Have Samsung, Model HCN4226WX. Keeps on losing convergience. At first replacement part cost $400. Have been using part STK-392-040 from Electronix to solve problem at much reduced rate. Have been told by TV repairer who solders in IC's that heat is the problem. Is that true, is there a way to solve this problem so it does noy happen once a year.
    Scholar:
  • 167 Answers
HELLO. .!!! YES I THINK SO .!!! YOU CAN HAVE A COOLING FAN INSTALLED .!!! THAT WOULD BLOW ON THE IC"s .!!! IT WOULD KEEP THEM COOLER.!!! WITCH SOULD MAKE THEM HAVE A LONGER LIFE SPAN.!!! THAN WITH ONE.!!! ALSO . SOME TECH'S USE CHEP PART'S . THAT ARE MADE TO BURN UP FASTER. !!! SO THERE BACK TO FIX IT AGAIN .!!! AND THERE IN YOUR POCKET AFTER YOUR HARD EARNED $$$$$$.!!! SO IF YOU DO PAY TO HAVE IT FIXED MAKE SURE THAT THE TECH USE'S . !!! BRAND NAME PART'S.!!! LIKE THE ONE'S THAT WHERE IN HE SET WHEN YOU FIRST GOT IT. !!! THEY SHOULD LAST LONGER THAN THE CHEP ONE;S OUT THERE.!!! THE TECH'S LIKE TO BUY.!!! TO MAKE MORE MONEY OFF YOU. !!! WELL HOPE THIS HELP'S YOU . LET ME KNOW . OK.!!! "GOOD LUCK".
Posted on Jun 27, 2008
51SWX20B convergys board
Board is not sold--the convergence board will look like attached photo--similar and set will use two of the black STK chips like those in the picture--can be a do it yourself repair--
Let me know if questions as I can help.
Apr 25, 2012 | Televison & Video
The tv looks like it is in 3d. when i try to adjust the convergiance the plus signs on the left are bent
do not play with this tv replace the stk ic chips and the resistors around the stk chips ,cant miss em about 2 inches big with heat sinks on them.
Sep 11, 2010 | JVC AV-48WP30 48" Rear Projection...
SCREEN HAS VARIES RED -BLUE-WHITE- LINE SHOWING, I TRIED USE THE
It needs to be repaired by having the convergence ICs replaced or resoldered (if intermittent).
Parts are STK 392-570. Be sure to use thermal paste on the ICs.
Jul 02, 2010 | Mitsubishi WS-65809 65" Rear Projection...
How do you configure the red convergence for the samsung hcn4226wx/xac- getting the red screen but will not allow to line up
CK 2 resistors on STK convergence Board 2.7ohms if open/bad replace them - then you should be able to adjust convergence.
Nov 22, 2009 | Televison & Video
Press remote to power tv green light comes on than shuts off
Replace Both of your convergence ICs they are big black ICs with STK on them use number on ICs if they are 110s use 180s if 020s use 040s other wise use same number on ics. Parts call 1-800-223-3205 or go to www.electronix.com .YES TV is worth fixing if all 3 tubes are Good.
Jan 03, 2009 | Televison & Video
Samsung p4241w HDTV that will not turn on
Replace Both of Your STK ICs STK392-040s For Parts Call Electronix 1-800-223-3205.
Dec 30, 2008 | Televison & Video
Projectors are out of alignment all colors are working looks 3d
You are going to have to replace your STK ICs convergence ics STK392-560 or 570 Call Electronix Parts 1-800-223-3205 Use STK number on ICs.you will also need some heat sink silicon to put on back of new ICs.
Dec 25, 2008 | Sony KP-51WS510 51" Rear Projection...
Samsung HCM653W
Convergence board will have 2 big black ics on it STK392-110s or 150s Use number on STK s in your set.To get parts call 1-800-223-3205 Electronix Parts.
Aug 25, 2008 | Samsung HCM653W 65" Rear Projection...
2006 42'' Samsung rear projection, Balist????
A Ballast is a circuit that provides voltage to Lamp. Ballasts are only used with TV's with a Lamp. According to your model number this unit does not use a lamp. That model number uses 3 rear-projected CRTs. The most common units with a ballast would be a DLP HDTV.
The Model number you specified HCN4226W is a unit made in 2003. However you stated in your subject line that this was a Samsung unit from 2006. Please verify your model number.
Feb 29, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226WX convergence problem
Having same problem
Part # BP95-00415B Convergence module board ??
Cant locate - 00142
Feb 16, 2008 | Samsung HCN4226W 42" Rear Projection...
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
