Question about Olympus Cameras
Hello, my stylus 105 won't load film. it looks like some little piece of plastic in the way of loading film on the left side there , where the end of the film goes in and winds around. Mines silver hope it is the same one. Carri
Decided to get a new digital-Thanks anyway
Posted on Jun 27, 2008
The 35mm strips won,t fit in my holder how should I be inserting them in the holder
The holder that takes 35 mm negative strips on one side and 4, 35 mm slides on the other has a plastic frame that holds the 35 mm film in place. To load film you have to first remove that frame by putting your finger in the opening by the large "A" and popping that end up. The frame fits in only one direction and must be clipped back in by first engaging the two small fingers into openings at the end opposite to the "A" and the lowering the retainer down snapping the 3 sets of 3 clips as you work toward the "A".
Oct 11, 2014 | Epson Perfection V500 Flatbed Scanner
It seems to be catching and making a noice when it hits the left side of the printer. We print 16x20s and you can actually see where it isn't dispursing the ink correctly and making a slight v at the...
I don't know if this will help or not. Remove the paper and look on the bottom where the print head runs across and you will see several small plastic insets that feel like felt. They soak up ink over time and will become hard. I had one curled up and it sounded like the print head was clicking on the side and I had an obvious issue on the left side of the paper. This occurred only with large prints. This is a small plastic film and i just removed the one damaged piece and kept on printing, problem solved or at least put off until the reason for that part is made evident.
Jun 18, 2011 | Epson Stylus Pro 4800 InkJet Printer
Loading film into it.
You pull down on the clip on the side of the camera. That will open the back of the camera. Pull out a little of the film from the canister. Put the canister into the side with the spindle. Put the end of the film that you pulled out over the roller on the opposite side of the camera then shut the lid and turn on the camera.
Jul 19, 2010 | Minolta F10 BF 35mm Point and Shoot Camera
Epson Stylus CX6000 Won't Load Paper.
hmmm am afriad if u had a warrant for it just take it back to them and get a new one...plastic staffs are hard to fix.
Nov 03, 2009 | Epson Stylus CX6000 All-In-One InkJet...
How do you put the film in in a olympus superzoom 105g
Open the back, gently blow out any dust that might have gotten in there. Load film in the shade. Take the film cassette out of the plastic container and insert it with the protruding piece on the bottom into the left side of the film compartment. Gently pull the film out to the right about 3-4 inches. Try to keep the film flat across the shutter opening but Be Careful you don't touch the Shutter Blades! Feed the film under the take-up spindle and through the vertical slot and hook the film into a sprocket. Push down the shutter release button and advance the film a couple times. Close the camera back securely. You are ready to go! Good luck
Aug 03, 2009 | Photography
Paper load
This plastic piece you are talking about have to be squeezed for it to be able to move from side to side, Try squeezing it and see what happens.
Thanks,
Lolita
Feb 24, 2009 | Lexmark Z2300 InkJet Printer
Loading film into the vivitar camera binouclurs
you have to pull up on the film rewind knob(pretty hard) and the back of the camera pops open. on the left side is where the film goes attach the piece of film to the film take up spool.
Jan 12, 2009 | Vivitar V3800N Zoom 35mm SLR Camera
Loading film in my vintage camera..help!
The "magic needles" while making the camera easy to load are about as intuitive as a dead skunk, I had a similar confusion when I got an ME Super. Put the film can in the left side of the camera back (the side with the little thing sticking out is the bottom, it looks upside down this way, but that is correct). Next push the film winder down, this will semi-lock the can into place. Now pull the film-lead across the camera and push it down between some of the white "magic needles on the opposite spool(push it in a bit so that it will stay). Next advance the lever; release the shutter. If the spool starts to turn you are doing it right. Now close the door and continue advancing and clicking until the little frame number window on top reads 1.
May 19, 2008 | Pentax ME Super 35mm SLR Camera
Canon ft-qi
Can you please post the model number for this camera
Mar 30, 2008 | Cameras
Vivitar
be sure that nothing film inside the camera , open back side of camera by pulling spinning knob , put film spool on left side and at the right side insert the film strip on diagonal small hook, turn the spool rachet turning left side then click shutter twice while holding the spinning spool left side , then close the cover , tightened the spinning spool little bit then test shoot.
Dec 25, 2007 | Photography
Cameras Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
