Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
F/up on Frig section not cooling and at time appears to...
I just wanted to followup on your solution regarding a Maytag SxS model MSD2756DEW frig section not cooling at times problem. You commented that it might be a defrost problem.
Well, right after I posted my problem, I turned the refrig & freezer down (approx to 2 or 3) as this has helped in the past. I did not get a chance to check the evaporator coil in the freezer as you suggested but did notice that more and more frost was forming in the back and on the evaporator cover. Once the frost became wet, the refrig appeared to "work" again, i.e. cool air appeared to circulate from the top vent. Since I didn't get a chance to check the evaporator coils as you mentioned but noticed all the frost, do you think my problem is a defrost-related issue? How can I determine or a service repairman identify whether it's the defrost timer or the control board or something else? I have not had luck with repairmen and was wondering how I can be assured of a qualified one. The last repairman did not mention a defrost issue... Thanks for your help... Appreciate it...
  • mcmillansfur Oct 28, 2008
    Refrigerator not cooling, purchased new relay and need help with wiring
    Scholar:
  • 68 Answers
If the defrost timer is malfunctioning, and I think that unit has a mechanical timer, causing the defrost to cycle slower than it should, then yes... the coil can freeze not allowing air to pass through until the next defrost. One of the first things a repairman should check is the defrost circuit if the coil is frozen. Many times you would not notice unless you open the door alot or your freezer is quite full.
Posted on Jun 27, 2008
Maytag sxs; freezer frosts up no defrost + runs all the time + fridge side is cold.? Thanks.
Try to turn the defrost timer manually to force into defrost. If the frig defrost the ice then replace defrost timer. If unit dose not defrost the ice then check defrost heater and replace if needed.
Oct 26, 2014 | Refrigerators
Msd2657heb------once every month my frig and freezer stops cooling the frig is on but not cooling---i unplug frig wait 5 minutes then it starts cooling again-all most like it is in a defrost mode that...
Hi.
There is need to test the defrost system and the electronics. If the fridge restarts in five minutes, then that is not enough to defrost. Problem may be electronic temperature control. Compressor start capacitor is also worth a look.
Let me know if you want more help on this.
Regards.
Ginko.
Mar 13, 2011 | Maytag Refrigerators
Fruits & Veggies are freezing in both lower frig compartments
Good day,
This problem appears in spades this time of year, every year.
The problem becomes more severe when the temperatures in the house cools down and is made even worse if the usage of the machine becomes lighter.
It occurs when the machine is off, not on.
There is an open vent, near the bottom, between the freezer compartment and the fresh food compartment. This opening or vent is necessary when the machine is running, so that the air pumped into the top of the fresh food section, can return to the freezer compartment. This is by design.
Now,
When the machine is off, the zero degree air from the freezer compartment. can drift into the fresh food compartmnet and drop the temps near the bottom to below freezing.
Off time increases substantialy at this time of year.
Some have even recommended turning the controls colder to offset the problem, but I've no proof it works well, or even a little.
SXS and top freezer models experience it more than bottom freezer models.
Dec 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frig stopped cooling. Bad condensor Fan Motor.
sounds like a bad thermostat,that tells unit when to kick on and off.
May 15, 2009 | Maytag Refrigerator Light Switch -...
Sub zero 532
you might have a few problems,, make sure to check the condensor is clean, also make sure the condensor fan motor is going... you might have a bad Condensor fan motor, and Ref Control or a Freon Leak @ the Evaporator... I would call a tech to check it out...
Sep 27, 2008 | Sub-Zero 690 Side by Side Refrigerator
I have a fairly new Maytag frig with bottom freezer which cools well but I can't seam to change the temp and more importantly, a lot of fog comes out of the frig port, the frig and freezer seam to have...
hi thanks for the question if you have fog coming out of fridge it sure is cold enough you must live in a very hot climate i wouldn't worry at all thanks the appliance doc
Sep 24, 2008 | Maytag Refrigerators
Frig section not cooling and at time appears to stop but freezer is ok
There is one compressor, condenser and evaporator in all refrigerators. The part that makes the cold inside the unit is the evaporator. It's in the freezer, behind a barrier on the back wall. It's a "coil" with many small fins. There is a fan that blows air over the evaporator which makes the air cold. This air comes from the freezer and stays in the freezer. The cold food section (the refrigerator) has a control that opens a hole for air to pass from the freezer to the fridge. This being said...you can rule out the "temperature control" for the fridge.
The sound you hear could be the compressor relay, the evaporator fan or maybe something else. It could be bad, it could be not too bad. (Like a fan blade a bit unbalanced with dust)
OK,,, back to the evaporator. There is a little heater next to the coil that turns on every 8 hours or so to defrost the coil. That's called the "defrost cycle". Makes sense, no? If the defrost timer (common problem) or defrost control board (common problem) go bad, your evaporator coil freezes up, and that's not good for anything in your refrigerator. But it can often keep the freezer section cold. You can easily disassemble the evaporator cover in the back of the freezer and take a look. If it looks like a block of ice, you probably have a defrost issue. An even, thin coat of frost is OK, but lots of ice is a no no.
Jun 26, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
173 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
