Question about Sharp Microwave Ovens
Wheels on turntable are broken - Sharp Microwave Ovens
  • 100 Answers
Have your brand and model number, then check with www.microwaveglasstrays.com
Posted on Jun 30, 2008
I have a daewoo edition 1 microwave/convection oven. One of the wheels/runners of the turntable is broken. I am looking to replace the turntable, do you stock such spares?
FIXYA doesnt' stock or sells anythign. We are strictly a Q/A Forum made up by members like you and me, some ask, some make questions NO SALES
Do a query for parts at some websites like
Daewoo Microwave Parts
Parts Accessories
Find Daewoo Microwave Spares
Daewoo Spares Parts Accessories
Oct 29, 2015 | Daewoo Microwave Ovens
Turntable does not turn
checkunder neath it is belt driven and probably has broken belt
Mar 18, 2015 | GE Advantium 120 Convection/Microwave Oven
My turntable doesn't turn
Sounds like the turntable drive coupling is broken. In the bottom of the microwave where your turntable is, underneath that is a small drive coupling that the motor shaft pushes into. if the motor doesn't turn or the coupling, which commonly has a D shape shaft to keep it from slipping, is broken, the tray will not turn. One quick test it to remove your tray and see if you can turn the coupling easily by hand, if you can you probably have a broken drive coupling. The turntable motor is very difficult to turn by its shaft. so if it turns easily it is probably a broke coupling. NEVER force your turntable around by hand or you can break that coupling.
May 12, 2014 | Panasonic NN-S963BF Microwave Oven
Our Spacemaster Microwave can make occasional loud grinding or vibratory noises--deep and low sounds. Solution?
If it has a turntable, the wheels are worn or dirty and are chattering. When I have this problem, I take out the turntable, clean up the floor of the oven, the bottom of the plate, and the wheels on the turntable ring. Then I push a small amount of paste wax (made by S. C. Johnson) onto the axles inside the wheels to lubricate them. (I've kept my worn-out turntable ring going for over 10 years by doing this.) If the turntable has a central post through the floor of the oven, the bearing may need cleaning and lubrication.
Other possible causes would be the bearings in the magnetron cooling fan or the microwave stirring fan in non-turntable models. Excessive dirt on fan blades can cause imbalanced running, which will also generate vibrations.
Dec 30, 2010 | Microwave Ovens
I have a Kenmore microwave model 721.61820100 and the turntable wheels just broke. Which part do I need to replace it. The glass part is not broken, just the wheels on which it rotates on.
The part you need is the turntable support. Sears shows the part on their parts site, and here's another source that I use. The support just slides onto the motor shaft through the hole in the bottom of the oven.
Dec 12, 2010 | Kenmore 80809 Microwave Oven
Turntable wheel under glass tray broken
If the microwave comes with a roller ring to rotate the glass turntable then I would recommend that it needs to be used when the microwave is operating, as the turntable rotates the food so it can be heated evenly.
I would recommend checking with your local Panasonic repairer he may have access to a new roller or even a second hand one to tide you over.
Mar 20, 2009 | Panasonic Microwave Ovens
Need 3-wheel carousel for kenmore721.63252300
Ooops! I see it now.
You can find exploded views and order parts by entering your model number at the Sears parts site.
Dec 05, 2008 | Microwave Ovens
Microwave turntable won't turn
You may have a tunrtable motor or spindle problem..
This info is from GE website..( link : http://genet.geappliances.com/geasearch/Dispatcher?REQUEST=GETSEARCHRESULT
To minimize the possibility of electric shock, unplug this appliance from the power supply before attempting any maintenance or cleaning.
  • Make sure the turntable is centered and seated properly. On models with a stirrer motor there is a shaft protruding up through the floor of the microwave. Make sure the turntable is securely fastened to this shaft. On models that turn on a ring with wheels attached, make sure the turntable is seated securely on the ring.
  • Check the turntable to make sure it is placed right side up. If the turntable plate is upside down it will drag on the floor of the microwave.
  • Check to make sure that there is no food or debris under the "wheels" of the turntable ring. Food can prevent the wheels from moving forward.
  • Be certain you are pressing a cook function rather than a timer function.
  • If the microwave has a turntable on/off feature make sure the turntable was not inadvertently turned off. Try depressing the turntable on/off pad to re-engage the turntable.
Sep 21, 2008 | GE JVM1850 1000 Watts Microwave Oven
Lost glass turntable support wheel
I have the wheel you're looking for. We are tossing a broken Emerson MW8168B but I'll hold the turntable support for you if you want it. Let me know.
Apr 19, 2008 | Emerson MW8168B Microwave Oven
Microwave Ovens Logo
24 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
