Question about Kenwood 107VR
Won't turn on!!!! I need my music.
I've had my surround reciever around 8 years and for some reason when i push the on button it will turn on for a few seconds then it will turn right back off.when it is off the stand by light flashes on and off.it just wont turn on.is it in some kind of locked mode or something?
    President:
  • 624 Answers
Not a locked mode, your receiver is in the protect mode.
Try disconnecting the speakers and see if it turns on and stays on. If it does, yu have a bad speaker connected. Then you need to start connecting speakers one at a time, turning the unit off to plug a speaker in and then turn it back on after the next speaker is plugged in. When you get to the time when it goes back into protect, the last speaker you plugged in is bad. Take it in to be checked and fixed if possible.
If the unit goes into protect with all speakers disconnected you have a problem with the receiver. Most of the time it will be the amplifier circuit, sometimes other problems. In any case, it will need to be serviced by a professional technician. Sometimes these problems can be fixed for as little as $65 if it is very minor. In more severe cases it could go up to $200, it just depends on what the exact problem is and what kind of rated the service center charges. I have seen these type of receivers sold on ebay for as little as $75 used. That may not be a bad option, because you should be able to use your speakers with most any other type of stereo receiver.
If you need any more help or advise on what you should do with the receiver I will be happy to assist you. If this information was helpful to you a rating of "FixYA" would be appreciated.
And if you want to contact me again you can always just click on the "Ask me" below my picture or find me on the home page by clicking on the "Find Experts" link right below the top 5 experts section. I am on page 4 right now (I am new here, about 1 week), in time I will be on page 1.
I have been repairing car and home audio equipment for over 17 years at factory authorized service centers for most brands including Kenwood.
Thanks,
Dave
Posted on Jun 26, 2008
Element tv code direct tv
Not following... This is what I think you may be saying: You can't get the TV to use the RCA input?
The reason for my confusion is "rca surround sound". RCA will only carry left and right channel (stereo). It can't push surround sound unless it's setup as a direct input [typically an 8 channel input, where you would have 8 RCA cables (or 4 pair) connected].
The headphone jack, if using a 4-pin headphone jack (it has 4 sections of metal, vs a 3-pin, which only has 3 sections of metal), may be able to send something closer to surround sound, but it wouldn't be a true surround sound. You would need to use fiber optic, HDMI, DVI, or digital coax cable.
The sound settings in the OS on the computer need to be set to push the surround sound, or it will only push stereo. You'll probably need to spend some time there testing all the setting options.
Oct 19, 2013 | Computers & Internet
I've got a Sony STR-K880 Cinema surround system and the remote control won't work it anymore! The only thing it will do is turn the system off when I push the'AV I-O' button and the &#
I had the same problem. Found the fix in this document
STR-K880 service manual
On the amp, while powered off:
"While depressing the INPUT MODE button, press the POWER button to turn on the main power."
You may need to do this more than once.
This switches command mode between AV1 and AV2.
Jul 08, 2012 | Sony Audio Players & Recorders
I've got a 4 yr old Roper electric dryer that won't start up. The belt is fine and the drum spins freely. When you push the button to start it will hum but won't turn the drum. I've got...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 03, 2011 | Roper RGX4634KQ Gas Dryer
I want to record an MP3 CD, or a Music CD and be able to hear it with the Surround Speakers, not just Left and Right, for some reason whenever y insert a music CD the only speakers that i hear are the Left...
Press the surround button and change the surround mode to Dolby Prologic Music or Movies.Since there are only 2 channels in your MP3 disc and music cd the systems default setting is stereo.
Use your DSP ( Digital Sound Processing ) function to create 5.1 from 2 channel source.
Mar 14, 2011 | Audio Players & Recorders
Changing from 2 channel to 5 channel
dear friend. try to push the surround button. and select movie or music. else you can try reset from the main menu pressing setup the unit to factory settings. if that not work the problem maybe is on the amplifier unit.
Aug 03, 2009 | RCA RTD258 System
Problem with speaker wires making contact in back of reciever on
Open up the receiver and check for poor solder connections @ the spkr junctions.
If you can solder, then solder a pin that is THICKER than the wire to it, the Bose wire is fairly thin and the spring clips don't clamp to heavily to thin stuff.
When you push the surrounds in you bottom them out in the connector. Having a thicker wire will eliminate the problem, use a piece of 12ga solid wire from house wiring. Make as many as you need and shrink tube all connections after soldering. Use White for + and Black for -.
Larry
Jan 29, 2009 | Technics SA-AX530 Receiver
To connect Asus Notebook to Yamaha RV-502 Av Reciever to play music
Hi, Most notebooks have a 1/8 female plugin from your audio card. (headphone Jack)
Now, you need a cord with a 1/8 male plugin on one end and two RCA Jacks on the other.
All you need to do is connect the cord to (AMP) RCA in and the 1/8 Jack to you notebook.
This will work fine. Good luck
Oct 12, 2008 | Computers & Internet
Speaker Channels? STR-DE505
Hi There,
Maybe can clarify the reasons you have different output configurations.
I worked for Dolby in London for ten years and cinema processing was an area close to me.
To cut a long story short;
The number of factors and different combinations possible for a fully equipped cinema offering Dolby and / or other protocols to the guest is large to say the least even within the Dolby formats.
For Sony to try to offer a range of home units (recievers or tuner/amps/decoders in this case) was to say the least ambitious .but hey!..........who else can give the public what they think they need.,,,good old Sony
I have looked at this unit and it seems the "amplifier section" is used for various configourations
and power output ratings vary depending on the configuration you choose.
Stereo 2 ch L+R is 2 x 75w
Surround requires more channels (centre and mono rear) and of course new signal routing to and from these blocks which of course will draw from the modest power supply.
So 4 channel surround will deliver 4 x 50w.
etc. etc.............what you hear are the relays which are reconfiguring and re - routing the signals.
Basically you cant have all the sections working all the time due to cost /design restraints
So speakers A OR B can be used but not BOTH when in surround mode....where the centre and surround are needed. .you cant have A and B at any time....push both buttons an NEITHER will work ....release one button and there you go.............it saves "letting the smoke out of the box".........which you should never do...........cos they never work without it. :)
Sorry for boring you ...............but I think you will find the unit is working just fine.............you could read the manual but that's not too informative.
Right...off to get a life now
Nik
Aug 01, 2008 | Sony STR-DE505 Receiver
Shows to be stuck in Standby.
hold down the enter button and the advanced surround button for 5 seconds or so and the amp will restart, the display will come up and hopefully it will be ok. its often caused by using speakers under 8 ohms, or damaged speaker cables etc
Mar 20, 2007 | Pioneer VSX-D712 Receiver
Kenwood 107VR Logo
194 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
