My attic fan failed to work. I replaced the motor and it ran great... for about a day. This is a problem I've had 3 times already and each time I replaced the motor, it blew out again before the season ended. What could the problem be?
  • 828 Answers
Your problem could be related to the supply voltage to the motor. Have it checked or check it yourself with a volt meter. Voltage with the motor operating should be with-in 10% of the nameplate of the motor.
Posted on Jun 27, 2008
Hi, I have an older mobil home with a Colman AC
Your unit uses both the capacitor and a contactor (relay) to start your compressor and motor. With the indications you are giving it would either be the capacitor or the contactor - and since you have already changed the cap - then replace the contractor!
NOTE: We always recommend that you change the capacitor and relay at the same time, because they seem to fail at about the same time.
Jul 28, 2011 | Coleman Heating & Cooling
I just installed a master flow attic fan. I ran
Sounds like it could be a bad capacitor (black box on side of motor).
Jul 19, 2009 | Cool Attic Dryers
Replace old attic fan motor, or replace the entire fan assembly.
I am assuming you replaced your fan by now. However in the future call Gibraltar Industries, they are the ones who manufacture all fans and motors. My attic motor fan also died and I first called Ventamatic and they wanted $65 for a new motor. I then called Gibraltar and they shipped one our for free. 800-527-1924.
Jun 26, 2009 | Ventamatic Gable Mount Power Attic...
Our Eiki LC-986 projector has worked flawlessly for at least 3 years. Last week, the projector shut itself down after approximately 30 minutes of use. This happened at least 5 times, so we replaced the...
It sounds like it is overheating. Are the fans all working? If so, try opening the casing and blowing all the dust out with a can of air from Staples/Office Depot. If the fans aren't working you may need to replace them.
Jun 15, 2009 | Eiki LC X986 Multimedia Projector
Mouse in vent fan?
Yes, the mouse was probably attracted to the warmth and food odors in the duct work and may have gotten trapped in the vanes of the fan and died. I'd act fast...
The best bet is to remove the oven from the wall, or almost from the wall, so you can see the area of the hood vent exhaust fan.
This is safer with two people and the installation instructions will be of great help.
You can download GE owner's manuals and installation instructions here.
Dec 09, 2008 | GE Advantium 120 Convection/Microwave Oven
Attic Fan Repair
All attic fans, by enforced standards and codes, have a thermal fuse. Most are one time fuses wich trip usually when resistance to the motor reaches a peak point. This almost always happens when your motor gets older and needs to be replaced. Resistance occurs and progresses when dirt,dust, grime ect build up on the once freely spinning system. There are some savy folks on the web that get into soldering on a new fuse but at the risk of time, fire and electricution... you'll be better off buying a replace motor and putting your faith in the professionals.
May 26, 2008 | Dryers
Attic fans
I just fixed a Broan-353 with a similar problem - the fan was short-cycling, turning on and off within a minute or less.
These fans have a thermostat which is designed to turn off 10 degrees below where it's set to turn on. Apparently, one failure mode is this temperature delta stops working I've had this happen twice, each time after about 3 years.
Replacement thermostats are available from Broan for about $30 It's a 10 minute repair if you have easy access to the fan.
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
