Question about Vizio 42 in. LCD TV
Lcd tv I have audio but no video. Is it worth repairing? The set is only 2-3 years old.
  • gsxus1 Nov 04, 2008
    What does it cost for ITI to repair it
If it is a 42", then it IS worth repairing. Vizio will send someone to do it for you, and it will only take 30-60 minutes. There are THOUSANDS of Vizio repair techs around the country, due to the repair company's procedures. Give it a try....
Posted on Oct 05, 2008
2007 visio tv will flickerimage on and off why wont the image stay on?
if it's a fast flicker, you could either have a backlight inverter problem or power supply problem. The problem with 32" sets Hannah is that they are not worth repairing these days as the prices have dropped like a rock. You can spend more fixing the set than buying a new one! The fact that its a 2007 would make me want to purchase new. Your TV is 7-8 years old and is at the end of its service life. Sadly, LCD TV sets were not designed to last as long as the old tube sets. 5-7 year life expectancy is typical. If I have been of service to you please sign my guestbook page @
http://www.back2lifeelectronics.com/Guestbook.php
Jun 29, 2014 | Vizio L32 32 in. LCD HDTV
Bought sony bravia 6 37" lcd hd tv 2 yrs ago +$1,500 when picture went dark, then out; srvc repair diagntc $75+tx. Now, we hv audio but only one channel wh cannot be seen & remot doesn't work. Were...
1,If you still have the old tv, reconnect.
2 turn on power after connecting cables making sure audio goes into ado and video into video.- very important.
3. do you get the pic, and sound?
4 if you do, do the settings to your choice.
will talk about new if the old does not work, good luck lindamilo.
Dec 25, 2013 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
Spider Crack on Display
That 46" LCD panel will caot you more than the TV iself, you can try contacting www.shopjimmy.com to see if he has his panel in stock, you may have to get the information as printed on the label on the back of the panel.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jul 07, 2010 | Samsung LN46A650 46 in. LCD HDTV
My tv is about 4 months old. 2 days ago it stopped playing audio. I still get a picture. it is an LG 42" lcd.
Go purchase a small radio from a pawn shop with aux inputs. Run the tv's audio through it form the audio outs on the rear of the tv,or from the video sources rca outs. You may have to find somewhere to set it up centered on your tv, but at least you get a better sound for a bargain in comparison to a repair.
Dec 30, 2009 | LG 42LH40 LCD TV
I have a 2 year old Toshiba 32
Your panel is defective.Not worth repair.Try calling Toshiba customer support and see if they will help you.
Sep 28, 2009 | Toshiba Televison & Video
Buffer board on panel
All the flat panel TVs are somewhat made to last less then 2 years. That's why the warranty is only 1 year for most TVs. Every TV is going to need repair sooner or later. So don't get discourage by it.
If you are a do-it-yourself person, it's cheaper than replacing the TV.
Here's the best place to get replacement parts:
http://www.shopjimmy.com/catalogsearch/result/?q=dynex+dx-lcd32-09
May 28, 2009 | Dynex DX-LCD32-09 LCD TV
Olevia tv
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
The inverter is the high voltage board that provides variable power to the backlight lamp. This is the most common. When inverter is faulty you can get no picture, or a very dim picture that can only be seen by pointing a torch light with a 45 degree angle on the LCD surface from very near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
This is quite uncommon, but happens. If the TV had been hit or moved the LCD cable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
This is the board that controls the video signal, it is difficult to test, as there is need to read determined values on IC pins. To test this board you need to purchase a service manual and follow the troubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where you connect the video and audio cables, if a signal board is defective, then you may get no picture on particular inputs located on faulty board.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
May 25, 2009 | Olevia LT37HVS 37 in. LCD HDTV
I have a Hisense 32 inch LCD TV about 3 years old .
Unfortunately, if the panel itself is damaged or defective, the replacement can easily cost the same as a replacement set. Unless you can find another set that has a good LCD but defective boards, the set is not worth the repair cost. Sorry about the bad news.
Dan
Jan 27, 2009 | Televison & Video
Open Questions:
See all Vizio 42 in. LCD TV Questions
Vizio 42 in. LCD TV Logo
208 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
