Hi i have tv sony 57 and the convergence i cant fix it red is curve and blue
  • tradewins Nov 26, 2008
    I replaced the ic's but still some red outlines. The standby blinks 5 times any ideas what the alert is?
    thank you
  • 8,617 Answers
You need to replace both convergence ICs STK392-560 you can get replacement ICs at the following link and they provide free instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Posted on Jun 26, 2008
How to fix the color alinements
You need to replace the two STK-392-560 CHIPS THIS SET USES AND DO NOT RUN THE SET WITH CONVERGENCE BOWED or soon you will have other parts bad.
May 27, 2012 | Sony KP-57HW40 57" Rear Projection...
Want to perform manual convergence. when i get to the convergence section, buttons on tv will not perform the task. remote has not worked since quite new according to previous owner. Is there a reason for...
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 28, 2011 | Sony KP-57WV700 57" Rear Projection HDTV
Picture out of alignment. letters appear in red green and blue beside each other and curved. 3D effect.
Thats a convergence error. Your model will require the two Convergence ICs and also 8 pico fuses 6 3.5 amp and 2 5 amp picos. Of you require a repair kit with the parts and instructions you can get the Sony type 1 convergence repair kit from www.tvrepairworld.com which fits your model.
Jul 04, 2011 | Sony KP-57WS500 57" Rear Projection...
I turned my kp57ws510 on and I had three images-red, blue, and green. If I put it on ESPN the ticker at the bottom is curved.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
You can get a repair kit with parts and instructions from www.TvRepairKits.com
Sep 20, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
The picture looks 3D
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 03, 2009 | RCA HD52W56 52" Rear Projection HDTV
Color overlapping and curved picture. I have had problems in past with the green curved lines but fixed by adj the voltage screw
Ur convergence is dead,need a convergence kit,use what in that kit.U know how to solder right?Buy a convergence kit, with these websites.Tv Repair World.com,Ebay.com.
Sep 28, 2009 | Sony KP-57HW40 57" Rear Projection...
I have a sony projection tv and the screen is curved and blurry.
Need new convergence amp ic's and probably a few resistors.
Cost you about $30.00 for parts.
Search for keyword "convergence".
-dan
Jul 08, 2009 | Sony KP-51HW40 51" Rear Projection...
Distorted image and color
sounds like the convergence ICs have failed. Will the red and blue move in all 4 directions when you try to adjust the convergence? If not the convergence ICs are bad replace both of them also check the resistors that power the ICs as they may be open as well.
Mar 12, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
TV going Blue
malfunction of the convergence ics
Dec 27, 2006 | Sony KP-57WV600 57" Rear Projection...
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
