Question about Whirlpool AD25BBK Dehumidifier
Oil inside the water collection res
This was to have been the third season for my Whirlpool AD25BBK Dehumidifier, and the fan started when things began getting damp in my basement as is normal this time of year. Well, it never seemed to fill up with water as it has previously. It had collected some fluid and I went to my laundry sink with the water reservoir to dump it in. What my unit collected, was heavy weight oil. What the Devil, where did it come from and what happen to this thing? Am I SOL, or what ???
  • Real-Carnut Jun 27, 2008
    So politely put, the unit is toast ... The next one I will spring for an extended Warranty. Consumer Reports rates the Kenmore 54701 rather highly so I guess I will check it out. Thank you for confirming my worst fears Tresilla. So much for banking that stimulus check ...
    President:
  • 1,462 Answers
The compressor runs in oil. suspect you have a quite bad leak and loss all the gas - hence no water collection and the compressor oil is being pumped out thro the leak
Posted on Jun 26, 2008
It doesn't poduce any water . It runs fan runs
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 02, 2011 | Whirlpool AD25BBK Dehumidifier
Unit runs constatntly, but is not pulling out any moisture. tank barely has any water in it
heatman101
Aug 06, 2011 | Whirlpool AD25BBK Dehumidifier
Compresser on the bottom gets very hot won't work
heatman101
Jul 19, 2011 | Whirlpool AD25BBK Dehumidifier
Does not collect water in bucket but runs all the time
Does it have a filter?
http://whirlpool.custhelp.com/app/answers/detail/a_id/953
also:
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises."
Jun 21, 2011 | Whirlpool AD25BBK Dehumidifier
Whirlpool gold dehumidifier, fan is running, but not collecting water. It's in a bathroom, and the temp doesn't get below 60. filter was very dirty and the inside as well, from not cleaning the filter....
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Feb 10, 2011 | Whirlpool AD35USS Dehumidifier
I have Whirlpool AD50USS0 Dehumidifier, but does not collect water
heatman101
Dec 15, 2010 | Whirlpool AD25BBK Dehumidifier
It is not producing water, it runs but no water is collecting in pan.
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again.
Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue.
This situation will have to be addressed by a qualified technician.
Take care.
Aug 19, 2010 | Whirlpool AD25BBK Dehumidifier
Unit runs but no water in tank. Unit does not expel hot air.
heatman101
Aug 17, 2010 | Whirlpool AD25BBK Dehumidifier
Coils will not heat up
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 03, 2010 | Whirlpool AD25BBK Dehumidifier
Fan runs ,coils are room temp. should they be hot or cold , no water is collecting in bottom
A dehumidifier is basically an air conditioner, so some coils should feel hot, the others should feel cold.
If no water is collecting, then the unit's compressor is not starting. Typically you have four possible failures causing this: the switch/wiring for the compressor has an open circuit, the motor-start capacitor for the compressor has failed, the compressor itself has failed, or all the refrigerant has leaked out.
If there is evidence that it is 'trying to start', but then clicking repeatedly, this can be a symptom that the refrigerant has leaked out, as some devices have a pressure switch to prevent compressor damage.
Also, a failed start-capacitor can also cause the click-click noise if the device has a current limiter switch on the compressor.
So the short answer is, it's broken :)
Oct 21, 2009 | Whirlpool AD25BBK Dehumidifier
Whirlpool AD25BBK Dehumidifier Logo
529 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike Squire
Mike
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
