Question about Dell Dimension 8250 PC Desktop
Computer Still Down (Bad PBR)
When this computer was originally bought it didn't come with a startup disk or a recovery disk. At this point I really don't know what to do anymore. I tried all that I could within the power of not having the xp disk. Are there any other fixes that someone could suggest. I really need to get this thing back working. I just purchased 750 or a TB drive and I would like to actually use it in my Dimension 4700 but I don't know what will happen. I got my plate, looking for food for thought served with a few chips. I'll have just a bytes...... just froze one day had to hold power button to turn off now it won't go past the windows power up screen won't load to main startup where tool bar and everything else is i have all the disc's that came with it but no manual all i can get to now is the screens that come up when f1 and f12 buttons are pushed but when i get to those screens i am lost as to what to do and when i try to put driver disc or windows disc in tray the light comes on for a second then nothing can anyone help thanks
  • 282 Answers
The reason why you didnt receive any back up discs because your computer has a recovery partition. To access it,restart your pc,tap ctrl+f11, select "restore".It will format your hard drive and will load factory imag that has your windows and dell apps..if that didnt work,you can request back up disc here, support.dell.com/xpscd
Posted on Jun 26, 2008
    Genius:
  • 1,226 Answers
You problem how to boot your computer in installation disc. you can do this by pressing F12 you can directly got to bios set, try to find out " F2 or Delete or maybe F12" your directed to bios setup.
in bios setup look for priority boot or boot sequence something like that. and then select the "CD ROM" first to boot. and then save and exit the setting. Or refer to your manual for the bios configuration. Manual can be search here:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_P4_8250&os=WW1&osl=en&catid=&impid=
Installing windows is here: http://www.pcstats.com/articleview.cfm?articleID=1435
may this help,
melnavz
Posted on Jun 27, 2008
    Problem Solver:
  • 21 Answers
They will not send you a back up disk dell no longer manufactures thoes i asked.
If yoiu have a Windows P Operating System CD: Insert the CD then when you are able press F2. Now with the arrow keys go to Boot Sequence and hit ENTER. Now you have to use the + and - keys. You want IDE CD-ROM Device on the top. And The Hard Drive can be anyhere but the top. Please make sre you have a check on both the IDE CDROM Device and Hard Drive. To check them hit the SPACE BAR when you are highlighted over them. Now after you do that hit ESC then ESC again and hit ENTER on Save and Exit settings. After it saves and should go to windows loding screen hols the power button to shut off. Now turn back on but begin tapping F12 right after you hit the power button. Now you want to scrool down to IDE CD-ROM Device and Hit ENTER. When you hit ENTER you will be delayed 2 sec then a tiny message wil pop up saying "Press any key to boot from CD". You have to quickly hit ENTER or SPACE BAR because that only stays for a couple seconds. Now the Boot Process will start. Now on the bottom of the screen you will see words like "Press F6 to Repair". DON'T!. Wait till you get a screen with a couple bullet points and alot of words then hit ENTER. Now i believe it takes you to a "Partition Page". On this partition page you should see "Partitioned Space" and more words ten "Un-Partitoned space". If you don't see "Un-Partitioned space" Don't worry. Now scrool down to the Partitoned Space and highlight it with arrow keys then hit "D"then a new screen wil come up saying are you sure hit the letter "L". Now please remember all of your options are always at the bottom of the screen. it will say things like L=Delete or stuff. After ou delete the Partition it will either just take you back to the Partition Page or tell you to press ENTER=Continue or something. If thats the ase hit enter. Now if you DON'T have a pre-set Un-Partitioned space press the Letter "C". Then from what i remember it creates a new one automaticly. If not please read the options at the bottom. It is pretty staright forward. Aftr you create an Un Partitioned space highlight over that with the Arrow Keys then hit "ENTER"=Install. After you do tht Windows XP CD does the rest. After the Formatting is done it will start to "Copy Files". After that is done the computer will automaticly shut down and in some cases you will get a Black Screen with options just hit "Start Windows Normally". Now it will load a Windows Blue screen saying Installing Windows then after thats done it will say Finalizing Instaltion or something. Soon is where you enter your Account name and other accounts. You don't have to enter accounts. You will also set the time and other stuff. Then it will finish and ur done. When you are able to get to your desktop it will do some other loading then ur done.
Please Note: You just Deleted everything on your Hard Drive. You will loose everything.
Thanks, please kindly leave me a vote!
Posted on Jan 03, 2009
  • Colton Gilbert Jan 03, 2009
    To request a Windows Operating System CD please go to
    http://support.dell.com/support/topics/g... Here you need to enter the 7 Alpha-Numeric code off the tag on your computer. here you can chat with a live agent or call 1-800-624-9896 and once you get an agent tell them i need a new Windows XP Operating System CD for my ell Dimension 8250. If they ak why say why.
2 Suggested Answers
  • 36 Answers
SOURCE: Computer Still Down (Bad PBR)
bad pbr means tht the sectors on the hard drive are bad.....u can try running tests on the hard drive by going to the f12 menu & thn contact dell tech support if u get any error msg........else u can get a win xp disc & reinstall the os
Posted on Jun 30, 2008
I got a computer at a yard sale its old but the man who sold it too me didn't tell me it had password and username
if it is a HP computer, and many others, you can turn on the computer and immediately start tapping the F11 key,(before the main screen pops up) - then follow the prompts and allow plenty of time - this takes awhile. this puts the computer back to the original Factory Settings like out of the box. this is a full system Recovery I had a friend with same issue, bought really nice computer but the guy didn't know the password (so he probably bought it the same way!) she did the F11 and fixed the problem
Jun 08, 2013 | Computers & Internet
MY DEL DESKTOP 531 THE DISK CLEANUP HAS NOT BEEN WORKI NG & MY BACK UP HAS NOT BEN WORKING AS I CAN NOT DELETE OR KNOW WHAT TO DELETE BUT I CAN'T DO THAT NOW
Wow! Where to start? First of all if the computer has Windows XP loaded on it that is no longer supported by Microsoft. If you want to re-install an OS (operating system software) I would suggest Windows 7.
