Question about AOC 7F 17" CRT Monitor
AOC model 1770 cable conexion
I disconnect the cable that connects the CPU, the cables came off, I need the connecting diagram for the monitor AOC 1770, the combination of the cables in the connector to the CPU, thanks
  • Anonymous Aug 15, 2008
DIAGRAMA DE CONECTOR VGA
Posted on Jan 07, 2009
  • JOSERUGAMATE Jan 07, 2009
    DIAGRAMA DE CONECTOR VGA.
AOC 2036S won't connect to laptop
Is the cable working? try reducing your laptop screen resolution and connect to your monitor. Your monitor may not support full hd resolutions....
Jan 09, 2014 | AOC 2036S 20 INCH BLK LCD MONITOR
Plug was cut from monitor cable
You don't specify which cable was cut but the easiest repair is to replace the complete cable unless, of course, your AOC monitor has an attached cable that does not disconnect. If that's the case, you'll have to disassemble your monitor enough to access to the internal connections and install a replacement cable
Apr 08, 2013 | AOC 177SA-1 (BLACK) Monitor
Monitor says "no signal"
try to unplug the blue cable and the power cable, then hold the power button for 3 seconds. Reinsert back the blue cable and the black cable then turn it on.If it is no signal in spite of the CPU turned on, contact AOC with regards to monitor since the power supply is busted inside of it..
Jun 23, 2011 | AOC 917Sw 19" LCD Monitor
Monitor flashes the "AOC Eyes Value" logo without evr turning on
Man that really hurts.
Flashing logo of company on monitor screen means your monitor has power but not receiving data. Have to find a way to fix data, may be data cable ( vga cable ) of booting of computer itself
Try few things not sure solve your problem or not but really doesnt hurt to try
First, It looks you have loose VGA cabling. Try removing VGA cable completely and connect again
Link how VGA cable looks like
http://files.sandberg.it/products/images/lg/501-93_lg.jpg
Second, if above doesnt solve the problem, may be your VGA card has problem or your CPU is not booting up. Feel the breeze of fan on SMPS to see if it is working or not.
Hope this helps
May 20, 2010 | AOC 193FW LCD Monitor
AOC color monitor 15in. 5En model. during power on all led lights functioned and no display was observed
u try to reorient ur vga connection it might be a loose connection between ur monitor and ur cpu otherwise ur vga cable is defective...
Nov 02, 2009 | AOC 5 En 15" CRT Monitor
AOC color monitor model 5En...during power on all led lights blinks then stops blinking without display action. all led lights on no more action observed.
actually if u repair an aoc monitor alone without getting connected to cpu once u switch on the monitor all led's will lit on ( green light ) it will remain on situation until u connect the vga connector to cpu that's the time led's will lit off and only the power led will remain in green condition.some aoc 5en once u power on power led is in green condition and if not connected to cpu it will be in orange condition.hope u get some idea but i am not sure if it will work with ur monitor. but as long as LEDs lit on i think no problem with ur monitor.
Monitor has solid green LED, but no display
you have to test the processor functions. therefore use post diagnostic card via PCI or PCIX or USB for the check hexa codes, if you show codes the processor ,ay be ok, also have to check the code function by card manual. and replace the unit that failure.
Mar 12, 2017 | AOC LM-800 18" LCD Panel Monitor
Mymonitor is an AOC 1770 CRT, it have a light
make sure you dont have a bent pin on the cable where it plugs in. a bent pin will make different things happen to your colors. if the whole thing is tinted, yellow, or purple it usually is an issue with the plug. also, if you have an old screen plug it in and eliminate the video card as the culprit.
Jun 19, 2009 | AOC 1770 17 in.
Aoc1770 monitor
Dec 16, 2007 | AOC CT700G 17" CRT Monitor
Monitor Repair
Dec 14, 2007 | AOC CT700G 17" CRT Monitor
AOC 7F 17" CRT Monitor Logo
769 people viewed this question
Top AOC Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
