Problem with my ricoh 2238 printer
I replace oil for ricoh 2238 but still there is messege showing that the oil is empty and need to change
* 28 * - maintenance mode. you need to reset the oil counter in mode 5. somewhere there. can't remember the exact simulation number. It's the same mode as the fuser settings.
Posted on Jun 27, 2008
Richo SP C410DN says black toner is empty, but just replaced...tried multiple toners...
Look at the toner hopper closely there are little springs that some times get caught "down" they line up with the contacts on the toner. -Carl
Jan 31, 2014 | Ricoh Aficio SP C410DN Laser Printer
Used toner bottle is full
I'm going to assume you typed the model wrong, and that it is a 1035 like the header states. If this is the case, the used toner on these is inside the transfer belt unit.
Open the duplex unit if equipped, then open up the right-side door. Attached to the door is the transfer belt unit, as see below:
602d8058-7b67-4449-895f-e01b266fd371.jpgLift the lever as shown, then lift unit out of machine. There is a panel with 6 screws near the bottom of the unit, remove all 6 screws and remove the cover. Be very careful, this thing is going to be FULL of used toner, and will make one HUGE mess if not disposed of properly. Once emptied, put cover back on, re-install unit, close doors, and you should be good to go.
Jun 09, 2013 | Ricoh Aficio 1035 Copier
How do I refill the Ricoh SC P400 cartridges and replace the chip?
the cartridge cannot be refilled and chip cannot be changed. you have to replace the whole cartridge. Ricoh don't refill laser printer cartridges mate. I work in Ricoh.
Jan 04, 2011 | Ricoh Aficio SP C410DN Laser Printer
RICOH 2238 C ERROR CODE SC680
SC 680 BCU/ MUSIC communication error After the engine CPU sends a message, the Music CPU does not respond within five seconds three consecutive times. • Toner cartridge memory chip loose connection • Memory chip problem • Memory chip cable wiring problem 1. Turn the main switch off and on. 2. Check if the toner cartridge is installed correctly. 3. Replace the toner cartridge. 4. Check if the harnesses are not damaged. 5. Replace the BCU.
Mar 12, 2010 | Ricoh Aficio Type 2238 (411603) Print...
Installed new black toner but it still indicates it is empty and nothing will print!
Did you install a brand new cartridge? Or did you refill the old cartridge?
Ricoh has "smart chips" in the toner cartridges, and those tell the printer how much toner is used. If you refill the toner,the smart chip must BE REPLACED, the old chip will remain stuck at "empty".
Sucks, that Ricoh for you. That why that printer was $160 on Woot. LOL.
(Yea, I got suckered in too...)
Oct 13, 2009 | Ricoh SP C220N Aficio Laser Printer
Aficio 2232C, I cann't do anything.
Looks like you need to replace your fuser oil unit (the oil is used to lightly coat the fuser to prevent paper sticking). This is just a simple part swap out, not much harder than loading the printer with paper, full instructions are in the manual (see link) and a the units themself are readily available, if you dont know your local supplier google will return dozens of online merchants
http://ricoh-usa.com/downloads/manuals/bw/aficio2232c.pdf
Sep 30, 2009 | Ricoh Aficio CL7000 Laser Printer
Ricoh Aficio 2238c: Fuser Oil Unit
you really can not refill the bottle but I would recommend two things. One find a fuser oil unit on ebay and order it quickly. Next hit the yellow clear modes button, then hit the numbers 1 0 7 , then hold the red clear stop button till the display panel changes. hit copy sp, select 7 data log. now use the page down arrows located in the middle of the disply till you see 7804 push it then go to #10 oil supply and hit execute. this will reset the oil counter and allow you to use the machine till you get the new unit.
Oct 25, 2008 | Ricoh Aficio CL7000 Laser Printer
Ricoh Aficio CL5000 Laser Printer
Click here for the link to the Ricoh USA website.
There you will find downloads such as user info, guides and driver downloads.
Hope this helps.
Apr 26, 2008 | Ricoh Aficio CL5000 Laser Printer
134 people viewed this question
jasbo
jasbo
