Question about HP PSC 2210xi All-In-One InkJet Printer
Me again 2210xi all in one fax problem
Thanks Bob, but my 2210xi all in one does not have a auto answer option??...under basic fax set up my options are: date/time fax header rings to anser paper size tone or pulse dialing ring and beep volume...I can't find anything to turn on or off the auto answer...I can easily find the distinctive ring, have set but still doesnt work...Is my fax set up right?...I have 1 incoming line with two numbers 8383 fax rings 2 times...6785 phone rings once (that feature works) also have an answering machine.(that feature works)...on the incoming line I have a splitter one line goes to phone, one to fax...answering machine just to phone...do I need the one line to run through the phone to the fax??
    Scholar:
  • 137 Answers
The "tags" says no dial tone, so I wonder if you can send faxes? If not I would suspect the connection is not correct. The preferred setup would be to connect the phone line from the wall to the line input of the 2210 and then plug the phone (and answering machine) into the phone output on the 2210. Looking from the back the should plug into the jack on the right and the line to the wall should plug into the jack on the left. It is possible (??) that the 2210 will not present an autoanswer option if an active phone line is not connected. You can see the setup instructions for the Fax here. Note HP recommends using only a 2-wire phone line.
Also, do you have DSL on the same line? This can cause some issues.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Posted on Jul 03, 2008
How do I turn off the auto answer for the fax option----The fax sounds if I manually answer the telephone
Press the auto answer button until the button lits off/button light goes off.
Or got to front panel press set up button
go to basic fax or advance fax
look for auto answer and choose off
power off then turn the printer on to make sure the settings takes effect.
hope I helped you in simplest way I know
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
Apr 10, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Is it poss. to disable the auto answering machine in old fax (with a phone) model 372 I think. In the man. book this option dosn't shown. Thanks, Rony.
There should be a button near the top left side area on the front of the printer that says "auto" and/or has a little red light next to it. When the light is on the printer will auto answer. Push the button until there is no light on and this should turn off auto answering.
There are a few models that do not have this button, but they still have the option on whether to automatically answer or not. It is just accessed a different way.
If you find you have a machine without an auto answer button and wish to turn this service on and/or off, press the "menu" key on your printers keyboard and use the arrows to scroll through the options available. When you the "basic fax setup" press the "enter" or "ok" key on the keyboard. Then continue using the arrow keys to scroll the options until you find the "auto answer" on or off feature and again press the "enter" or "ok" key to change it.
Some machines have two fax setup catagories. If you cannot find the auto answer key in this area, scroll with the arrow keys to find the second one and try there. I have found that some say "basic fax setup" and have another catagory on "advanced fax setup" ect.
Mar 20, 2011 | Panasonic KX-FM131 Fax
Our HP 2140 fax under distinctive ring setting DRPD was answering under our Master ring (double Ring) until yesterday it switched inside somehow where it now answers regular phone ring instead of...
Was the fax plugged into another telephone line? Maybe a power surge?
My solution would be to reconfigure the fax from scratch to learn the ring pattern.
From the Manual:
Step 1-Teach the HP Fax the ring pattern
The HP Fax will learn the ring pattern when you call it from another telephone or fax
machine.
1. Be ready to call the fax machine.
2. Press Menu repeatedly until BASIC FAX displays and press OK.
3. Use LEFT ARROW - RIGHT ARROW BUTTONS to scroll through the options until DRPD Mode displays and press OK.
Call this fax from another fax machine... Waiting Ring...
will display.
4. Call the HP Fax.
DRPD OK will display when the pattern has been learned and the HP Fax will return
to Ready mode.
Step 2-Set up distinctive ring (DRPD) answer mode
Once you have activated distinctive ring, it becomes one of the answering modes you
can select by pressing the Mode/Contrast button.
Press Mode/Contrast repeatedly until DRPD Mode appears in the display.
• In Ready mode, DRPD appears in the right hand corner of the display.
• Now, the HP Fax will manage calls and faxes as if it were set to AUTO mode
(AUTO mode on page 28)
TIP: Distinctive ring must be set up again if you reassign your fax number
or connect the machine to another telephone line. Once set up again (that
is, the fax machine has learned the ring pattern and the answering mode is
correctly set), you should test the fax machine by calling the fax number
and another number on the same line. The machine should respond
appropriately to a call placed to the fax number with fax tones, and to a
normal telephone call with the expected ring pattern.
Mar 04, 2011 | HEWLETT-PACKARD HP 2140 Fax
I am unable to send a fax brother intelifax 775 fax manual
go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 24, 2010 | Brother IntelliFAX 775 Plain Paper Thermal...
Cannot receive faxes
Thanks.
Have a good day
Dec 23, 2010 | Office Equipment & Supplies
Can't receive faxes
Thanks.
Have a good day
Dec 22, 2010 | Brother Office Equipment & Supplies
How do I set up the fax feature?
Introduction The HP All-in-One can receive faxes automatically or manually depending on the Auto Answer setting. If the Auto Answer option is set to On (the default setting), the HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Refer to the given instructions to receive faxes automatically or manually. Receiving faxes The HP All-in-One can receive faxes automatically or manually. Receiving a fax automatically To receive faxes automatically, set the Auto Answer option to On (the default setting). The HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Receiving a fax manually If the HP All-in-One has been set up to receive faxes manually (the Auto Answer option is set to Off ), or you answer the phone and hear fax tones, use these instructions to receive faxes.
  1. Make sure the HP All-in-One is turned on and you have paper loaded in the input tray.
  2. Remove any originals from the document feeder tray.
  3. Set the Rings to Answer setting to a high number to allow you to answer the incoming call before the HP All-in-One answers. Or, turn off the Auto Answer setting so that the HP All-in-One does not automatically answer incoming calls.
  4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
  5. When you hear fax tones from a sending fax machine, do the following:
    1. Press Start Fax Black or Start Fax Color on the control panel of the HP All-in- One.
    2. When prompted, press the down arrow to highlight Receive Fax Manually , and then press OK .
  6. Press Start Fax Black again.
  7. After the HP All-in-One begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
    Trust this is helpful. Please vote. :)
Dec 11, 2010 | HP Photosmart C7280 Laser Printer
How do you change the number of rings, so that the fax will pick!
Thanks.
Have a good day.
Apr 28, 2010 | HP OfficeJet J4580 All-In-One Laser...
Will send but won't recieve fax Lexmark 5600 6600
Thanks.
Have a good day.
Mar 13, 2010 | Office Equipment & Supplies
Fax machine
You need to set the machine up to AutoAnswer as follows per HP:
Receiving faxes automatically If the Auto Answer option is set to On , the unit automatically answers incoming calls and receives faxes after the number of rings specified by the Rings to Answer setting. Press Auto Answer to turn on the Auto Answer option. 1: Setting the Auto Answer option
  1. 1 - Auto Answer button
    NOTE: The Auto Answer button is lit when the Auto Answer option is turned on.
  2. Press Auto Answer again to turn off the Auto Answer option.
Dec 30, 2008 | HP Officejet 6310 All-In-One InkJet...
HP PSC 2210xi All-In-One InkJet Printer Logo
93 people viewed this question
Ben Johnson
