Danby DPAC 10030 shuts down with water full alarm but there is no water in tank
  • 3 more comments
  • Anonymous Jun 28, 2008
    Same thing happens with mine. I have found no solution except unplug the unit and wait 1 min and plug it back in. Then it "might" work....or it might just do it again. Anyone have a solution?????
  • caper1948 Jul 16, 2008
    there is another drain,below the external water tank you can screw this cap off and the internal tank will drain, have towels handy to dry up. this not a fix
    See page 11of the manual, there may be a solenoid problem or a pump problem
  • notools Aug 04, 2008
    Using DPAC 10030
    Experienced same early shut-off scenario. I removed the snap-in spigot from the tank, plugged it back into the unit and gently blew some air into the machine thinking it was clogged internally. Things returned to normal for a couple of tanks. I think mine has dirt or something clogging from the inside.
  • joeyjung Aug 18, 2008
    Have the same problem, can extend the running time by putting a book under the front wheel for couple of hours but then the problem comes back.
    If tilt the unit forward, lot of water will come out then the unit can have a run time of 3-4 hours.
  • pdwesley566 Sep 11, 2008
    I read from another sire to take the back off and side panels off and blow out the lines as they can get plugged from time to time I have not tried this but nothing sayiong one cant give it a try.
david04928
  • 102 Answers
SOURCE: Danby dpac 7599 PC board fuse keeps blowing
Sounds like the Start capacitor might be shot.  I think  you need a professional to service it.
Posted on Mar 11, 2009
  • 233 Answers
SOURCE: unit does not cool with the exhaust pipe connection covered
you need to get the exhaust air out if the structure or it will never work, you can use regular duct from a supply house as a temp fix
Posted on Jul 12, 2009
  • 68 Answers
SOURCE: Using the DPAC 8020 AIR Conditioner (Danby)
these portable units will usually have a knob reading from low to high. set it about half way and adjust as needed. half way is usually low 70's
Posted on Aug 03, 2009
SOURCE: My danby air conditioner/dehumidifier model dpac
Also check to see that the nut on the male connection to the external water tank is tight. Mine dripped because the nut was loose.
Posted on May 30, 2010
  • 4736 Answers
SOURCE: my danby DPAC 12030 is
Since, I believe your model s a multifunction unit (Air Conditioner and Dehumidifier), Which can be operated together or separately. There are two things which may be causing this problem. If the dehumidifier function is operating the water collection tank o bucket may be full and needs to be emptied. In conjunction with this, the air intake filter on the inside front of the unit may be dirty or clogged.
There is a third thing that is also playing a role in this. The tubing that drains the water into the tank may be clogged. Which causes the water to backup and overflow. You can clear any clogs by using an 18" long, plastic Zip Tie, that is appropriately sized to fit inside the tube or hole. Insert it carefully and work it in past the bend in the tube, until the Zip Tie bottoms out or you run out of usable Zip Tie. The rotate (twist) it as you carefully remove it. As you reach the end of the Zip Tie, be prepared for some water to follow. CAUTION: BEFORE ATTEMPTING ANY SERVICE OF THE UNIT, TURN THE MASTER ON/OFF SWITCH TO OFF & UNPLUG THE UNIT FROM THE ELECTRICAL OUTLET.
Also keep in mind When dehumidify mode is selected, the indicator light will shine ORANGE. Air is
dehumidified as it passes through the unit,without being in full cooling mode. The fan will operate on medium speed. If room temperature is 25°C (77°F), fan speed can be adjusted; otherwise fan speed is fixed to "low". Note: The warm air exchange hose must vent inside the room when using Dehumidify Mode, not outside as it does when cooling. If the unit is vented outside, some cooling will occur.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Posted on Jun 08, 2011
Remove Water Tank
  • require you empty the unit by hand (usually less expensive units). These have either a removable water tank which must be emptied, or have an internal tank and a drain, where you have to empty the water into your own pan. Sometimes the drain is on the bottom of the unit, making it hard to find a pan that will fit under the unit to drain it.
  • discharge most of the water through the exhaust hose (usually more expensive units). This is called "Auto-evaporation" or "Self-evaporating" feature.
Most units are made so that they can be drained with a gravity hose that flows to a drain inside or outside your house. But the water must drain down. If the drain is higher than the unit, you may need a condensation pump to move the water upward. A few units do include a pump to send the water a short distance through the drain pipe.
do no forget to rate the solution as fixya if it helps you.
thanks.
Jul 02, 2008 | Danby DPAC10031 Air Conditioner
Danby dpac 10071 air conditioner is not cooling. a red light is on next to an icon with a full cup. Does anyone know how to make it cool?
That indicates that the water collection bucket is full and needs to be drained. Once the unit is turned OFF, unplugged and drained, the unit will start up and start cooling again. The drain hole is on the rear of the unit, just above floor level. You can either drain it in a shallow sided pan capable of holding 1 quart of water. Or roll it to a floor drain or outside to drain it.
Hope this helps you and thanks for choosing FixYa.
Jul 29, 2011 | Danby DPAC10061 Air Conditioner
I have a 7 year old danby portable air conditioner it seems to work good but my neighbor just purchased a new 12000 mine is 10000 he said he has to empy water frequently We have never had a drop of water...
This model is designed to heat the condensed water and send it out the exhaust duct as vapour. It prevents accumulation on less humid days. It sounds like it's served you well for seven years.
However, I do recommend one step for owners of the DPAC series. At the end of the season, drain the internal tank by opening the two taps at the bottom rear. Put a pan beneath them . The internal tank only holds one cup of water.
Jul 10, 2010 | Danby DPAC120068 Air Conditioner
My Danby Premiere DPAC 13009 is leaking water through the bottom. I have attached the continuous drainage hose, and no water is going through it. I tried to manually drain the tank using the drain at the...
Water is collected from cooling mode, not just dehumidifier mode. It does not always evaporate into the exhaust stream due to design limitations.
Of course the water should never leak even on the hottest day. Two suggestions:
Try removing the hose and attaching the external tank to see if it has any effect. Otherwise, you'll need to locate the exact source of the leak.
May 25, 2010 | Danby DPAC12031 Air Conditioner
My danby air conditioner/dehumidifier model dpac 8399-4 leaks water all over the floor and never fills the holding tanks what can I do to fix this problem?
Probably needs cleaning. I assume it is on a level surface. Water drips from the evaporator coil into a collection tray of some type and then drains into the holding tank, this tray is either broken or the outlet is plugged.
Good Luck,
Gilsh
Nov 26, 2009 | Danby DPAC8399 Air Conditioner
Aug 03, 2009 | Danby DPAC8020 Air Conditioner
Unit does not cool with the exhaust pipe connection covered
Jun 01, 2009 | Danby DPAC10031 Air Conditioner
Red flashing light
Had the same problem, thing shutting off after an hour, no water in the tank. I had the external tank attached, was always bone dry. What I didn't know was on the side, there is a slide out tray which acts as the internal tank. The lid to that tank activates a micro-switch which tells the unit that it's full. This tank was dry too, but the switch was getting jostled, casuing it to trip. I've taped down the switch now, and it's fine. I check the tank every few days, just to be safe, but it's never got any water in it. Hope this helps.
Jun 25, 2008 | Danby DPAC9030 Air Conditioner
Danby DPAC 8099 Moisture Removal problem
If the dew point of the air in your place of operation is low you will not get moisture out of the air. Generally when the unit is first used it lowers the indoor humidity and you get a lot of moisture. Once things settle out the amount of moisture will decrease.
May 17, 2008 | Danby DPAC8099 Air Conditioner
Heating & Cooling Logo
404 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
