Question about Gateway MX6453 Notebook
Smoking computer Notebook just over 1 yr old. About 2 months ago, started having problems with the a/c adapter charging the computer, wiggled the cord then would charge. It became almost impossible to charge, then one night I pluged it in and white smoke came out of the USB port closes to charge outlet. Immediate I pulled out a/c adapter and waited 30 minutes, then tried again, and the white smoke came out of the computer again too. It is a burning electrial smell. The computer still works fine, but unable to charge. It still has a little charge on the computer, so no problem with operating system. Just wandering should I take to a professional, try to fix it by replacing battery and a/c adapter, or just buy a new computer, or whatever. I just need some help!!!!
  • 58 Answers
I would suggest taking it to a repair depot to get fixed. It sounds like something has shorted out on the motherboard. I recommend taking the hard drive out so it doesn't get damaged.
Posted on Jun 27, 2008
Hi i need help plz, i've my laptop do not power when i plug the ac adapter ther' is no ligth
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
May 23, 2011 | Dell Inspiron 2200 Notebook
When you turn the laptop on it turns off with 30 - 60 secs.
Feb 06, 2011 | Acer Aspire 5735 Notebook
Computer is not charging the battery.
Your DC connector is probably loose from the system board:
Jan 05, 2011 | ASUS F8Sn-C1 PC Notebook
Our year old Dell Inspiron 1545 currently won't turn on anymore, for the past week it would not charge so we were just keeping it plugged in. It claimed the ac adapter was unknown, even though we had been...
You have a bad or loose DC connector on the system board:
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
Dec 16, 2010 | Dell Inspiron 1545 Notebook
Asus netbook ac power cord adapter stopped working...no blue light on...not charging computer...what to do and need new one?
You need a replacement AC adapter, it's very cheap online.
1)Output Voltage is within +/- 5% of your old charger's output.
2) Output Current is the same or higher than that of your old charger.
3) Connector tip must fit securely into your laptop.
Jul 15, 2010 | ASUS AC Adapter- Universal Notebook AC...
My power cord does not stay charging while plugged in. Normally I hear the beeping as it conects and disconnects, up to 20 times a minute. Do I have a bad power cord? Is the best result just to purcharse a...
If it keeps connecting and disconnecting, it could be either the power adapter or the motherboard, but chances are it's the power adapter (and that's the cheaper solution too). You can usually get a new power adapter for $15 or $20, and that should take care of your problem.
Jun 01, 2010 | Gateway NV5215u Notebook
Mac notebook won't turn on, completely dead. I've held down the power button and it still won't start. It is plugged in to the wall and it is only a couple months old
As this is a month old I can tell you if the Ident is right a Blueberry Ibook is not a couple of months old, its around 10 years old. If this is just new to you, the possibility is that the power adapter has failed. Remove the battery from the bottome and wiggle the cord in the laptop while holding the power button down. If you hear a chime, either the jack or the cord is no good. If not you need to get the cord tested. If you have a meter you can do this, if not you have to take it to someone or buy a replacement.
Apr 29, 2010 | Apple iBook Blueberry Mac Notebook
Power chord won't charge laptop
If you need to wiggle the cord in order for it to charge, then you have a problem.
If you have to wiggle it at the computer, you probably have either a bad plug on the adapter or the power connector on the motherboard is going bad. This situation will not cure itself. It will only get worse.
Check the voltage at the end of the power adapter cord (the plug where it goes into the computer). If it's constant even when you wiggle the plug, you're gonna be looking for a new motherboard soon. I have actually replaced the power adapter on motherboards, but it's tricky--you have to be really good with a soldering iron!
Mar 22, 2009 | Dell Inspiron 1525 Notebook
Gateway MX6453 Notebook Logo
136 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
