Question about Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424
Freezer runs all the time
Freezer set on #3 runs all the time temp 0deg. out side walls get very hot.
  • Anonymous Jul 24, 2008
    2 yr. old Kenmore upright freezer has been working fine, until we filled it with a half of beef and 5 chickens. Went away for a while and when we came back a "buzzer" in the freezer was going off. I reached down near the floor on the front right side where there is a switch and pushed it to off. The sound went away. I then noticed the sides and top were extremely hot. I then unpluged the unit.
    What is the alarm telling me???
    Why is the exterior so hot ???
    What should i be doing or not doing??
    James M. O'Connor
    hew12@comcast.net
    Novelist:
  • 161 Answers
I don't have enough information. Use a freezer thermometer and check the temp. If below 0 probably a bad thermostat. Sides getting hot is normal. Thats how it gets rid of the heat from inside. In the summer a freezer can run over 80% of the time. Again this is normal. Another thing to check is the gasket around the door. See if it is worn or torn and is sealing properly. If there are condensor coils under neath clean them check to see if the fan under there is working when compressor is running. (Not all freezers have coils underneath. Some have them in back, Smaller units just use the side of the cabinet.)
Posted on Jun 30, 2008
Why are the sides of my frostfree freezer so hot
the sides is were the condenser is it is called a hot wall condenser try to keep things from the sides so it can run more efficeiant
Jul 25, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
New fridge freezer isgetting very hot on both
This heat is normal. The refrigerator you have in your kitchen will have the condenser coils which get very hot on the bottom or back of the frig. A deep freeze has the condenser coils inside the walls of the freezer. Hot temps are normal when it is running.
Try to leave an inch or so of space around it for air flow and that will help.
Apr 24, 2010 | Kenmore 14.8 cu. ft. / 419 liter Chest...
My freezer is very hot on the sides is that normal ? the inside temp keep on flutering is that normal ?
check door gasket, proper clearance from sides.the more it runs the hoter the sides get.the cooler the room temp the less it will run ect.. does it ever shut off by the control? set control on one and listen for it to shut off wait a couple min and turn it up does it come on if it doesn't it may be in defrost so wait a wile and do it again if every time it's off it won't come on (in defrost) the cold control may be bad what temp is it in there. is it frost free and is there frost buildting up where there shouldn't be it has a defrost problem
Dec 25, 2009 | Frigidaire Freezers
Why does it get hot on the front and the sides it never did that before
If the food is at normal temperature, then what you are describing is normal.
On a chest freezer the condenser coils are embedded in the outer walls, as the evaporator coils are embedded in the inner walls to provide cooling.
This is the very basic principle of refrigeration. One set of coils (the condenser) are allowed to get hot, so the other set of coils
(the evaporator) can get cold.
When the unit is not running, which is most of the time, the walls will cool to room temperature.
Nov 03, 2009 | Haier 7 cu. ft. / 198 liter Chest Freezer...
Freezer temp
Was the condenser fan back there running. It should be when the compressor is.
Is the fan in the freezer running. Check for ice buildup on the back wall and behind the back wall cover on the evaporator coil. Heavy ice here would be defrost problem.
Jul 12, 2009 | Freezers
Freezer outside walls are very hot. Not maintaining temp
Hi, The walls are getting hot because that is where the condesor coils are. The condensor coils are where the heat is disperst that is trap as the coolant pumps through the evaporator coils inside. The fact that it is holding 0 degrees is a good sign. Is this freezer in a garage?
Check the door seals to make sure no heat is getting into the freezer other then when the door is opened.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 24, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer
The condenser or high side is built into the side walls on these modern freezers and refrigerators in many cases. It is normal for the outside walls to be hot when the unit is working. Frost on the inside of the sealed packets of food is from the moisture content of the food. Running the temperature setting to cold will accelerate the moisture freezing to the inside of the food packets. This also is a normal condition.
Sep 15, 2008 | Freezers
Exterior side walls VERY hot
Hi wjjlaw,
ngafm at your service,
Is the hot side th open side or against the wall or cabinet side?
Have you touched this side before in he two years you have this appliance? Or is it that you just noticed it?
And if you can keep your hand on that spot for a long time it is not so hot only warm? If it is not burning your had it is probably just the characteristic of that fridge!
Check if the freezer part is full to the top and packed full.
Freezers can not be so full that you cover the cold air vents usually found in th rear of the freezer.
My advice is only a trained tech can remedy this problem, this time!
If I were there I'm sure I could nail it down!
You need hands on service!
Bless You ,
ngafm,
Please give me a good rating before you sign off.
Thank you.
Sep 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23424 Logo
611 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
