Question about Palm Treo 680 Smartphone
Phone got wet
Phone fell in toilet
  • 1 more comment
  • DA3411 Jul 08, 2008
    HI,
    My Palm Treo got very wet too. It actually went in the pool when I jumped in in to help my friend's son who was 4 and couldnt swim. Saved the boy, but I dont know about my treo. I have the batery back in and the light on the phone is red and solid. The Palm logo comes up and the progress bar goes all the way across, then the screen gpes Black!
    Anyone have any idea? Any help is appreciated!
    DA
  • king_dymonde Dec 19, 2008
    yesturday i got a stain on my pants so i took them off quick to get the stain out completly frogetting that my phone was in the pocket. i put the pants in cold water fro about 2 min before i noticed that my phone was missing. i took the battery out and shook all of the water out. i dried it the best that i could but the only part i could not get to was the screen. i have not turned the phone on yet but im really scred because i barley got the phone a month ago for my anniversary and im scared to tell my boyfriend. what do i do?
  • Baljit Saini May 11, 2010
    1. Don't charge until the unit has totally dried out. Remove as many parts as you can such as SIM Card, Flash Card. Wrap the unit in towel and shake as much water out as possible.
    2. Use a hair dryer on low heat to dry out every part possible.
    3. Recharge the battery.
    4. Check Operation - Hope everything works! If not not post an update as to what function is not working.
    Sniper:
  • 68 Answers
I dropped my phone in a toilet. (It had already been flushed) I did not try to turn the phone back on, instead I took the battery, sim card, back cover off, and put my phone in a bowl of rice with a lid on it, for a couple of days. The rice pulled all the moisture out of the phone. My phone worked fine after that. My battery did have the water mark on it, so I had to buy a new battery
Please rate this solution.
Posted on Jul 31, 2008
  • Jay Tate
    Jay Tate Jul 31, 2008
    Use uncooked rice
Did the exact same thing about 4 months ago. By the next morning, the screen wasn't working. I gave up and ordered an unlocked one from Ebay to replace it. Now that one isn't working right, so I got the old one back out just in case.
Works like a charm! I think I just didn't give it time to dry out thoroughly. Now, if it will just KEEP working....
Posted on Jul 29, 2008
I had a very similar problem when I dropped my phone in a mudpuddle. I could not get it to work at all and I think the connector that is used by the hotsync cable was shorted with muddy water because it kept trying to rngage the hotsync operation even without a cable.
I disassembled the phone as much as possible and got some distilled water and rinsed the unit very thoroughly It is important to use distilled water because distilled water has all of the mineral content removed and is non conductive.
After that, you can dry the unit with a hair dryer, but it is unlikely you will be able to get the water out of the phone that way very effectively. I had access to an oven that had accurate controls and set it at 180 degrees and left the phone in there for several hours.
When I reassembled and turned it on, everything worked fine again. The only thing I noticed was that the backlight was less uniform than before. I think that was because of some of the contaminants from the mudpuddle that I could not rinse free. It is barely noticeable, and I have been runnig great for 6 months since.
I hope this helps...
PE
Posted on Jul 09, 2008
Phone got wet fix
It's probably too late, but first open the case, take out the battery and shake out any water. Then place in a jar of rice (absorbs all the water). Then let it air dry overnight. After all is thoroughly dry, replace battery and try it out. The reason it may be too late, is that with the battery in, electrolysis takes place and damages connections and circuit boards. I hope it's not too late for you.
Mar 28, 2014 | Kyocera Cell Phones
Iphone 4 fell down the toilet - now wont turn on HELP PLEASE
You should not try to turn on the device since it is wet. If you have it might be a long shot that it will work again.
Try putting the iPhone into a bag of rice for a few days. The rice should absorb the moisture and then hopefully it will turn back on.
Hope that helps!
Sep 23, 2013 | Apple iPhone 3G
Phone fell down in toilet. got it out dried with blow dryer but its not charging up now.
This could solve your problem : http://www.wikihow.com/Save-a-Wet-Cell-Phone ...but you have to consider the possibility that the phone is damaged and needs to be rapaired or replaced...
Jun 13, 2011 | Sony Ericsson XPERIA X10 Cell Phone
My phone got wet
put it in a jar of rice for about an hour
Jan 16, 2009 | T-Mobile Sidekick
Sidekick 2008 got wet
I dropped a phone in the toilet once, a T-mobile phone. it took a couple of days for it to dry out completely. Then I snapped it back together, and it was fine. Being that yours just got wet, and not immersed is different though, so you may want to take it into T-mobile and see if they can check it out for you because then you will know for sure what is going on. Good luck.
Jan 12, 2009 | T-Mobile Sidekick® 3 Cellular Phone
I have N 70 and it got wet,do you know a possible solution ?
take the battery out first do not switch on the phone dismandle the phone if u have blower the blow with it in a reduced temperatue make sure all the water are been dryed now reassemble it
Jan 08, 2009 | Nokia N70 Cellular Phone
My phone got wet in the washer machine
When that happened to my phone I was able to open it immediately and set it in an area near my oven to help dry it out. It worked for my samsung phone but not my razor. The samsung was in a front loading washer whereas the razor fell in a (clean)toilet bowl. That may be the biggest difference.
Sep 11, 2008 | Cell Phones
Wet
I've rescued cameras and cel phones from such a fate, but I worked on them while still wet. After they dry, not much hope, sorry
Aug 20, 2008 | Olympus FE-230 Digital Camera
Cell phone
if the phone didn't get wet or u can't see a visibly broken screen then ur lcd may still be working, u simply may need to re seat the ribbon cable that connects the lcd by un screwin the 4 screws that hold the display n pryin in open from the mid section of each side then use somthing flat to lift the connector n replacing it pressin firmly.
Nov 26, 2007 | Motorola Mobility RAZR V3
Palm Treo 680 Smartphone Logo
398 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
