Question about NEC Computers & Internet
Colour shifted on NEC LT150Z data projector during use
  • jbbartley Jun 27, 2008
    Seems to lose a colour. Result is that colours display incorrectly. Clears up foe a time if projector is shut off then restarted, but reappears after a time.
    President:
  • 2,712 Answers
Here is a link to the user manual:
http://www.necdisplay.com/cms/documents/UserManuals/LT150_user_manual.pdf
Check pages E38 and E41 for possible solutions.
Should that not fix the issue, then its most likely a problem with the colour wheel, if not the cables. If this is the case, I would recommend sending it in for servicing, considering that it is an expensive piece of equipment, or you could try contacting NEC tech support here:
http://www.necdisplay.com/AboutNEC/ContactUs/
Hope that helps!
Posted on Jun 27, 2008
    President:
  • 357 Answers
Hi there
Save this image to your computer and the zoom in to read the writing, this will tell you all the possible problems.
Please remember to put a good rating on this post.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
    Guru:
  • 1,894 Answers
Color shifting can be due to both internal and external disturbances of the magnetic field.
if there is any external magnetic objects please remove them and try it.
else it may be some internal parts.
  • 6,487 Answers
Try this one:
1. Lift the front edge of the projector.
2. Press the Tilt button on the top of the projector to extend the Adjustable Tilt Foot.
3. Press and hold the Tilt button.
4. Lower the front edge of the projector to the desired height and release the Tilt button to lock the Adjustable Tilt Foot. · If the projected image does not appear square to the screen then use keystone correction for proper adjustment.
Hope that helps.....
Posted on Jun 26, 2008
  • 58 Answers
Hello frist , the color shifting during useing , that could be because a ba cable , in the cable their is alot of wires eash wire controle a color so when a wire of them get cut , the next wire takes his share to increase his color so , you see the pic. get colored as a hole , like for example , it turns redy , and thank you for using fixya
  • adham said
    adham said Jun 26, 2008
    i advise you to try another cable
  • NEC Master
  • 13,433 Answers
This may indicate a problem in the cable used, try another cable.
If the camble is fine it may be a problem in the lamp / bulb.
But check another cable first and report back.
    Genius:
  • 1,447 Answers
Hi-
What do yo mean by, color shifted? try checking the. have the projector cool down by shutting it off for a few minutes and take out the bulb and reinstall it, try cleaning the air filters as well. If issue persist try hooking it up using a different cable to a different source. keep us posted on results, Thanks!!
My projector Nec model V300X after sometime the colour of the image starts changing and eventually turns discoloured what is the solution to this and what may be causing this
DLP projectors use a light tunnel called an engine. The bulb sends light through this part and the image is gathered from that process. Light engines wear out from heat. I am not able to get any service part info on that machine. You need to contact NEC or replace it.
Jan 23, 2016 | NEC Office Equipment & Supplies
My nec mt810 lcd projector is showing some green colour not sharp colours showing whats problem plz help
It seems that the lcd panels are failed
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Oct 14, 2013 | NEC USHIO PROJECTOR LAMP, Projector Lamp...
Hi there! i have this nec mt1030g+ projector and its video hv sumthing like a copy of image with is like shadow of the real image in blue colour! i wanna know if its lamp fault or sumthng elsa! thanks
It sounds like a polarising lens has failed, if so it will probably be cheaper to buy a new NEC NP115 which has probably got the same if not better specification.
Hopefully I was of help to you
Feb 04, 2011 | NEC MT1030G Replacement Projector Lamp...
The projector is an NEC model VT590 and is connected to my computer for use with a SMARTBoard. In the bottom left hand corner a pink colour is starting to grow inwards. In the upper left hand corner, there...
It is not the smartboard, lamp or the computer as well know, it's the projector itself. This may not work but you at least need to try press the auto adjust button on the projector and then adjust the clock/phase in the menu. If not you will need to send in to NEC it could by the color wheel. Usually they have a warranty for a couple of years.
Jun 05, 2010 | NEC MultiSync VT590 LCD Projector
Red coured picture Nec MT850
I don't think it's globe related, I'd be getting a quote on the electronics.
Mar 23, 2009 | NEC MT850, MT1050, MT1055, MT1056...
Nec picture turns megenta
I'm gonna take an educated guess and say this is a DLP projector. Sounds like the DLP wheel is slowing down causing blurriness and Magenta when the wheel stops. It probably needs a new color wheel. Call NEC and see if they have a bulletin or notice on this issue. If you're lucky, you might get a free new color wheel or replacement projector from them.
Jun 12, 2008 | NEC HT1100 Multimedia Projector
Nec mt 1000
go to menu- go to setting -go to colour move slider to right hand direction befor you change the lamp -take care that some vga cabel(((cabel between pc and projector make this fault).then you have to change this cabel and try.
Mar 09, 2008 | NEC MultiSync MT830 Multimedia Projector
NEC MT800 Projector with Vertical Lines in picture
The ghosting problem is a combination of both the lcds and driver boards in which case neither need to be truely replaced.. They use a specific voltage to transmit data to the lcds.. Each lcd is different and the driver board is programmed by the factory for the EE v.com setting. Unfortunatly with nec, they do not offer a service mode to go in and adjust the ee settings to correct the electrical convergance. So the only way to fix the problem is to replace the lcd with a newer one who wasnt worn out from long term heat.
Sep 22, 2007 | NEC MultiSync MT830 Multimedia Projector
Computers & Internet Logo
79 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