May 10, 2013 | Dell Inspiron 531s Desktop Computer
My Dell Inspiron 6400 (Windows XP Home) won't reboot. It's giving me a "Loading PBR for descriptor 1 ... done" line on a black screen. What can I do to fix it. Can I salvage my content / files
Before you use the Recovery CD you need to backup your data because to restoring your laptop will wipe your data off the hard disk.
To backup your data when you cannot boot up your laptop, remove the hard drive and connect it to an USB hard drive adapter. Connect this hard drive/USB adapter into the USB port of a working computer. The computer will see it as an external storage device, you can then open the folders and backup your data.
You can then fit the hard drive back into the Dell laptop and boot up with the Dell recovery CD to reinstall Windows etc.
Mar 04, 2013 | Dell Inspiron 6400 Laptop Computer Core 2...
I cannot get the screen to come on, it is just black but the laptop is on
try removing the battery from th back.wait for like 5 minutes then restart the computer.
else try pressing F8 at the startup if you can go yo the advance boot options.
go to repair my computer..select the language then select the username and password..then in system reco ery optios try startup repair or system restore.
else go to safe mode with networking...there in command prompt type sfc /scannow if you have vista or 7..else if you have the xp in advance boot menu try last know good configuration.
Try the below steps to start the recovery
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
CAUTION:
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
if the above step is not working try to use the windows repair with the oprating system cd.
insert the cd in to thr cd rom, restart the computer
press F12 at the startup it will give you the boot sequence then select the cd
and if none of the things are working contact Toshiba..there might be a hardware issue
plese rate if you find this helpful..thanks
Sep 01, 2011 | Toshiba Computers & Internet
BOOTMGR IS MISSING
try to do power cycle first
ensure that all power source is taken out of your computer then hold down power button for 1 minute
try to open back the computer in safe mode then if it doesn't go tru it means you need to reinstall the operating system then
May 26, 2011 | Microsoft Windows XP Home Edition
Acer Aspire 5534-At first I was having a problem with startup repair. My computer would not startup. So I did a startup recovery and that didn't work, then I tried to return the computer to the...
I would forget about all the recovery options if you dont care about lost data get ya windows disk and boot from that then format and reinstall the lot. If you dont have a windows disk download 1 free from http://thepiratebay.org/ cheers and please vote
May 18, 2011 | Acer Aspire 55345410 Notebook
I want to restore my computer to its factory setting
Some computers will, at startup, tell you to press F11 to recover the computer. This will restore to original factory settings.
If you created recovery disks when you bought your computer, you can use them to do the same thing.
If you have neither, you'll have to use your system disk that came with the computer (if you got one with the computer) and reinstall the operating system. Then you'll have to install all the drivers.
If you have none of these, you are basically out of luck unless you can get a windows CD/DVD
Apr 02, 2011 | Computers & Internet
How do I reconfigure, or restore to original settings?
Contact your Computer Manufacturer and ask them to send you a set of Vista Recovery disk/s.
They normally do that for a small $ cost.
Also, ask them if you have a Recovery Partition on your Computer/Laptop to restore it to Factory settings.
See if a Manual came with the computer, or go to the Manufacturer's website, email or phone them for info on how to do a Recovery.
Normally, you would press F10 or F11 at Startup to commence the Recovery Process..
Another way I have seen on some models is to tap F8, and go to a list of Startup options, and start a Factory Standards Recovery from in there, by selecting the Repair computer option.
Also ask them if it is possible to make Recovery Disk/s from the Recovery Partition in case of Hard Drive failure or System Crash.
They will tell you how to do that.
Each Computer Manufacturer has their own way of making Recovery Disk/s.
Dec 19, 2010 | Computers & Internet
How do I format my laptop
I am thinking you mean a System Recovery rather than a reformat. Reformat is erasing the whole hard drive and having to load the operating system and everything again afterward. A System Recovery is reinstalling the operating system back to factory conditions.
I would try a system recovery before doing a reformat.
If the laptop came with any disks, see if any of them have something about system recovery or system restore. Put them in the cd/dvd drive and reboot. Follow the prompts and 30 minutes later you are done.
If you do not have any disks that came with computer for that purpose, then they are most likely stored on the hard drive partition.
To access this you have to reboot your computer. When your Acer logo appears, hold down the "ALT" key on keyboard and press "F10" at the same time. If you miss it or it does not work, reboot and try again.
If you are successful, the system recovery program will run. Just follow the prompts and in about 30 minutes you will done.
After you are done with the recovery, make sure you reload any drivers for things you might have added to your computer after you bought it. Do not forget to also update windows.
If this laptop is running XP, you will not have wireless until you apply the service packs from windows...unless they already had the service pack bundled into the installation. So there is a chance you might need to connect to your router/modem via a wired connection until updates are done. Thought I would add that in incase you run into this problem, don't want you to freak out and say "OMG what did perpetual have me do to my computer" and use my picture as your new dart boart bullseye.
Good luck, hope this helped. It is a very simple process and will save you a bill from the local computer repair shop.
Sep 12, 2009 | Computers & Internet
Jun 26, 2008 | Dell Dimension 4700 PC Desktop
Dell Dimension 8250 PC Desktop Logo
625 people viewed this question
Alun Cox
