Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
Replacing a screen
I have a hp pavilion dv2000. How hard is it to replace the screen? Is it worth it? I leaned on it while it was closed and now I have a ruptured crystal display. It's usable but annoying.
  • Anonymous Jun 26, 2008
    My laptop is a Compaq Armada and the screen was broken when a metal object fell onto the screen. Is it repairable?
  • 41 Answers
You can get replacement LCD screens and instructions here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ViewObjectID=56222
Posted on Jul 06, 2008
Im on a laptop and the back light usually just flickers but the screen has gone dark and i have to use a flashlight to see the screen.
Replace the Inverter, rickeyjsmith.
An LCD screen cannot produce enough light by itself. An additional light source is needed.
A Backlight is the additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp. (Lamp = Bulb)
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale in physical size.
(Average size is 3 to 5 inches long, and half the diameter of a No.2 pencil)
An Inverter is used to provide power to the LCD screen, and the Backlight.
90 PERCENT of the time the Inverter is the problem.
Which is a Good thing.
The Backlight is located inside the metal frame that hold the LCD panel layers together.
Usually on one side of the LCD screen.
{Some LCD screens require Two Backlights}
Replacing a Backlight is a job for a trained repair person.
The LCD screen is a composite of layers.
http://solutions.3m.com/wps/portal/3M/en_US/Vikuiti1/BrandProducts/secondary/optics101/
A lot of times the LCD screen is replaced for Backlight replacement, because some LCD screens require this.
Backlights cost more than an Inverter, and of course an LCD screen costs much more.
This is an example of an Inverter for an HP pavilion dv2000 series Notebook PC,
http://www.buy.com/prod/new-usa-lcd-inverter-hp-pavilion-dv2000-dv2100-dv2200/q/sellerid/23962916/loc/101/217117085.html
The above is ONLY an example.
An Inverter MUST be matched to THE LCD screen.
Stating Pavilion dv2000 is only stating the series.
The EXACT Product Number is located on the bottom of the laptop in a white Service Tag.
P/N = Product Number
Also, there is an HP part number on the Inverter.
Match the HP part number to the listing for the Inverter you are going to purchase.
A reputable seller will list THE HP part number so that the buyer will purchase THE correct Inverter.
How to replace an Inverter in an HP Pavilion dv2000 series Notebook PC;
1) Service Manual
I'm going to use the HP pavilion dv2000 CTO Notebook PC as an example.
The Service Manual is the same for All of the Pavilion dv2000 series of Notebook PC's,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=1817074&
On this page click on the file name >
HP Pavilion dv2000 Notebook PC Maintenance and Service Guide.
After you click on the above link it may take up to 30 seconds, or more, to see the first page.
In the meantime you will be viewing a blank white page.
The PDF file is downloading in the background.
In the Bookmarks menu to the left, click on the + sign to the left of >
Click on the + sign next to > Removal and Replacement Preliminaries
Read up on Anti-Static Precautions
Now go back, and click on the + sign next to >
Removal and Replacement Procedures.
Scroll the sidebar down, and click on > 5.12 Display Assembly
Direct information on replacing the Inverter is on Page 152.
(Page Number Box at the top of the PDF file, to the right of the blue Down Arrow)
I use a computer pick to ease up on one side of the rubber Screw Covers. You may have a similar device you can use.
If you are careful with the rubber Screw Covers, you can reuse them.
There is a contact cement on the covers.
Lay them down glue side up on a piece of paper.
(They do like to stick to the computer pick, and your fingers, however. Giving you a 'heads-up'.
Try to keep the glue side from picking up debris, however)
If you need guidance, no matter what it is concerning this procedure, please post in a Comment.
One more thing that pertains to the HP pavilion dv2000, dv6000, and dv9000 series of Notebook PC's, that I think you should be made aware of,
http://www.youtube.com/watch?v=bnkQNmKauEc
Regards,
joecoolvette
Dec 05, 2010 | HP Pavilion dv2000t Notebook
Hi, i have an HP Pavilion dv2000 & it had recent motherboard problems, so I had it repaired in the HP Service Center. They replaced the motherboard & so far, everything was okay until yesterday....
Yes, the GPU is faulty. either replace the systemboard or reflow the GPU. Second option is cheaper and you can do it yourself. There's a link for a diy guide to fix that issue.
does your screen look like this?
http://bootmylaptop.com/hp-pavilion-dv2000-with-display-issue/
Jan 30, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
HP pavilion dv2000 hangs with startup screen and when i do force shut down it gives beeps until i remove the battery and the the light is keep blinking on my laptop
hello..i think their is the problem hardware on the unit..try to remove the memory and try to clean or try to replace..thanks...and Good Luck..^_^
May 13, 2009 | Dell Latitude D600 Notebook
Hp pavilion dv2000 notebook will not boot up
Go to this Hp website for you could have a grapgics chip fault. One way to test is to plug a VGA monitor into the VGA outlet port on the upper left side of you laptop and start it up. If you get a clear display you have a screen problem - next step remove the external monitor and again boot up but in a darkened room to see if your backlight is off - if you can just see the HP logo in the back ground then your backlight has failed or more rightly - the backlight micro switch under your R/H hinge has failed. A cheap fix. If there is no display external or TFT your Nvidia graphics chip has failed. m/board replacement required BUT you may qualify for free m/board replacement under Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} HP Pavilion dv2000/dv6000/dv9000 and Compaq Presario v3000/v6000 Series Notebook PCs - HP Limited Warranty Service Enhancement go to this site below to see if you qualify
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Mar 07, 2009 | HP Pavilion dv2000t Notebook
HP Pavilion dv2000 Screen Flicker
Please replace the screen for optimal performance.
Do rate this.
Feb 25, 2009 | HP Pavilion dv6000z Notebook
hi,
i m in Hong Kong. The stupid HP repair center charged US 90 just for inspection!!!!! They they said the whole motherboard had to be replaced, thts additional US 630 dollars, the thing is just 1.5 yr old. They also said i don get to keep the broken mother board after replacement. This is simply irresponsible, unethical, sleazy and UNJUST!!
Thanks. right now the computer is fixed for US70. when i hv time, i'll open it up and see if i can figure it out how it was fixed. The shop suggested tht the computer wont last too long. This is such bad quality for HP... Sorry, i hv to do the following for other victims to find this easily:
(can some creative netizen bring this to the public light to pressure HP to do the ethical things??)
bad quality HP. hong kong HP pavilion dv2000 series manufacture problem. HP unethical.
Sep 21, 2008 | Computers & Internet
HP Pavilion DV2000
first replace the inverter to correct the lighting problem ok. then move to the other problem both can be recovered from
so ebay dv2000 lcd inverter buy it get a screw driver link me bakerandre2000@yahoo.com
Apr 14, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavilion dv2000 Screen.
the lcd lamp driver (inverter is likely bad)
inverter provides the high voltage that the lamps need.
as it heats up it has the symptoms you describe.
easy to replace.
I see them on ebay for around 30.00
Feb 03, 2008 | IBM ThinkPad T23 2647 Notebook
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
41 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
