell Inspiron 1525 Notebook
No sound on my laptop Dell Inspiron 1300
check if comp is mute, check sound properties if correct device is selected, check if sound device is detected in device manager, uninstall reinstall sound driver, perform 32 bit diags on sound using the drivers disc of comp
Feb 21, 2010 | Dell Inspiron 1300 Notebook
Hi! i need to have an audio to my dell laptop. how can i do that?
check if the speaker is mute or in very low volume. check if correct device is selected for sound. check if sound card is detected in device manager - if ahve driver problem, uninstall and reinstall sound driver
Feb 17, 2010 | Dell Inspiron B130 Notebook
Wireless network connection not working
For some reason known only to Dell, the default setting for the Inspiron 6000 built-in wireless network adapter is 'off' or 'disabled.'
If you used Dell's restore disk to reinstall XP, the radio button is turned off. Go to control panel/system/device manager, find the wireless LAN device, right-click on it and choose 'Properties.' Under 'Wireless radio' check 'on' or 'enabled.'
Go back to Windows network setup wizard and go back through the steps using the 'restore network connection' button. You should be good to go.
There's an EXCELLENT network manager from Cisco named 'Network Magic' that takes all the guesswork out of setting up your internet connection. I highly recommend it. They offer a free trial and I think may even have a 'Lite' version that helps with simple connections without the bells and whistles of the full blown program. I'm not sure about that, but I can't tell you how much time it's saved me troubleshooting and setting up networks for my clients.
Jun 11, 2009 | Dell Inspiron 6000 Notebook
No sound with or without earphones, mute is not on, device manager ok
thanks for you problem,
i think i can help u.
dear frn, don't worry, if device manager looks fine altho you are no able to hear the sound then it is better to uninstall the software driver then reinstall it. coz, if any files of driver is deleted then also it help u to repair it, so plz reinstall the sounddriver. i hope it will ok fine.
ok have a nice day.
good gyee
May 23, 2009 | Dell Inspiron 8000, 8100, 8200 Series...
Dell Inspiron 6000 won't connet wireless network after reinstall
check DEVICE MANAGER if the wireless card have the right driver installed. if you found that the wireless card have yellow exclamation point on the right it means, you installed a wrong driver.
check also in BIOS if the wireless card is enable and the switch is turn on.
press Fn+F2 to enable wireless radio/anthena (funtion key with wireless icon in blue color)
some dell laptop have hard switch located right side check this and turn the switch on.
if you want to see the icon n task bar, go to control panel....network connection...right click on wireless adapter...select properties...check Show on taskbar
Apr 03, 2009 | Dell Inspiron 6000 Notebook
No audio output device
You need to reinstall the drivers. Get these from support.dell.com
Mar 28, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Wifi?
Look on the keyboard and see if it has a key with a symbol for a wireless device. If it does, click it with the FN (function) to enable or disable it.
You can also see if there is a switch on the front or sides of the laptop for a wireless device.
Finally, go to start>control panel>system. Access the device manager. Click the plus next to network devices and see if any wireless devices are listed.
Feb 27, 2009 | Dell Inspiron 6000 Notebook
My laptop has no sound
Do you have the sound muted on your keyboard? Or do you have sound enabled in the system BIOS?
When you look at the devices on device manager, does the sound card show up under audio/video devices?
Jul 21, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
2,050 people viewed this question
Alun Cox
